DIY: Fog Light Mod
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, Mar 13, 2014.
  1. Dec 23, 2017 at 6:45 AM
    #61
    Bleakbn
    Bleakbn New Member
    2018 Tundra SR5 CrewMax TRD 4x4
    I would be very grateful if someone provided updated instructions (with detailed photos) for the 2018 model. I applied the mod to my 2012 years ago and I really miss it on my new truck. However, I’m not comfortable with experimenting/guessing on a brand new truck!
  2. Dec 30, 2017 at 8:19 PM
    #62
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Scribed....
  3. Jan 20, 2018 at 5:22 PM
    #63
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    does anyone have an image of the AJ10 (grey)connector and the pin position for a 3rd gen tundra. (using the attached Eddie's v1 doc) I can't seem to locate the correct wire.
    edit
    figured it out for anyone doing this mod in the future you want the top left grey wire on the grey connector.
  4. Apr 14, 2018 at 1:23 PM
    #64
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    So you just depin or cut that grey wire and this allows the fogs to turn on with Parkin lights, low beams, and high beams, using the stock switch?
  5. Apr 14, 2018 at 1:59 PM
    #65
    mtTundra
    mtTundra New Member
    Bozeman MT
    you need to add a jumper wire between the pink and grey wires. all the details are in this thread. yes it allows you to turn on the fog lights with high beams and running lights
  6. Apr 14, 2018 at 2:30 PM
    #66
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    There's several pdf's and links which one is it? Lol
  7. Apr 14, 2018 at 3:23 PM
    #67
    mtTundra
    mtTundra New Member
    Bozeman MT
    I did the fog lights eddie v1. it's the 1st pdf* on the first post of this thread.
    NewImprovedRon likes this.
  8. Apr 14, 2018 at 3:27 PM
    #68
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Their is also the other way of doint it. Find the relay bend a pin and run a ground to that bent pin. Incase some 1 not wanting to cut the harness
  9. Apr 18, 2018 at 1:18 PM
    #69
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Do you have a pic of this way kind sir?
  10. Apr 18, 2018 at 3:14 PM
    #70
    fisherman951
    Tony
    2017 crewmax 4x4
    @xtyfighterx has a thread on it. Its called 5min fog mod look him up
    xtyfighterx and OBXTundra like this.
  11. Apr 18, 2018 at 3:17 PM
    #71
    seniramsu
    Nate
    VA
    Good deal. Thanks
    xtyfighterx likes this.
  12. Apr 18, 2018 at 4:42 PM
    #72
    seniramsu
    Nate
    VA
    Just did that 5min one.... BAMCIS!!!! Fogs are operating!!!
  13. Apr 18, 2018 at 4:45 PM
    #73
    fisherman951
    Tony
    2017 crewmax 4x4
    Easy peasy haha way to go
  14. Apr 19, 2018 at 6:25 PM
    #74
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Thanks for the tag! Glad it worked
    SkipMGMXPSeries likes this.
  15. Apr 28, 2018 at 6:39 AM
    #75
    TTund16
    TTund16 New Member
    Thank you @mtTundra and everyone else!
    mtTundra is correct about AJ10 being in a different location for the 2016 model.
    Just adding a little bit more info for the next person ...
    in my 2016, there are 2 grey connectors under the kick panel.
    Both connectors are kind of hidden behind bunch of wire harness.
    One grey connector is on the top left (horizontal and has thicker wires)
    just under it to the right there is a 2nd grey connector (vertical and has thinner wires).
    This is the one that mtTundra has a picture of (refer to his post above) and this is the connector you want as he has pointed out.
    It works and if you can do it under 1 hour (as someone has mentioned in this thread or one of the other threads), you are a genius! :yes:
    I ain't one! lol
    Thanks again everyone!
  16. May 20, 2018 at 12:00 PM
    #76
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  17. May 20, 2018 at 5:23 PM
    #77
    Punisher17
    Punisher17 New Member
    I got these for my 2007 crewmax. They're the smoked OEM style. I bought a cheap replacement chrome front bumper on Amazon and the tabs don't fit right but I zip tied it up pretty good so for the price it looks pretty nice. What is a good stock replacement bulb for these that is brighter than stock? I've heard people put 9005 high beam bulbs in them but I would be afraid of them melting and if they didn't have melting problems would be afraid of getting pulled over or causing an accident so wouldn't put them in anyway.20180520_172021.jpg
  18. Jul 31, 2018 at 7:49 PM
    #78
    angryhawaiian
    angryhawaiian New Member
    05 Double Cab Tundra SR5
    The wires for my 05 do not look like any pictures in the eddie v1. Please help.
