DIY: Front Coilover Install - Completed with Toytec Radflo 2.5
Discussion in 'General Tundra Discussion' started by csuviper, May 4, 2017.
  1. Oct 30, 2017 at 3:37 PM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    My only concern with the way you described is if you only have one jack, is it ok to lift from one control arm, set the jack stand and then move to the other side?
    Edit, replied to early, thanks for the clarification.
  2. Oct 30, 2017 at 3:43 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    From 2012 Toyota Tundra Owners Manual
    equin likes this.
  3. Oct 30, 2017 at 5:03 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Thanks Brian. That’s not that bad at all. Ok I’m buying lol.
    @dcsleeper408 check it.
  4. Oct 30, 2017 at 5:17 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Let’s do it!
    BlueBottle likes this.
  5. Oct 30, 2017 at 5:45 PM
    csuviper
    Broomfield, CO
    Do it! Love this suspension.
  6. Oct 30, 2017 at 5:49 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Brian you just assuaged my only concerns about the 2.5's. Now if that bonus will just come in already...
    csuviper[OP] and BlueBottle like this.
  7. Oct 31, 2017 at 5:43 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    awesome, my fronts finally just shipped :)
  8. Oct 31, 2017 at 8:42 AM
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    Need profit sharing check.:pccoffee:
  9. Oct 31, 2017 at 1:07 PM
    geno0506
    geno0506 New Member
    Michael
    Almaboy,
    You can do it, I'm no mechanic! I did my install and thanks to the folks in here and google, it was pretty straight forward, trust me your balls are there, :rofl:
    Also, its so gratifying when you do it yourself and knowing it works! I figured I have 3000 miles on my front and rear suspension I did and nothing fell off yet so I'm good, lol
    I did take it to a mechanic after to have them check and retorque if needed, to be safe!
    :cheers:
  10. Dec 2, 2017 at 3:26 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  11. Dec 2, 2017 at 3:31 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    You running Camburg ball joints?
    zachzap361 and dannysmith604 like this.
  12. Dec 2, 2017 at 4:31 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yup
  13. Dec 2, 2017 at 4:41 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Camburgs. Still not sure why I didn’t do those. Or kings lol
    dcsleeper408 and BlueBottle like this.
  14. Dec 2, 2017 at 5:03 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Awesome DIY. No idea how I missed this!
  15. Dec 2, 2017 at 5:42 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Did you guys get 1 or 2 spanner wrenches? @csuviper @HBdirtbag
    Mine only came w one and it’s a pain to unlock it with 1.
    dcsleeper408 likes this.
  16. Dec 2, 2017 at 7:19 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    I only saw one in the box. I’ll look closer tomorrow and see if there’s another one.
    BlueBottle[QUOTED] likes this.
  17. Dec 2, 2017 at 7:25 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks.
    How many inches of lift are you running? Do you know how many inches of threads above the collar you have?
  18. Dec 3, 2017 at 10:37 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Just got mine yesterday, so they’re not installed yet.
  19. Dec 3, 2017 at 11:19 AM
    #49
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Ah. I’m sure you can’t wait! Did you get UCa’s? How much lift are you trying to get out of it? I wonder what the max lift recommendations are without getting coil bind on compression @ToyTec Lifts ?
    Going to try and get an alignment this week. Then I can really test it out. So far it’s smooth driving about 30 miles so far.
    Here’s how she sits right now. It’s a little less than 3” of lift I believe.
  20. Dec 3, 2017 at 11:24 AM
    #50
    zcarpenter92
    Zach
    NE Colorado
    In sig
    I’n just gonna leave em at 3”, maybe a little less if I can. Haven’t gotten UCA’s yet, hoping I can get a good enough alignment to run stock control arms for awhile. Planning on Camburg uniballs though.
  21. Dec 3, 2017 at 11:26 AM
    #51
    BlueBottle
    '16 Platinum 4x4
    See fine print
    They don’t come out of the box 3”. I think around 2”. You should be able to get alignment. I ran stock uca’s on my 3” spacer lift for 10k miles. My camber was 0 and caster was around 3*. With UCA’s you can get more caster while maintaining 0 camber.
  22. Dec 3, 2017 at 11:31 AM
    #52
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Hell thats interesting. If I can leave em at 2”, still align well and not rub too bad that’d be awesome.
  23. Dec 3, 2017 at 11:38 AM
    #53
    TheBeast The Beach
  24. Dec 3, 2017 at 11:40 AM
    #54
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    The question I have is how to get more out of the rear when I’m at 3 in the front. I want more rack, or at least leveled
  25. Dec 3, 2017 at 11:41 AM
    #55
    Eclipsed & Floating
    Voluptuous Whitey
    Will MCM build extra lift into the Deavers?
  26. Dec 3, 2017 at 11:46 AM
    #56
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I’m only running CB+3 in the rear. I have about an 1” rake I believe. You can do a combo of CB+1 and icon add a leaf if you don’t want a big shackle?
  27. Dec 3, 2017 at 11:49 AM
    #57
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Aren’t you running stock leaves plus an AAL?
  28. Dec 3, 2017 at 11:53 AM
    #58
    Eclipsed & Floating
    Voluptuous Whitey
    Yes, but my rack, try, and gear is already flattening out the stock pack plus aal
  29. Dec 3, 2017 at 11:54 AM
    #59
    Eclipsed & Floating
    Voluptuous Whitey
    I’m probably going to get the U748 pack and shackles. Will hopefully have it ready to install in a couple weeks
  30. Dec 9, 2017 at 7:25 AM
    #60
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    So I’ve got about 30-40 miles on them and am happy so far. Few things. My driver side had to be cranked down significantly more than the passenger side to get it to level out and the passenger side is still about .25” taller.
