DIY Guide to installing OEM led Bed Light and Pop & lock for tailgate
Discussion in '2.5 Gen Tundras (2014-2021)' started by BlueBottle, Apr 8, 2017.
  1. Apr 9, 2017 at 5:22 PM
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    I think I'll go without the Dynamat and put it in later if needed. I noticed the silver loom was factory after I posted. Too much excitement in this thread to see clearly :goingcrazy:
    BlueBottle[OP] likes this.
  2. Apr 9, 2017 at 8:57 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Good job @BlueBottle ! I discovered those grommets (driver and passenger floor board) when I installed my AMP PowerSteps and then used the passenger side grommet for my Pop N Lock tailgate lock (I also used some Dynamat to reduce the sound - it is much quieter than my last truck was without it). My bed LEDs were installed by my dealer accessory installation folks (part of my deal); they used a grommet in the back floor. None of these locations caused any lumps in the carpet - the wire looms run between the foam that is under the carpet.
    Cat3ILS and BlueBottle[OP] like this.
  3. Apr 10, 2017 at 8:24 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Same thing with me. I assumed they sent me the wrong wire because it was short but maybe they're all like that. I had to move my connection to under the bed for it to reach.
  4. Apr 10, 2017 at 8:31 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
  5. Apr 10, 2017 at 1:10 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Me three. The wiring for the tailgate portion was about a foot to long, and the wiring for the side of the truck was a foot to short. I reran the wire and just barely made it fit. That was with wiring thru the engine bay into the cab per the instructions.
  6. Apr 10, 2017 at 1:26 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Awesome write up. Just a heads up, though. Those parts are SET or GST accessories only. I'm not in either of those regions, so I can not get them like Sparks can.
  7. Apr 10, 2017 at 1:46 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    I went the direct route from the passenger floor pan. My wire was perfect length. I had maybe 8" extra wire so if I went the long way through the firewall it would have been short.
    I guess anyone doing this themselves should go up through the way I went so it's not short.
    Good to know!
  8. Apr 10, 2017 at 1:54 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I have have no idea what SET or GST mean. Always thought you could get everything :)
    I will adj the OP occordingly though. Thanks for the message
    :cheers:
  9. Apr 10, 2017 at 1:55 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Southeast or Gulf States? :notsure:
    BlueBottle[QUOTED][OP] and Roman like this.
  10. Apr 10, 2017 at 2:06 PM
    Roman
    Roman
    Franklin, TN
    It's Southeast Toyota and Gulf States Toyota. They can get aftermarket accessories that are sold to them from third parties, and then they stick a Toyota part number on them. The part numbers usually begin in 00016.
  11. Apr 10, 2017 at 7:34 PM
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    What a great mod. I have to do this one now! Adding it to my long list of to dos. Gonna need more beer.
  12. Apr 10, 2017 at 8:29 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Seriously.. this site makes my wish list keep getting longer and longer and longer...
    NewImprovedRon and ChucklesToy like this.
  13. Apr 11, 2017 at 10:21 AM
    Roman
    Roman
    Franklin, TN
    Oh, I can get it. :D
    We order from one of our sister stores in FL for these parts, but only if absolutely necessary. The only reason I don't sell SET or GST parts is because I'm another middle man and can't keep the costs down. Plus, if problems arise, it would take too long to fix with us being just another middle man. It's one of those deals where I refer people to other dealers so they can get the best deal.
  14. Apr 12, 2017 at 3:49 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    would the tailgate lock make it through the winter? I've had issues with truck tailgates every winter. Gread mod btw.
  15. Apr 12, 2017 at 6:47 PM
    Tundra Fan
    Toby
    The Pop & Lock is just a solenoid that activates your factory tailgate lock.Whatever issues you are currently having (freezing up?) with your tundras lock probably won't be prevented by adding this.
  16. Apr 28, 2017 at 7:55 AM
    TJ1794
    TJ1794 New Member
    2017 Tundra Crewmax 1794 TRD Off Road
    Tailgate popabd lock power lock actuator Toyota OEM tri-fold tonneau Bed Rug bed liner AMP Research powersteps Weather Tech floor liners and rain guards TRD Pro grille and color match surround/hood buldge Color match door handles and mirror caps ICON Stage 5 suspension 2.5" resi's with rear leaf pack and 1" front diff drop Fuel Pump 18"x9" rims +20 offset with 295/70R18 Nitto Ridge Grapplers.
