DIY: Footwell LED install
Discussion in 'Lighting' started by csuviper, May 19, 2015.
  1. Feb 28, 2019 at 12:32 PM
    #91
    Pudge
    CT
    2015 Blue Ribbon Platinum
  2. Mar 1, 2019 at 6:43 AM
    #92
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    VLED Footwell Lights. No soldering, no tapping, easy peezy lemon squeezy.
    V3N0M, 20Tundra_sauce21 and Skew12 like this.
  3. Mar 24, 2019 at 11:43 PM
    #93
    dargdb2012
    dargdb2012 New Member
    2019 Midnight Black Tundra SR5 XP
    Another project on my list...
    V3N0M likes this.
  4. Jul 16, 2019 at 10:58 AM
    #94
    motocrossman99
    motocrossman99 New Member
    Josh
    2019 Barcelona Tundra SR5
    so i am planning on getting 8 of these so i can put 4 in the foot well and then 4 as running board lighting. Can the drivers side foot well light cable power all of them or should i tap into somewhere else? and if that is the case how would i make it so they come on when any door is opened? i am completely ignorant when it comes to electrical systems. i am only being ambitious with this because its just running all the positives to the one and the negatives to the other. With that in mind what is the best way to tie all the cables together? just a wire nut after i tap into the main factory drivers side footwell light or is there a better option?
    https://www.amazon.com/gp/product/B00YXBEQ52/ref=ox_sc_saved_title_4?smid=A368XWQHXB3YQO&th=1
    Edit: some research on my own leads me to conclude soldering with shrink tube is the way to go. it will provide a strong joint that is shielded with the tubing. let me know if that is incorrect thinking.
  5. Jul 16, 2019 at 8:10 PM
    #95
    NMTundra
    NMTundra New Member
    Soldering is always the most secure way to go but also the most difficult. FWIW, I've never soldered anything when wiring in a car and I've done probably 10 headunits, 7 or 8 amp and sub configurations, countless speaker installs, a backup camera and rewired 12V outlets without a failed connection. Depending on the connection point, you may have to solder though.
    I think you'd be fine with 8 off the footwell lamp, LEDs really don't pull much of a load.
  6. Jul 16, 2019 at 8:39 PM
    #96
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    I noticed the model LED's you're looking at are non-dimmable. Our interior lights run through a dimming circuit, they fade on and off. Non dimmable LED's may flicker while dimming or not fade on/off very gracefully. Not positive, not very experienced in 12v dimming circuits but something I'd look into before I installed everything.
  7. Jul 17, 2019 at 4:40 AM
    #97
    motocrossman99
    Josh
    What method have you used then just wire nuts?
  8. Jul 17, 2019 at 4:43 AM
    #98
    motocrossman99
    Josh
    Oh this is good advice. I will power one before I install them all and see how they react. If they just shut off while everything is dimming I'm fine with that but I dont want repeated flickering. I picked that one because it was waterproof and the power lines coming out of it was protected with a rubber jacket. I was concerned about the 4 that will be outside in the elements. Especially where I live the winters can be very harsh and I didn't want water and ice to destroy it my first winter season. Do you have a different LCD strip you reccommend?
  9. Jul 17, 2019 at 7:55 PM
    #99
    NMTundra
    NMTundra New Member
    Yep or crimp splices.
  10. Jul 18, 2019 at 6:09 AM
    #100
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    Look into Posi-Locks instead of plain wire nuts.
    texasrho83 likes this.
  11. Jul 18, 2019 at 6:41 AM
    #101
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This.
    Stay the hell away from the scotch-loks imo.
    rockmup and NewImprovedRon like this.
  12. Jul 18, 2019 at 6:44 AM
    #102
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Btw, I wanna add this sort of interior lighting but I wanna steer clear of the ribbon lighting. The sticky tape never holds up and should your foot accidentally brush up against it, it's hanging afterwards. Any other light suggestions?
