DIY: Front Coilover Install - Completed with Toytec Radflo 2.5
Discussion in 'General Tundra Discussion' started by csuviper, May 4, 2017.
  1. Jun 20, 2018 at 8:36 PM
    #91
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Taller you go the stiffer any Lift is going to be.
  2. Jun 21, 2018 at 7:07 AM
    #92
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    They are going to be adjustable up to the 3'' of lift
  3. Jun 26, 2018 at 9:26 AM
    #93
    kirk1963
    kirk1963 New Member
    Hi guys, just a quick update - I adjusted my coilovers to 3" - and still found the ride to be a good bit stiffer than they were stock, (2"). Accordingly, I added a spacer to each side (note I found that the studs in the radflos are only big enough for 1 1/4" spacer).
    I adjusted the ride height to 3" (25" center of hub to top of fender well) - so 2.5" radflo + the 1/4" shim. I find that it rides much better than at 3". Note there are a lot of potholes near me - so I'm probably more sensitive to ride quality on a day to day basis than most. If may roads were smooth, I would've been fine with the 3" adjustment with no shim.
    Hope this is helpful to somebody.
  4. Jul 9, 2018 at 1:06 PM
    #94
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    Give it time, mine have really broken in over time and I'm quit happy after having some doubts at first. I've let a couple people borrow the truck over the last few months and every single one of them has come back and said how they felt like the thing drove like it was on a cloud and was not at all what they expected (most have been total none car people).
    I do wish we had a lower spring rate options, I think 650lbs would be perfect.
    I haven't had it off road in a few months, but was very happy with it when I did.
    I think i'd want to remove my rear lift and lower the front a tad (i'm at 3" up front). But i don't like a rake....and toytec doesn't recommend no lift on the rear with the rear shocks.
    zcarpenter92 and sr5shark like this.
  5. Jul 9, 2018 at 2:00 PM
    #95
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    I've had these on my 18 for a few weeks now and while initial bump is stiffer than the stock TRD, they're way better damped and absorb the "entire" bump way better than stock. Crashing is completely gone.
  6. Apr 4, 2019 at 11:18 PM
    #96
    IvandGreat
    IvandGreat New Member
    Ivan
    2017 Tundra Platinum Crewmax Supercharged// 2007 Tundra Limited Crewmax
    Supercharged, Exhaust, Leveling Kit, Toyo MT
    Great point. I just had an alignment done 3k miles ago, i have a 2.5 spacer, im installing fox 2.5 and am going with 2.75 total lift, what do you think? Align it?
  7. Apr 4, 2019 at 11:55 PM
    #97
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Did mine the same but didn’t need to remove tie rod ends.
    Lessened the inner lca bolts so it could swing down
  8. Dec 11, 2019 at 5:49 PM
    #98
    Spakylpm
    Spakylpm New Member
    2024 Tundra
    About to try this install after years ago doing it on my 2010 I also don't remember having to remove tie rods. Can someone please advise if that is necessary. Thanks in advance!
  9. Dec 11, 2019 at 7:10 PM
    #99
    xtyfighterx
    Ty
    North Idaho
    No need to mess with tie rods
    equin likes this.
  10. Dec 11, 2019 at 10:28 PM
    #100
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Agree. I didn’t remove them when I did my coilovers.
  11. Dec 17, 2019 at 11:54 PM
    #101
    Skidmarks
    Skidmarks New Member
    Great thread guys. Picked up a set of 2.5 Radflos from Boss 4x4s great customer service btw. Going to throw these on with my new JBA UCAs. Spoke to David from coachbuilder and he says the best way to set these up is with a CB shim on the drivers side to correct lean and keep the preload identical on each side.
    equin likes this.
  12. Dec 18, 2019 at 4:41 PM
    #102
    xtyfighterx
    Ty
    North Idaho
    I did the shim with my fox coilovers to. David is a good guy I’d get a diff drop to if you plan on being over 2.5” and if you go over an 1” in the rear I’d do the carrier bearing drop.
    Skidmarks[QUOTED] likes this.
  13. Dec 18, 2019 at 8:57 PM
    #103
    Skidmarks
    TY, Did you do 2 shims driver side and 1 PS or just the 1 PS?
    I also purchased the JBA UCAs so I can get a solid alignment with plenty of adjustability. I plan on going a full 3-3.5 up front to level with the rear. Still may need a bmc with these 0 offset Fuel Vectors and 35 tires?
