DIY: Fog Light Mod
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, Mar 13, 2014.
  1. Apr 7, 2019 at 7:26 AM
    #91
    11SilverPlatinum
    11SilverPlatinum New Member
    Dave
    2011 Platinum Tundra
    Plastidip emblems, Pace Edward bed cover w/lumber rack, remote start, TRD intake and exhaust, TRD front and rear sway bars, color match grill surround, LED headlight upgrade.
    I have a 2011 and did this mod a few months ago - my auto off function still works. I'm glad I didn't lose that feature when I did it, I'm with you, I use that feature all the time. :eek2: Hope you get it figured out.
  2. Apr 7, 2019 at 9:14 AM
    #92
    tundra123456789
    tundra123456789 New Member
    Hmm, I didn't specify in my post that I did the eddieV1 mod. Which did you use? Maybe I could get that functionality back.
  3. Apr 7, 2019 at 1:12 PM
    #93
    Dr_Al
    Dr_Al New Member
    Al
    You know if you combine the two mods with a slight change you can make it so the fog light switch works either all the time or when the key is in either the acc or on position. After doing the mod to the wire harness if you pull the fog light relay and bend the lower right pin (not lower left in the picture) so you can put a wire on it you can bypass the relay connected to the taillights. You just need to run a wire to from that pin to the power of your choice.
  4. Apr 7, 2019 at 2:41 PM
    #94
    11SilverPlatinum
    Dave
    I used this one: FogLightsEddieV1. Worked great!
  5. Apr 7, 2019 at 6:50 PM
    #95
    tundra123456789
    Apparently I was a little tired when I finished this mod after work. I went for a drive today and left my lights on like usual when I parked; my headlights turned themselves off after a little while. :bananadance: Awesome write ups on this stuff to the OPs! :oldglory: THANKS!
  6. May 22, 2019 at 10:08 AM
    #96
    Brocksw
    Brocksw New Member
    Spruce Mica 2012 SR5 Off-road DC
    Elka 2.5 reservoir front(+3") and rear, JBA UCAs, toytec +1.5" shackle, Falken Wildpeak 285/75r18.
    so regardless of the way you do this mod, you lose the switch on the column (blinker side) and have to use a new button? Or am I misunderstanding this?
  7. May 22, 2019 at 10:22 AM
    #97
    ccress83
    ccress83 Be A Good Human
    Colin
    Cleveland Ohio
    2011 Tundra CM TRD Off-Road Limited
    AFE Dry Drop in Filter, Morimoto XB LED Fogs , LED Taillights, Morimoto D2S retro w/profile HI-Lens LED Brights, 3/1 LRO Level, Dirty Deeds 8', TRD Rear Sway Bar,
    This is how I did my fog light on all the time mod. Fog light switch is pretty much disabled and they will not be on in "auto" mode. No cutting, no digging in the dash and no bending tabs. Made little extension wires, plugged those into the proper plugs as if the relay was plugged in and then grounded the one wire.
    AbunaiTaco likes this.
  8. May 22, 2019 at 10:24 AM
    #98
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Interesting why the extensions tho? Never seen any 1 do this and the relay fits just fine back in place
  9. May 22, 2019 at 10:28 AM
    #99
    ccress83
    Colin
    Cleveland Ohio
    Didnt want to bend any tabs on the relay. I found this way to work on the tacoma forums which I did when I had my taco. Tried it on the tundra and it worked also.
  10. May 22, 2019 at 10:30 AM
    #100
    fisherman951
    Tony
    2017 crewmax 4x4
    Got it.
  11. May 22, 2019 at 10:31 AM
    #101
    Brocksw
    Brocksw New Member
    Which method (if any) allows me to use the factory fog light on/off switch to turn the fogs on anytime and not have to run a new button? Also, I'd like to cut the wire to turn off the daytime running lights, will that affect these mods?
  12. May 22, 2019 at 10:33 AM
    #102
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    is there still enough space to put on the fuse box cover?
  13. May 22, 2019 at 10:46 AM
    #103
    ccress83
    Colin
    Cleveland Ohio
    Yup, mine goes back on no problem. Like I said before, you lose your switch function inside. Fog lights are on with parking/headlights on/brights. Off when headlights are off and in "auto" mode if you have it. And they obviously shut off when the truck is off. I should also post that I have a 2011. Not sure if it makes a difference with the newer trucks.
  14. May 22, 2019 at 10:50 AM
    #104
    Brocksw
    Brocksw New Member
    so you cant turn your fogs off then when your headlights/brights/parking lights are on?
  15. May 22, 2019 at 10:53 AM
    #105
    ccress83
    Colin
    Cleveland Ohio
    No, keeps them on all the time.