  13. Jul 18, 2019 at 7:10 AM
    #103
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    They make them now. $7 mod, brighter? Buy 2 sets. Cut off the button switch and positap to existing footwell bulb wires. Turns on/off when you open the door. Secure with zip ties, it’ll never kick off.
    https://ebay.us/ctyimv
  14. Jul 18, 2019 at 7:14 AM
    #104
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    These are LED strips. I was kinda looking for pods I guess...sort of like rocklight pods. Something I can screw in or secure better than with sticky tape.
  15. Jul 18, 2019 at 7:34 AM
    #105
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I’d imagine pods are directional spotlights. LED strips bath light all over. The hardware can’t be seen tucked underneath unless you’re a midget walking up to an opened door, so the setup doesn’t need to be pretty, just secure.
    Depends on the lighting look you’re after. Double strips look exactly like this VLED setup.
    I just realized my passenger side is only 3M taped because there’s nothing to zip tie in that location, hasn’t fallen off over a year.
    Pudge and texasrho83 like this.
  16. Jul 18, 2019 at 7:44 AM
    #106
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Don't get me wrong, I like the light output from the strips, but I'm just concerned about the adhesive holding up to accidental foot encounters, etc.
    Ynot_tonY likes this.
  17. Jul 18, 2019 at 7:54 AM
    #107
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    Going to do this on my new tundra. But I will not use the strips. I used them on my wrangler and they were constantly getting kicked or coming loose just from the Louisiana heat.
  18. Jul 18, 2019 at 7:55 AM
    #108
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    You could always run a thin bead of clear silicone around the edges for a little extra oomf. If you keep the edges up, it shouldn't fall.
  19. Jul 18, 2019 at 8:05 AM
    #109
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This is what I’m saying. My buddy has them and he kicks them all the time. Finally pulled em
  20. Jul 18, 2019 at 8:16 AM
    #110
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Maybe it's where I installed them, have never kicked them ever, not even my less than careful kids. And it's not like I'm trying to be careful avoiding them, I move my legs/feet wherever I want.
  21. Jul 18, 2019 at 12:19 PM
    #111
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    Use 3M VHB tape. Iso alcohol to prep. It'll never come off unless you want it to.
    JoshuaA and texasrho83 like this.
  22. Jul 19, 2019 at 8:42 AM
    #112
    Pudge
    CT
    I used zip ties where I could and heavy velcro where I couldnt use zip ties. Well over a year and they have not come off
    JoshuaA likes this.
  23. Jul 21, 2019 at 5:37 PM
    #113
    motocrossman99
    Josh
    FYI anyone that is going to order the same strips i did. they do not flicker they fade in and out like the rest of the lights in the truck which is a great win. i just did a test today i plan on installing them all next weekend. i will post pics then.
  24. Jul 21, 2019 at 6:22 PM
    #114
    JimboSlice413
    Bakersfield
    Nice, I might pick these up for my footwells. I miss having indirect lighting like my old Buick had. Its nice to have interior light at night that isn't right in your face.
  25. Jul 22, 2019 at 7:38 AM
    #115
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did you get the cool white? Is it pure white?
  26. Jul 22, 2019 at 7:42 AM
    #116
    motocrossman99
    Josh
    no i got red. i was between white and red and my wife said red so i went with it.
  27. Dec 18, 2019 at 1:08 PM
    #117
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    Plan to do this soon, wondering what you all used to secure to the rear of the front seat? I seen two posts about Velcro, anyone else have any other options?
  28. Dec 23, 2019 at 4:43 PM
    #118
    Rebel Tundra Man
    Tyler
    Western Kentucky
  29. Nov 26, 2020 at 6:09 PM
    #119
    SouthWestGA
    SouthWestGA New Member
    Tagged for later!
  30. Nov 26, 2020 at 7:07 PM
    #120
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    There were no kits available that I knew of at the time I did this. Now I would just go with a kit honestly.
    WFD473 likes this.