  14. Dec 18, 2019 at 10:49 PM
    #104
    xtyfighterx
    Ty
    North Idaho
    1 shim per side is what I did.
    Ya I’ll bet you will have to do the bmc.
  15. Jan 13, 2020 at 8:33 AM
    #105
    Skidmarks
    82227770_10221920701874810_2764034342303825920_n.jpg 81875732_10221920702154817_81553594930692096_n.jpg Yes BMC had to be done. One shim each side no lean. I may throw some Fox or radflos on the rear now.
    zachzap361 and equin like this.
  16. Apr 8, 2020 at 6:17 AM
    #106
    f.pecan
    f.pecan New Member
    Forest
    2007 Tundra DC 5.7L
    Eibach COs and rear AAL., Morimoto XBs, Rough Country 20" Light Bar, Rough County Ditch Lights, CBI ditch brackets, rock lights,
    Doing a coilover install on my 07. I noticed you, as well as the Toytec site instruct to remove the ball joint/spindle assembly. I noticed in some instructionals on youtube, they don't indicate that you need to unbolt the spindle. Do I need to remove the lower spindle bolts?
    I am just worried about popping out my CV joint.
  17. Apr 8, 2020 at 2:13 PM
    #107
    equin
    Ed
    DFW, TX
    I separated the lower ball joint assembly, not the upper. The CV axle didn’t pop out on mine, but I kept an eye on it. Re-installing the lower ball joint assembly was tricky and took some time, though. Mind you, I had hand tools and did the job in my apartment parking lot, so it may be easier for someone with better tools and space. Not sure how much easier or more difficult it may be to separate and reinstall the upper ball joint instead, but I’ve heard of others going that route.
  18. Apr 9, 2020 at 6:02 AM
    #108
    f.pecan
    f.pecan New Member
    Forest
    2007 Tundra DC 5.7L
    Ah, I see. There seems like two ways of doing it depending on how you go. I had to get to the UCA to replace it with the SPC adjustable. Just got the coilovers installed last night. It went pretty smooth, minus a few hickups getting the sway bar back in (didn't know you needed to loosen brackets). The upper ball joint did not give me any trouble at all getting back in, thankfully.
    equin[QUOTED] likes this.
  19. May 7, 2021 at 10:26 AM
    #109
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    I know this is reviving an old thread, but wanted to say great write up. Used this just now as a template for my Eibach install. Took right at 4.5 hrs (should've been less).
    Someone earlier asked about tools needed:
    19mm, 22mm, and 24mm sockets
    14mm and 17mm ratcheting wrenches
    1/2" torque wrench
    1/2" ratchet
    Couple GOOD 1/2" extensions (broke 2 Amazon grade wobble extensions)
    Jack
    1 or 2 jack stands
    Bonus: 1/2" impact gun
    Couple things I did different was I didn't need to disconnect the tie rod, didn't remove skid (I have a RCI), and I loosened the camber bolts after fighting with the LCA for way too long.
    First side took 3 hrs. Second 1 hr!
    csuviper[OP] likes this.
  20. Sep 8, 2021 at 11:41 PM
    #110
    IgotSR5onit
    IgotSR5onit New Member
    I know this is an old thread, but I had a couple questions. If im doing UCAs is there enough room to get +3 Toytec 2.5s in from the top or should I do coilovers according to instructions then UCA after they're reinstalled? Also, does anyone have the torque specs?
  21. Sep 9, 2021 at 5:15 AM
    #111
    You can install the coilovers and then the UCA's. The coilover is easier to install by bringing it in from the bottom. You will see once you start doing it.
    A couple of key notes:
    You do not have to remove the battery or washer fluid tank to get the UCA bolts out. There are a couple of clamps on the wiring harness that you open to move the harness over to give you room. On the drivers side, there is a clamp bolt on the frame that needs to be removed. I can take pictures of these for reference. There is a wrench that you can buy that makes the UCA bolts alot easier to remove. https://www.amazon.com/GearWrench-8...ywords=gearwrench+85922&qid=1631189946&sr=8-1
    Once you reinstall the UCA's, do not reinstall the ABS wire bracket until the truck is back on the ground. Several of us have had to bend the brackets slightly to put some slack in the wire.
    equin likes this.
