DIY: Fog Light Mod
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, Mar 13, 2014.
  1. Apr 27, 2023 at 11:19 AM
    #181
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
  2. May 13, 2023 at 6:31 PM
    #182
    nikatnite79
    nikatnite79 New Member
    David
    2016 Tundra Limited
    None
    Has anyone done this WITHOUT the headlight switch having to be on at all? I bought some aftermarket headlights and the driving lights dim when I turn the switch on in any way. I had the simple ground to body mod but I still have to have the switch on the headlight which dims my driving lights and annoys me because I want the full brightness of the driving lights and the fog lights on. Anyone!?
  3. May 14, 2023 at 7:42 AM
    #183
    KeepOnTruckin
    Randy
    I don't have DRL nor the OEM stalk, ran a switch to wire bypassing the body control module.
    Look here. It's on anytime the lights are on any setting, and the new switch is on.
    https://www.tundras.com/threads/electrical-mods-fog-install-and-led-flasher.122423/
  4. Nov 26, 2023 at 7:46 AM
    #184
    Yota 4x4
    Yota 4x4 New Member
    2010 sequoia 4x4 96 Tacoma 4x4
    Hey I'm new here, hope this is the right thread. I got diode dynamics ss3 pro fog lights ordered and want to use them with my high beams, which mod should I use? 2010 sequoia limited. Any help would be greatly appreciated thanks.
  5. Dec 3, 2023 at 7:46 PM
    #185
    Lotsaspider337
    Lotsaspider337 New Member
    Scott
    2017 inferno orange CM 4x4
    Exhaust led bar
    Does this work on a 2017?
  6. Feb 17, 2024 at 12:49 PM
    #186
    Zcoq
    Zcoq New Member
    Pennsylvania
    2011 Rock Warrior Crewmax
    For those of you who have done this mod and live in a state like mine where fogs are required to turn OFF with HIGH beams in order to pass vehicle inspection: do you have to remove the mod before having your truck inspected, or do you just 'know a guy' that will pass it anyway?
    I've been looking at these various fog light behavior mods and have been trying to come up with a way to enable them (with stock fog light switch) when parking lights are on, but turning off for high beams. The best way that I can see to do this is possibly using an existing mod method (E.g. "Eddie's") and then adding another relay to disable the mod when the high beams are active.
    Anyone have any thoughts on this?
  7. Sep 21, 2024 at 9:46 AM
    #187
    Y2K_Tundra
    Y2K_Tundra New Member
    2000 White SR5 2WD Access Cab
    Any chance this will work of a 2000 Tundra SR5? Sorry if this is a duplicate question. Just read the first page of replies. LMK. Thanks!
  8. May 15, 2025 at 8:06 PM
    #188
    Watson918
    Watson918 New Member
    Mathew
    2000 tundra SR5
    I have a 2000 tundra. Will it have the same wiring as the one shown in the diagram. Mine is doing the same thing as the 2007 they are talking about after I added the LED bulbs.
