DIY: Footwell LED install
Discussion in 'Lighting' started by csuviper, May 19, 2015.
  1. Jan 12, 2021 at 11:07 AM
    #121
    mudrunner88
    mudrunner88 New Member
    2011 Black Tundra SR5
    None Yet Just Got Her
    Parts ordered to do this. I'm going to sit and design a circuit to tie them into the door lights and switch, and then use a diode to block back feed into a 2nd circuit which would be the reostat/resistor for adjusting the instrument cluster lights when headlights are on. Not sure if I will the 2nd part will work out but sounds cool.
  2. Sep 24, 2023 at 10:14 AM
    #122
    smileytn1
    smileytn1 New Member
    Hi all ! Does anybody know or have a detailed video and wire color and location to just hook up foot well lights to work with the overhead rocker switch on a 2022 Toyota tundra 3rd gen.I have the led strips mounted and wires hanging down just need somewhere to tie in that will operate with overhead switch than has off on and door control switch. Can't find any existing wires for a socket. Tied into door lights but they wouldn't go off. All experience greatly appreciated! Thanks smileytn1
  3. Jan 12, 2024 at 8:54 PM
    #123
    bchaase
    bchaase New Member
    Daphne,Alabama
    2015 WHITE TUNDRA TRD PRO
    LOOKING FOR IDEAS
    Anyone just mirrored on the front passenger side what exists in the front passenger side ?
  4. Sep 29, 2024 at 10:43 PM
    #124
    ArcticYota
    ArcticYota Way Out Yonder
    Northern Canada
    2015 Tundra SR5 Crew Max V8 4x4
    Headlamps, interior lighting, USB upgrades
    I haven't, though I'm savvy with electronics. It would be pretty straight forward to mirror the stock bulb like on the passenger side. You can purchase sockets with wire pigtails on them. Tie that into the existing footwell light on the driver's side with some 18 gauge wire, mount it all nicely and you'd have a twin light installed. If I was going that route, I'd probably swap the drivers side for a T10 socket and put one on the passenger side as well. The stock bulb is so tiny and T10 lights are easier to find replacements for.
