DIY: MotoTundra's 2014 Tundra D2S Retrofit
Discussion in 'Lighting' started by MotoTundra, Jan 18, 2016.
  1. Nov 20, 2016 at 3:40 AM
    MotoTundra
    MotoTundra [OP] The Ocho
    Don
    Nice! Good luck! @Paulskie Did you already buy the parts? TRS often has a great sale over Thanksgiving.
  2. Dec 20, 2016 at 8:44 PM
    geno0506
    geno0506 New Member
    Michael
    Amazing talent you have my friend!
  3. Dec 20, 2016 at 9:14 PM
    MotoTundra
    Don
    Thanks @geno0506 . It was a learning process for sure!
  4. Dec 20, 2016 at 9:41 PM
    geno0506
    geno0506 New Member
    Michael
    You learned well my friend! I PM'd you!
  5. Dec 21, 2016 at 6:28 AM
    MotoTundra
    Don
  6. Dec 21, 2016 at 2:59 PM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    excellent write up! now only if i have the skills and the trust in myself to attempt this.
    MotoTundra[OP] likes this.
  7. Dec 21, 2016 at 5:25 PM
    MotoTundra
    Don
    Thanks. I was worried, not gunna lie! I'm sure you can do it!
  8. Jan 10, 2017 at 9:07 AM
    blizz86
    blizz86 New Member
    I had only done fxr retrofits with the steelstik method and nut and bolt method.. for exact alignment but mini d2s 4.0 performance is not one to be ignored so I went for it this time around. Super easy retrofit process! Your guide with the shaving tips helped a lot.
  9. Jan 10, 2017 at 2:39 PM
    MotoTundra
    Don
    Glad it helped! Any pics of your new setup?
  10. Jan 10, 2017 at 2:46 PM
    blizz86
    blizz86 New Member
    Haven't finished yet. Waiting on another pair of shrouds since I changed my mind.. was originally going with xsb halos behind the normal panameras but then I changed my mind to the panamera drl lol.. and then I tried to tint the amber reflectors but the vht nightshade ate a layer of the plastic as it dried.
    So waiting on the shrouds, reflectors, and some tack cloth to rub my paint down.
    From the test fitting though I'm fairly impressed by the mini's performance with the cbis
  11. Jan 10, 2017 at 2:58 PM
    MotoTundra
    Don
    Gotcha, sounds like it will be a nice setup.
  12. Jan 10, 2017 at 3:09 PM
    blizz86
    blizz86 New Member
    It'll be fairly simple.. no led strips or anything like that.. but I did give a go at trying to achieve the passive white demon eye.. painted the shields white with some epoxy caliper paint. Hopefully they are as good as I hope they turn out to be!
  13. Jan 10, 2017 at 3:10 PM
    MotoTundra
    Don
    I'm sure they will.
  14. Jan 17, 2017 at 7:18 AM
    MotoTundra
    Don
    @trsandrew , I already installed your XSB LED Demon eyes in my retro, if I add the XSB 3.0 LED DRLs do I need both "Driver's" on each headlight or can I use one to control both the demon eye and DRL on each headlight?
    It's nothing urgent so I figured I would tag ya. Thanks!
  15. Jul 18, 2017 at 5:07 PM
    MotoTundra
    Don
    I would explore this site as well as others to really get a lot of info on retrofits. There are so many options and it's great to get them the way you like them the first time. I wanted to go simple, so I did. I blacked out my reflector bowl and bezel, but kept the side marker lenses orange for safety. I didn't use a shroud that lights up like the panorama, but I did go with demon eyes for s subtle effect. Sometimes I contemplate adding an LED DRL strip to them, but for some odd reason I like the stock orange/amber DRL's. It's all about preference and what YOU like best.
    Backslider likes this.
  16. Aug 13, 2017 at 8:19 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    @MotoTundra OMG excellent detailed write up. Sub'd so I can go through this when I do mine! I'm thinking of using everything u did but use a shroud with an LED so I can use that as my DRL. Have any recommendation on shrouds w/ LED to use for DRL?
