DIY: Front Coilover Install - Completed with Toytec Radflo 2.5
Discussion in 'General Tundra Discussion' started by csuviper, May 4, 2017.
  1. Dec 9, 2017 at 7:29 AM
    #61
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    I’m 3” up front and 1” shackle in rear and am level. Maybe .5” higher in rear
  2. Dec 9, 2017 at 8:06 AM
    #62
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    And you have Radflo with which leaf pack?
  3. Dec 9, 2017 at 11:10 AM
    #63
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Raffle/toytecs. Stock leaf with 1” shackle
  4. Dec 9, 2017 at 11:53 AM
    #64
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I just looked in the box again, mine only came with 1.
  5. Dec 9, 2017 at 11:56 AM
    #65
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Damn. Wish it came w two. It’s hard to break it lose with one sometimes. @ToyTec Lifts can you confirm it only comes w one?
  6. Dec 9, 2017 at 11:56 AM
    #66
    BlueBottle
    '16 Platinum 4x4
    See fine print
  7. Dec 9, 2017 at 11:58 AM
    #67
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Not yet, will likely be next week or the week after. Had stuff planned for this weekend and will be coming back from Vegas next Saturday.
    BlueBottle[QUOTED] likes this.
  8. Dec 9, 2017 at 12:00 PM
    #68
    midnight
    midnight IXLR8
    Todd
    GPT MS
    2024 Toyota Tundr TRD Pro
    Color matched mirror covers Color matched door handles Added TRD Performance package Changed the OEM fog lights to Rigid Industry Added AFE tow points TRD Performance Package
    Very cool
  9. Mar 15, 2018 at 11:08 AM
    #69
    Mitsuboost30
    Mitsuboost30 New Member
    18 Cement SR5 TRD Off Road 4x4 Crew Max
    @csuviper What is your total lift up front with the Radflo? CAnt decide between the Radflow or Boss :(
    @zcarpenter92 Did you ever get your lift installed? Pics?
    Thanks
  10. Mar 15, 2018 at 11:38 AM
    #70
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Yup, it’s been installed since late December. Here’s some pics
  11. Mar 15, 2018 at 1:42 PM
    #71
    Mitsuboost30
    Looks great!
    Did you shackle the rear?
    How much total lift did you get in the front?
    Thanks!
  12. Mar 15, 2018 at 2:25 PM
    #72
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Yup, I have em set at the 1.5” setting. I got just over 3” on the passenger side and just under 3” on the drivers side when the lift went on. Now that it’s settled I have around 1/2” of height difference between the two sides, will crank up the drivers side on a weekend sometime.
  13. Mar 15, 2018 at 3:35 PM
    #73
    TOTU17
    TOTU17 New Member
    Nice write up!!!
  14. Mar 15, 2018 at 4:52 PM
    #74
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    This is a great thread. I'm getting ready to install a set of these along with JBA UCAs. Do I need to extend my bump stops in the front? I plan to keep my front lift between 2 - 2.25 inches.
  15. Mar 15, 2018 at 4:53 PM
    #75
    IndyTundra
    Ronnie
    Indianapolis, IN
    Did they come out of the box at the 3" setting?
  16. Mar 15, 2018 at 6:38 PM
    #76
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Mine came pretty close to 3”, the passenger side was at 3.06” and the drivers side was at 2.93” with no adjustments.
  17. Mar 15, 2018 at 8:45 PM
    #77
    IndyTundra
    Ronnie
    Indianapolis, IN
    Thanks for the info. Did you extend your bump stops?
  18. Mar 15, 2018 at 9:02 PM
    #78
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Not yet, will probably be ordering SuperBumps at some point.
  19. Mar 25, 2018 at 10:10 AM
    #79
    tattoofan
    tattoofan New Member
    chris
    northern california
    2016 silver sky metallic crewmax
    are the factory torque settings listed anywhere ?
  20. Mar 25, 2018 at 11:08 AM
    #80
    17SR978
    17SR978 New Member
    Michael
    2017 Tundra SR
    I'll be using this as a reference when the weather warms up!
    zcarpenter92 likes this.
  21. Jun 20, 2018 at 4:03 AM
    #81
    kirk1963
    kirk1963 New Member
    Great thread guys, since this seems to be the best Radflo thread - I have a quick question on adjustment - I've had the radflos on my '18 with no adjustment for about a month (I got 1.7" oil the drivers side and 2.3" on the passenger side out of the box with no adjustment with the toytec shackles in the rear on the highest setting). Rides great, handles great - was super happy but too much rake. I just had them adjusted and have about 3.25" drivers side and ~3.5" passenger side now. Smooth roads are fine, but over potholes and such it seems much stiffer. I know 3" is recommended - wondering what everybody's experience is as to the optimal height. I see guys have them at 3.75-4" on facebook so I didn't think much about it (was late and had to head home) and cv angles look decent with the diff drop. Only about 500 miles on the kit since install and 100 since adjustment. Also wondering if I should go back down to 2.5" and use a 1/4" shim. Thank you.
  22. Jun 20, 2018 at 10:12 AM
    #82
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I cranked mine up to about 3” of lift and I agree with your that the ride is a bit on the rough side. They do not recommend 3” of lift. Not sure where you saw that. For best ride I would drop it down. Try 2.5” of lift maybe. Also I removed my front sway bar and it made my ride better. Maybe something you can try?
    TheBeast likes this.
  23. Jun 20, 2018 at 11:21 AM
    #83
    kirk1963
    kirk1963 New Member
    Thanks guys - also appreciate the PM's. Blue, as far as 3" see below - 3" was also the recommendation from Boss 4x4s and radflo when I spoke to them on the phone.
  24. Jun 20, 2018 at 1:26 PM
    #84
    BlueBottle
    '16 Platinum 4x4
    See fine print
    hmm I forgot where I read it. @Toytec Lifts can verify recommended lift heights though!
  25. Jun 20, 2018 at 1:46 PM
    #85
    TheBeast The Beach
  26. Jun 20, 2018 at 1:48 PM
    #86
    What’s the question?
  27. Jun 20, 2018 at 1:50 PM
    #87
    TheBeast The Beach
    I guess the recommended lift height for toytec radlfo. Is 3" preferred ?
  28. Jun 20, 2018 at 1:51 PM
    #88
    I would say no higher than 3”.
    kirk1963 likes this.
  29. Jun 20, 2018 at 7:52 PM
    #89
    kirk1963
    kirk1963 New Member
    thanks fellas - I'm going to dial it back to 3" and see how she does.
  30. Jun 20, 2018 at 8:21 PM
    #90
    geno0506
    geno0506 New Member
    Michael
    Awesome write up and video Brian, thanks! :cheers:
    If these 6112/5160's every wear out I think I'll go this route!