    I really liked this mod when I saw a YouTube video on it. Ordered it through sparks but it didn't come with any directions. I didn't go with the wire routing seen in the videos, for anyone looking to do the same mod I suggest routing the wire through the same cut outs that the camera wire goes through. Just pop out the plastic clips that secure the camera wire at the tailgate and bed, drill a 1/8 inch hole to the side of the plastic insert and use a pair of dikes to cut a notch to the drilled hole for the lock wire to slide into and reinsterted the plastic clips. This way the lock quick connect plug is right next to the camera wire connection under the bed and can come out the same way if the tailgate needs to be removed. This gives enough slack to route the wire through the engine compartment passenger side grommet. Looks clean and wire is well protected at the routing points. When I get a chance I'll post some pics in case my description is lacking.
    Rebel Tundra Man likes this.
  17. Apr 28, 2017 at 7:06 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    That't the route I went. But I didn't go up through the firewall as the floor pan is a more direct route.
    1EE482E5-C654-4D82-A587-9627E7DF05C2_zps_87d8412f29975ee8b0f9d2d635c34c14f7e3656a.jpg
  18. Apr 28, 2017 at 8:05 PM
    Voyagermike
    Voyagermike New Member
    California
    Just got my pop and lock today. Still waiting on my truck to arrive though:annoyed:
    Will use this when I install it. Love the idea of the two clicks to unlock the tailgate. Thanks. :thumbsup:
  19. Apr 28, 2017 at 8:50 PM
    #49
    BlueBottle
    '16 Platinum 4x4
    See fine print
    LOL it's bad when you have parts waiting for the truck hahah.. welcome to the broke club!
    Voyagermike[QUOTED] likes this.
  20. Apr 28, 2017 at 8:56 PM
    #50
    Voyagermike
    California
    It all started with me saying "no mods, I'll keep it stock". What the hell was I thinking.
    Weather techs arrived yesterday! Probably going to order tires this weekend. Not sure if I'll get new wheels just yet.
  21. Apr 28, 2017 at 11:32 PM
    #51
    TJ1794
    TJ1794 New Member
    Thank you sir, my suggestion exactly...
  22. May 10, 2017 at 8:31 PM
    #52
    Voyagermike
    California
    Installed the pop and lock today. Followed your guide but used the provided taps. Those things are a pain in the ass. Should have used the positaps like you recommend. The provided instructions were garbage.
    It is a little louder then I expected. The metal to metal contact is loud. Will probably install the dynamat. Or something on the actuator to quite it down. Thanks again for the write up. Really appreciate it.
  23. May 10, 2017 at 8:44 PM
    #53
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Glad it worked out. Definitely not annoying w the dynamat.
  24. May 10, 2017 at 8:46 PM
    #54
    Voyagermike
    California
    When I first tried it out I thought I left something loose or off. Or did something wrong. Just threw me off the first time. I appreciate the feedback!!
  25. Jul 12, 2017 at 6:00 PM
    #55
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    here is what the installers did to my pop and lock with the matting . Notice the matting on the actuator arm . Its very quiet .
    kkim124 and ChucklesToy like this.
  26. Jan 9, 2018 at 8:29 AM
    #56
    scjb007
    scjb007 Big Blue Nation
    Kentucky
    2017 White Platinum
    2018 led headlights and fog lights, Trd pro grill, rc 30in light bar, iron cross hd steps, trd sway bar, trd shift knob, color matched door handles and mirror caps, Linex bed liner, amber marker lights, led cargo lighting, anytime fog mod, VLED footwell lighting, bak x2 revolver, and FRAC.
    Hey @BlueBottle is OEM led bed lamps - Part Number: 00016-34089 sold per light or does it include both lights? Thanks
  27. Jan 9, 2018 at 8:50 AM
    #57
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Not BlueBottle but I can answer your ?. It comes as a Kit....all wiring and lights for Both sides.
    scjb007 and NewImprovedRon like this.
  28. Jan 9, 2018 at 10:48 AM
    #58
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Not sure what part # mine is but it came with both lamps and wiring and taps. Nothing needed but you install it.
    scjb007[QUOTED] likes this.
  29. Jan 9, 2018 at 10:50 AM
    #59
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    there is a guy on instagram that did a cheap pop n lock mod for latches and lock. pretty sick. I'll tag u
    LEKS and scjb007 like this.
  30. Feb 28, 2018 at 9:02 AM
    #60
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    That might have been me lol. All you really need is an actuator. Think I paid $16 on eBay and it’s a better actuator than what comes with the pop-n-lock kit. I had wire and loom laying around but those can be found cheap locally. I also ran my wire through the oem loom from the reverse camera, just a little cleaner imo. These should have been added from factory. 4CA37DF1-E56F-495D-ACA3-FAEB80480584.jpgDA2AF408-EF80-4B19-8F0F-580835BE6D70.jpg
    #60
