DIY Katzkins with seat warmers
Discussion in 'General Tundra Discussion' started by Patch999, Sep 19, 2018.
  1. Oct 8, 2018 at 2:30 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    Where did you get the Alea leather kit?
  2. Oct 8, 2018 at 2:41 PM
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    Ebay. touchups is the seller. just a charcoal gray pattern. took way longer than expected, but looks good and easier to keep clean hopefully. It came with leather for the armrests also.
    TundraLuv and Patch999[OP] like this.
  3. Oct 9, 2018 at 11:33 AM
    Berkdawg
    Berkdawg New Member
    2013 Rock Warrior
    Clazzio Seat Covers, Eibach/Toytec Coil Overs (3"), Toytec Boss Rear Shocks, Firestone Airbags
    Thanks @Patch999 for the insight. It is 30 degrees here now and I have warm seats!
    DoubleJackOnTap and Patch999[OP] like this.
  4. Apr 5, 2019 at 5:11 AM
    Danny
    Danny New Member
    2018 Tundra Crewmax SR5
    I was considering paying the local installers 650 to do this for me but you may have just convinced me to save that money and do this on my own!
    Patch999[OP] likes this.
  5. Jun 7, 2019 at 8:58 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Got my big box o’ Katzkin yesterday! Hoping to start this weekend.
  6. Jun 7, 2019 at 10:49 AM
    Patch999
    Patch999 [OP] SSEM #17 You are what you do when it counts
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Awesome. You will love them. The best mod I have done.
    panicman[QUOTED] likes this.
  7. Jun 12, 2019 at 8:28 AM
    panicman
    Eric
    Ok- finished completely on Tuesday.
    Everything went smoothly until the driver seat. Because it’s electric, you can’t articulate it to make getting the zipper closure at the bottom of the backrest any easier. In fact, I managed to pull the zipper slider off of the teeth completely trying to muscle the zipper closed (I was admittedly impatient by 11pm Monday night.
    No sweat- I installed the driver seat unfinished and tackled it again on Tuesday- this time inclining the driver seat all the way forward before disconnecting ground, unbolting and unplugging the seat and removing to my work bench. I was able to put the zipper slider back on the teeth, and the zipper was in a better position to close.
    I am now very pleased with the result. The Katzkins feel great!
    To finish I will get a steamer and get rid of any wrinkles.
    Huge thanks to Patch999!!! I used his guidance like an instruction manual.
  8. Jun 12, 2019 at 8:33 AM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Congrats. They look great.
  9. Oct 25, 2020 at 9:23 AM
    umarali
    umarali New Member
    Arlington, TX
    Looks amazing. Those wrinkles, are those avoidable? How so? Or it is because of not being oem? i saw some on ebay with TRD stitching, did u prefer one without TRD?
  10. Oct 25, 2020 at 10:45 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Some of it settles but try to avoid most of it by compressing the foam and tucking/pulling technique. Heating the pieces in the dryer as you go helps.
    panicman and umarali[QUOTED] like this.
  11. Oct 26, 2020 at 8:40 AM
    panicman
    Eric
    Those pictures are from immediately after install. Remember, these kits are folded/stuffed into a box for shipping, and then sit for who-knows how long. Most of those wrinkles settle out on their own, and any that still bugged me, I just used heat and steam to smooth out. I have very few wrinkles now.
    My big tip is to really focus on getting the seat and back panels that require hogrings exceptionally square before moving on with each seat. That’s where I found my newbie mistake was on the first seat I did- rear driver side, upper back panel (shamefully visible one the above pic!) Even that I was able to mitigate mostly with some heat and massage.
    Patch999[OP] and umarali[QUOTED] like this.
  12. Oct 28, 2020 at 6:53 PM
    TKNorthwest
    TKNorthwest New Member
    Washington
    2018 Limited Crewmax 4x4
    wish this was around back when i had my 1st gen
  13. Jun 14, 2022 at 5:27 PM
    Rivulose
    Rivulose New Member
    This has been super helpful!
  14. Jan 30, 2023 at 5:45 PM
    EvoTundra
    EvoTundra New Member
    Great write up!!