  17. Aug 13, 2017 at 10:55 AM
    MotoTundra
    Don
    Sire thing, glad it can help. I'm not too familiar with shrouds that light up, but I know Morimoto has the panamera and panamera switchback LED. I would assume they will work but I think an LED DRL strip would be much brighter. Someone else can give you better info on them than I though.
    I will say I really like all my Morimoto stuff. If I were to do another I will go with all Morimoto again.
    Good luck!
  18. Oct 3, 2017 at 9:25 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Really great write up. I don’t think I have seen such detailed instructions in a DIY yet.
    tomsinamerica and MotoTundra[OP] like this.
  19. Oct 3, 2017 at 1:51 PM
    #49
    MotoTundra
    Don
    Thanks, much appreciated! It isn't cheap to buy a retro, but if you can pull it off yourself, it's not too pricey. The hope was that this would help the guy debating on trying it for the first time.
    040Tundra[QUOTED] likes this.
  20. Oct 3, 2017 at 2:55 PM
    #50
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    @MotoTundra , I can do this DIY now that I have step by step directions w/ pics. If I may ask, how much in materials did this project cost you? YOu can PM me if that’s better. THANK YOU.
  21. Oct 3, 2017 at 4:20 PM
    #51
    MotoTundra
    Don
    Sorry I don't remember off hand.
    I basically bought all my stuff from TRS with the exception of the spray paint and a few other little things.
    They usually have a black Friday sale, that's when I bought my stuff so I saved a little bit.
    You can add the stuff to a cart to get a better idea...
    www.theretrofitsource.com
  22. Oct 4, 2017 at 4:48 AM
    #52
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    That’s a great idea, thank you!
  23. Oct 4, 2017 at 5:04 AM
    #53
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    a few weeks ago, I ordered the following...
    D2S 4.0
    Morimoto bulbs
    35w ballasts
    igniters
    relay harness
    butyl adhesive
    extensions
    90mm housing caps
    Pretty much everything @MotoTundra had in his shopping list with the exception of LEDs & Halo parts since i'm OK with old school amber DRLs.
    If my memory serves me correctly, my wallet felt lighter by $402. I didn't use coupons, i'm impatient and tired of driving in the rain with zero visibility. (interesting side note, since i ordered my lights, it's not rained in my part of NC - I hereby apologize to my neighbors now on water restrictions, I do feel somewhat responsible)
  24. Oct 4, 2017 at 6:01 AM
    #54
    MotoTundra
    Don
    Awesome! I too love the old school amber DRL's, I only went with LED demon eyes which are powered independently so I kept my amber DRLs. The demon eyes look cool but it's rare that it is dark and I don't have my headlights on. Not a waste, but they are seldom seen. They are meant to be subtle, so they aren't very noticeable during the day.
  25. Dec 17, 2017 at 1:48 AM
    #55
    MDHinSD
    MDHinSD New Member
    Michael
    SoCal SD North County
    2017 Black Tundra CrewMax 4X4 TRD
    Blackout Grill
    Looks Great!! Thanks for the tutorial!
  26. Dec 17, 2017 at 7:41 AM
    #56
    MotoTundra
    Don
    Thanks.
    Anytime, hopefully it can be of help!
  27. Jan 11, 2018 at 3:33 PM
    #57
    BeachyTundra
    BeachyTundra New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    The time has come. My parts are on their way.
    Bi-LED projectors, RGB Demon-Eyes, 12" RGB LED strips, RGB Halos behind panamera shrouds....I'll keep everybody posted on the progress!
    TRON and MotoTundra[OP] like this.
  28. Jan 11, 2018 at 4:13 PM
    #58
    MotoTundra
    Don
    Please do! I can't wait to see the bi LED setup!
    TRON likes this.
  29. Jan 11, 2018 at 6:11 PM
    #59
    775tundra
    775tundra New Member
    2015 superchargered CM
    Magnuson supercharger, 22x9.5 black rhino traverse, black widow muffler, URD pulley, katskins, pioneer 4600NEX , Toyo ST2, SOS racing 2/4 drop
    nice! Doesn't look too difficult. I have some extras in the garage I may give this a shot.
  30. Jan 11, 2018 at 6:24 PM
    #60
    MotoTundra
    Don
    It's not. Just a bit tedious.
