DIY maintenance versus Toyota Care with engine recall in mind
Discussion in '3rd Gen Tundras (2022+)' started by buzzkill42, Jan 7, 2025.
  1. Jan 9, 2025 at 6:19 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    I saw the responses after I posted. That is a very "interesting" path you need to do it in the app. Not saying the website is any better though.
  2. Jan 9, 2025 at 6:56 AM
    AZBoatHauler
    So.Arizona
    This may be a dumb question - if you have the skill and tools to change the oil every 5k miles, why would you buy a maintenance plan?
  3. Jan 9, 2025 at 8:10 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I kicked myself for buying the plan. It does cover the 40K plug change. They do rotate the tires every 5K at least I don’t have to mess with those.
  4. Jan 9, 2025 at 8:39 AM
    buzzkill42
    buzzkill42 [OP] New Member
    Joe
    2024 Tundra 4x4
    You'll have to check the wording of your ToyotaCare documents, but there is a chance you can cancel it for a refund.
  5. Jan 9, 2025 at 8:51 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    I’ll look into it. Thanks.
  6. Jan 9, 2025 at 10:14 AM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
  7. Jan 9, 2025 at 10:55 AM
    Brit84
    Brit84 New Member
    done, and on/off phone....nada, ill contact their app support