  19. Aug 2, 2018 at 3:13 AM
    #79
    TTund16
    TTund16 New Member
    Check page 1 of this thread. There are a few links for different year Tundras.
    I recall references to older Tundras either from page 1 links (buried within posts) or somewhere else. I think fog light any time (page 1) maybe more universal and may apply to most Tundras.
  20. Sep 11, 2018 at 1:04 PM
    #80
    Ikonrat
    Ikonrat New Member
    2018 MGM DC TRD OFF ROAD
    Thanks for the great thread. I have a 2018 DC and upon looking at my wiring, it does not match previous year trucks. has anyone attempted the "always on fogs" for 2018 via pink/gray jumper lower dash/kick panel method? I'd like to retain factory switch. If all else fails, I'll go the route of 5 min relay ground method until there's a confirmed technique for the 18's. Pics attached of my setup...
    Under Kick Plate:
    Under Lower Dash:
    AbunaiTaco likes this.
  21. Sep 12, 2018 at 1:34 AM
    #81
    TTund16
    TTund16 New Member
    @Ikonrat
    Read my post #76 above.
    from your pictutes, looks like the wiring in your truck is same as my 2016 DC. I have the same 2 grey connectors as in your picture.
  22. Sep 12, 2018 at 7:24 AM
    #82
    Ikonrat
    Ikonrat New Member
    Close up pic of the connector under the kick panel. Instead of the gray wire on the gray connector, mine is white with black stripe. Also, the lower dash plugs all look totally different from earlier years.
  23. Sep 12, 2018 at 8:55 AM
    #83
    xtyfighterx
    Ty
    North Idaho
    Use the relay method easier faster basically the same outcome. Fogs come on with parking lights and shut off when they do.
  24. Sep 12, 2018 at 8:57 AM
    #84
    xtyfighterx
    Ty
    North Idaho
  25. Dec 1, 2018 at 2:57 PM
    #85
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Bump.
    Did the foglightsEddieV1 today. Most excellent!!! Thank you to everyone that contributed.
  26. Dec 11, 2018 at 6:04 PM
    #86
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Trying to get the exact process for 2017 CM.
    I don't really want the fog lights on all the time, but would like them to stay on when I flip on the brights.
  27. Jan 28, 2019 at 11:19 AM
    #87
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Hi guys was trying to do the mod this morning and cut the wrong pink wire now I know it’s the pink under the steering wheel now..Wanna make sure I’m doing it right so I can just depin the pink and gray wire then tap it together right? Thanks guys wanan do it right this time.
  28. Mar 3, 2019 at 1:39 PM
    #88
    Jrfor0
    Jrfor0 New Member
    James
    FWIW, I tried the attached FodLightsEddieV1.pdf fog light mod today and with the help of posts 64 and 76 it worked like a charm on my 2015 Limited. I altered the guidance a little bit and instead of cutting the wires, I removed the pink/gray pins from the associated plastic connectors and connect the pink/gray pined wires to each other using a jumper wire. This way it should be easier to go back to stock if needed.
    Dual Rider and tinman10101 like this.
  29. Mar 10, 2019 at 8:10 PM
    #89
    Dual Rider
    Dual Rider New Member
    Ken
    Portland, OR
    2014 MGM Limited Crew Max
    Bilstein 6112 2" level in the front, black Fuel wheels, 285/70R 18 Nitto Exo Grappler tires, BakFlip Tonneau cover, N-Fab nerf steps, Undercover Swing Case, Line-X bed liner, console safe, 2018 TRD Sport grill with color matched MGM surround and hood bulge, and more...
    Thank you Jrfor0 and everyone, I just did the same thing on my 2014 Limited and it worked great! I depinned the connectors as well avoiding having to cut any wires. Thanks for the tip!
  30. Apr 6, 2019 at 10:42 PM
    #90
    tundra123456789
    tundra123456789 New Member
    Just did this mod on a 2011 and it worked great! Only problem is lights no longer turn off automatically, which I enjoyed using. Going to see if I can keep the mod while bringing back auto off function by incorporating a new relay.