  16. May 22, 2019 at 11:03 AM
    #106
    fisherman951
    Tony
    2017 crewmax 4x4
    Same thing on my 17
  17. May 22, 2019 at 3:29 PM
    #107
    Dr_Al
    Dr_Al New Member
    Al
    The mod where you cut/ splice the wires under the steering wheel. Your switch will still function but to have the fog lights come on you will have to have your parking lights on as well. The relay mod is for just having them all the time. You can do a variation of the relay mod and combine it with the dash wires mod so the fog lights come on even if the parking lights are off.
    Brocksw[QUOTED] likes this.
  18. Jul 11, 2019 at 3:22 AM
    #108
    GreyGhost15
    GreyGhost15 New Member
    2015 MGM TUNDRA SR5 CREWMAX 4X4
    https://www.tundras.com/threads/big-easy-build.66540/#post-1731305
    I just did the EddieV1 on 2015. should have came this way from factory!
  19. Aug 14, 2019 at 11:53 AM
    #109
    rvrats2
    rvrats2 Too Often Yankees Overprice This Auto
    Carbondalé, CO
    2011 SR5. Bench Seat!
    Finally cut some wires! I don’t like cutting wires, scared me! But it’s all working.
    So...what’s the baby light under the dash? I can’t get it to turn on, looks to be wired factory. Bulb itself doesn’t appear to be burned out. Don’t really feel like taking the panel off again for a wiring pic, but I can. 9027700D-A6EB-4424-9B70-DA080914B44F.jpg5ABE9BAA-3B39-4F4F-BBCB-3AE6A2954F80.jpg
  20. Aug 14, 2019 at 1:12 PM
    #110
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    That’s your courtesy footwell lamp. It should come on with your other interior lights (dome, lower door lights) when you open door and fade off after 15 seconds (or however long)....
    rvrats2[QUOTED] likes this.
  21. Aug 14, 2019 at 3:27 PM
    #111
    rvrats2
    Carbondalé, CO
    Thanks, I’ll see if I can find a replacement light that works!
  22. Aug 14, 2019 at 3:38 PM
    #112
    Ericsopa
    Ericsopa Old man and the sea
  23. Aug 14, 2019 at 4:19 PM
    #113
    Jrharvey02
    Consider an led upgrade while you’re doing this. There’s write ups on bulbs etc, I did this a while back but can’t remember where I got the bulb. All the other interior bulbs in your cab are able to be simply swapped out with led, this pesky little guy is the only one you have to wire in as it’s wired “in line”.
  24. Aug 26, 2019 at 2:26 PM
    #114
    joseph_sal
    joseph_sal New Member
    Joseph
    Memphis TN
    2000 Toyota Tundra 4WD SR5
    csuviper Do you know if the Eddie V1 works on 1st Gen (2000 Tundra)?
  25. Sep 25, 2019 at 11:54 PM
    #115
    Comtech
    Comtech New Member
    Dave
    2007 Crewmax 5.7. heavily modded
    ToyTech lift, 35” Toyo, SAR radio, Red/white wig wags, Spyder Halos, rear cam with manual switch, power camper locks, Firestone air bags, P3 Tekonsha brake control in dash, Baja Design Squadron Pro fog kit, Kenwood 8”:touch screen sat/ bar in nav, bazooka sub, fog light anytime with Orem switch mod. a/c power inverter, Safari roof rack on Leer matching shell with Led interior lights. Accessory 20amp outlet in bed.
    I have replaced my OEM fogs with Baja Designs Tundra fog kit w/ the Squadron Pro driving /flood combo OPTION. Very solid bezel holds them snug and they are just under 5k lumens each side. Outperforms the high beams easily. Driving the remote deer, elk, moose, bear laden highways of western Wyoming is now much more pleasant.....NOT DOT approved but I just kick em off with traffic just as I do my brights!
    NewImprovedRon likes this.
  26. Oct 22, 2019 at 11:37 PM
    #116
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    This is badass.
    Anyone tried this on a 2014+, that has also done the 2018 LED headlight upgrade?
  27. Nov 2, 2019 at 2:29 PM
    #117
    Scotticus
    Scotticus New Member
    I just tried the original mod of running the wire from connectors on my 07 tundra and now my battery is running on lower volts and my truck dies if it sits still too long. What would cause this? I put everything back the way it was and I guess the damage is done because it is still doing it.
  28. Nov 10, 2019 at 7:07 PM
    #118
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    Saw the thread last week and knocked it out today...super easy would have done it a long time ago had i known.
  29. Jan 26, 2020 at 10:32 AM
    #119
    Bschick
    Bschick New Member
    2013 Tundra
    in the video that says fog light mod 2012 Toyota tundra does anybody know what switch the guy used... Sorry I know this is an old Post
  30. Mar 25, 2020 at 4:59 PM
    #120
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    I have had the Eddie V1 done on my 2017 for several years. Working fine but now I no longer have a fog light indicator on my instrument panel. I am wondering if it was something else I did or does this mod make the indicator not work?
