DIY: Footwell LED install
Discussion in 'Lighting' started by csuviper, May 19, 2015.
  1. Dec 10, 2016 at 3:07 PM
    #61
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Ron, it was so dim I was almost looking at it scratching my head as to it's location. lol
  2. Dec 10, 2016 at 7:38 PM
    #62
    Ericsopa
    Ericsopa Old man and the sea
    Oh my.....that's a light?!? LOL Had to wait till night to find it. But you're right...there's this tiny little thing that seems to have a sole purpose of lighting the parking brake pedal. All righty, I can fix that!!
  3. Dec 11, 2016 at 5:29 AM
    #63
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I know, right?!
  4. Dec 24, 2016 at 10:26 AM
    #64
    Crusty
    Crusty New Member
    '12 Plat and '15 1794
    Are y'all pig tailing all four sets thru the small drivers foot well light? ( driver, front pax and the two back seats). My wife's 15 1794 does not have a front pax foot well light.
  5. Dec 24, 2016 at 11:12 AM
    #65
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Ok here is the light in comparison with a pea.
    Sunnier, TomC843, TheBeast and 3 others like this.
  6. Dec 24, 2016 at 5:42 PM
    #66
    Crusty
    Crusty New Member
    I checked her 1794. No pax footwell light. Thank you.
    NewImprovedRon likes this.
  7. Sep 22, 2017 at 2:32 PM
    #67
    TwoMoreChains
    TwoMoreChains New Member
    2014 MGM Crewmax TRD OR
    definitely next on my list thank you!
  8. Oct 26, 2017 at 11:05 AM
    #68
    ScottsBad
    ScottsBad New Member
    Scott
    Free Idaho, escaped Commiefornian
    2018 TRD Limited
    Just a Bed Rug, Soft Topper, Console Safe
    I'm thinking of putting a light in the center console as well. Would like it to turn on when opened. I'll have to think about what type of switch to employ.
  9. Oct 26, 2017 at 12:28 PM
    #69
    csuviper
    Broomfield, CO
    Hood pin switch style for the glove box
  10. Oct 26, 2017 at 1:10 PM
    #70
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I used the metal arm that is attached to the lid to ground the 2 led strips negative wire and the positive to a constant 12v source (my always on Dual USB charger).
  11. Jun 5, 2018 at 5:12 PM
    #71
    Gryphon1721
    Gryphon1721 New Member
    2012 Tundra TSS
    Ok so I’m late to the tundra game...just got one a month ago and I just tried installing the led strips I couldn’t get them to come on....I tested the lights after soldering on some wires and they came in but when I connected it in the truck it didn’t work any suggestions?
  12. Jun 5, 2018 at 5:24 PM
    #72
    csuviper
    Broomfield, CO
    Try switching polarity
  13. Jun 5, 2018 at 8:12 PM
    #73
    Gryphon1721
    2012 Tundra TSS
    I tried that as well and got nothing
  14. Jun 18, 2018 at 2:25 PM
    #74
    Gryphon1721
    2012 Tundra TSS
    Found my issue....solder ran together and caused it to ground out
  15. Aug 16, 2018 at 1:45 PM
    #75
    Leslatimer
    Leslatimer New Member
    Les
    2007 tundra limited
    Stereo, cold air intake, leveling kit, 35" tires
    Had them in 2 of my camaros. Cobalt blue. Had it set up so u can do it with doors, on all the time, or off all the time. Really cool look. My tundra has all lights inside changed 2 blue left's. Haven't done strips under dash or back seats yet. If I did do it does anybody know if I should also put under rear seats as well 2 give whole inside an even lighting?
  16. Sep 14, 2018 at 5:49 PM
    #76
    KJB84
    KJB84 New Member
    Kyle
    I don't have a footwell light in my SR, but want to add this mod. Where is the best place to find wires to tap into?
  17. Sep 14, 2018 at 6:10 PM
    #77
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  18. Sep 14, 2018 at 6:59 PM
    #78
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The cargo light wire. Its found on the drivers side, under that black trim in the doorway. I think its called the scuff plate. Wire color differs from year to year I believe.
    Lights will come in when truck is unlocked with remote, when door is open, or when cargo light is switched on. This is what I did based on recommendation from @NewImprovedRon
  19. Sep 14, 2018 at 7:02 PM
    #79
    Pudge
    CT
    My pic is in previous post ^^^^^ those lights are mounted under the front seats facing backwards. Works well, theres no good place under rear seats to mount. Lights for front are mounted under the dash
  20. Sep 14, 2018 at 7:03 PM
    #80
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    That's awesome!
    Pudge[QUOTED] likes this.
  21. Sep 14, 2018 at 7:07 PM
    #81
    Pudge
    CT
    Thanks man, I like them. Wasnt too bad to do and cheap too. Somewhere I posted here when I did it and what I used. Forgot where though
  22. Sep 14, 2018 at 7:28 PM
    #82
    saybng
    Gary
    Ventura CA
    Well you better find it cuzzz ima do it..lol
    NewImprovedRon and Pudge[QUOTED] like this.
  23. Sep 14, 2018 at 7:31 PM
    #83
    Pudge
    CT
    I shall search now
  24. Sep 14, 2018 at 7:50 PM
    #84
    Pudge
    CT
  25. Sep 14, 2018 at 8:48 PM
    #85
    Pudge
    CT
    @TundraTex to remove the piece below the hvac controls, where you recommend placing frac switches on the ledge on platinums, do I just pull the shifter surround, then the trim that goes from center console arm rest area? Then I can get to that "ledge" piece? I wanna stick an LED bolt light there to illuminate my front most cupholder/usb aux port area. That part of the video with @4x4_Angel goes pretty quick and I dont wanna miss something.
  26. Sep 16, 2018 at 8:09 AM
    #86
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    You can remove it with just the shifter removed, but the cup holder and center console top are also just clipped in and removing those will give you a little better access. A curved panel removal tool to assist, will help either way.
  27. Sep 16, 2018 at 12:16 PM
    #87
    Pudge
    CT
    Thank you sir!
  28. Feb 28, 2019 at 11:32 AM
    #88
    ctdomain
    ctdomain Expeditioner
    Clint
    2019 Limited Quicksand Tundra
    Suspension: ADS Front C/O's w/adjusters, ADS Piggyback rears, Toytec Shackles, Icon Rebound 17in wheels +25 offset, 35x12.50xr17 Nitto Ridge Grapplers. Miscellaneous: Tech 12 volts remote start, Tyger side steps, Color matched pro grille & bulge, Black handles off of SR5 Tundra
    For those of you who are able to put these lights where you can switch them on and off even while driving, how are you doing it? I understand attaching them to the well light on drivers side will make them come on when door is open, but I would like to be able to run them while i'm driving as well. @Leslatimer
  29. Feb 28, 2019 at 11:47 AM
    #89
    Pudge
    CT
    Attach them to the cargo lamp wire instead if the footwell. That way you can turn them on. Just be aware the cargo light will also come on.
    The dome wire would be the best solution for you but no one seems to be able to find that wire to tap into. Your other option would be hard wiring from an add a fuse and adding a switch
  30. Feb 28, 2019 at 12:24 PM
    #90
    ctdomain
    Clint
    When you say hardwire, you mean coming straight from the battery? Sorry I'm pretty noob when it comes to electricity, I have a light understanding at best (no pun intended lol).
