DIY: Fiberglass Eyelids
Discussion in 'General Tundra Discussion' started by boardude, Aug 7, 2016.
  1. Aug 7, 2016 at 3:42 PM
    boardude
    boardude [OP] I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I couldn't really find anyone who made eyelids for the 2014+ Tundras and I didn't want to slap a vinyl on the headlight so I just made my own fiberglass eyelids. Below are the steps that I took to make these. But first the fine print....
    Disclaimer: As any DIY, this thread is not telling you how to make perfect fiberglass eyelids rather I am just sharing how I made mine. If you attempt the mod and f*ck up something I am not responsible for anything.
    And now to the DIY. Feel free to PM me if you have any questions or need any help. The resulting product below was actually my second attempt so many lessons learned lol.
    The tools and products I used were:
    - Beer
    - 3M Painters Tape
    - Mold Release Agent
    - Fiberglass cloth and resin
    - Beer
    - Mixing stick
    - Bondo glaze and filler
    - 3M double sided tape
    - Several cheap paint brushes (you will most likely toss these when you are done). Not too cheap where the bristles pull. Otherwise you will be picking these out of the resin lol
    - Flat head screw driver
    - 10mm socket wrench/ratchet
    - Beer
    - Patience
    - lacquer thinner
    - Gloves if you don't want sticky hands for 2 days
    - Beer
    - Rattle can primer (your choice)
    - Final paint and clear coat. I used color match from automotivetouchup.com
    c4Qj-3mMwlaeZw3PFRFcBvtyE_r4zcL_leSzKvKG_5f1eaa02af56e19e3ba039252c594d0bbe9d7286.jpg
    First I removed the grill and panels under the headlights then removed the three bolts for each headlight and pulled them out.
    tp1nKD7WgkEduYPPc67x2wMhr3T1XRlT7Q4QanxY_434feb8ecdbed74f30c9cf703259ce3c20b9b488.jpg
    I cleaned and taped off the entire front of the headlight with 3M painters tape
    KQ9nMkTZssZuyPAFlpuTqaLJk-5GNeKTlOA_s9rz_7f3769a6259e5bb2218c1a2a0de883476fcf528e.jpg
    Next I took a sharpie and outlined the shape of the eyelid I wanted. This outline was not intended to be the final shape but more to make sure that I cover the entire area with resin.
    ELwv6Ul2m194wZsJgi8LdUYl2vu_G3XbHTYQqPdS_6d9b4f6f077376974df69da014a28e8b73225bf4.jpg
    I made sure the entire area within the outline was completely smooth with no creases or folds in the tape because the cloth will inherit all of these when the resin is applied and dried which means more work in the end sanding these out.
    UQXPqKgMrZR9_umkf-iKQfoj1eiOHr0-PKMIJsRf_8ebeb4c3fa1602a644fefc7f481ac0e6f41024eb.jpg
    Applied the mold release agent on the headlights in the outlined area and a couple inches past that as well.
    rrV1qOrKPx32Nlv7ylktyq1DfURSkWXGB-tdbNTt_dde8209f3ad242f5d54e55194fa0396229bc8385.jpg
    I cut 4 pieces of fiberglass cloth (2 for each side) large enough to cover the outlined area.
    Uobvo6b26Kor_THokpyUCeOB-Sz2M0WpcQEklVN2_1b6efb99ec94f9b3b817ce8279824c6269426aba.jpg
    About 15 mins after applying the mold release agent I mixed up a batch of resin. I only mixed enough to apply the first cloth on both headlights. Then I began to brush the resin on the cloths starting from the middle and working my way out to the edges. I used my outline as a guide to know where to apply.
    0JNZUZdjQR8PxOvMO8lKDTbX6a-skoy4LE6-0xw0_0d3a23f65884d3114ef8724db09185052869ce33.jpg
    After 5 mins of the first cloth I mixed another small batch of resin and applied the second cloth using the same method. I smoothed out all air bubbles and made sure there was no separation between the two cloths. After another 5 mins I made a third batch of resin and caked it on. I did this to make them more solid and also when they cure and it comes time for sanding, its easier to sand and smooth the resin then the actual fiberglass.
    vrTvczasvoLnCGaZdEgx1sqSzQEgW0ZSic_zqEbF_7c30e7b562276b0a81e00444faf60663f8b3fbbf.jpg
    Gave it about 3 hours to dry and they were ready to be removed. I took a sharpie and traced the outline on the fiberglass as a guide to wear to cut.
    I slowly used a flat head and started to peel the edges of the eyelids off the headlights. Once the edges were clear I stuck the entire flat head down the middle and the whole thing popped right off.
    XZMohEmDk55h8-i6mJIf7JZsYP8h84P6EJ9CMZ8p_9ba46e2232e974f43be42ce30b550db854974bd4.jpg
    I cut the excess cloth off and used a dremel to cut close to my outline. Then I started sizing up the eyelid on the headlight to determine where to cut for my final shape. I did this in small sections of cutting then sanding.
    OfYoyOx88CZscGMEkPPcYX8-5AZf3YLAGMHDGHdB_f66d68db40042848b74a8f9f8c4db6ec64d3eabf.jpg
    This was the most time consuming part as its easy to make a wrong cut. Plus I am super anal about everything having to be level and lined up so I might have gone overkill on a few spots lol. But in the end I think it paid off:
    PFkmql5MQUnvXmfEeZIb05-COBbi97vb2aWFTi8r_a480ac7306b81cbcf30ae1a8fca8b342b40c3ab6.jpg
    Once I had the final shape I hit it with 150 grit, then 220 and then 400 sandpaper. I sprayed a few coats of white primer on the eyelids:
    -ftfP_ma6N92xmlwnrNgI_jVS_FZZA_0JLxJTWBZ_cf67a98c95028935819074dc0e7199a3ff80bd7c.jpg
    After a few hours I then hit them again with 220 paper. This was to reveal the high and low spots of the fiberglass. The white patches were the low spots which some were filled with the primer. For the spots that need more filler I marked with a sharpie and then used bondo glaze and filler. Once the filler was dry 20 mins later I hit it with 400 to smooth the filler and repeated where necessary
    AQ3LmGv-kOBe49B5M3TMeHO5Z9JTPOamonU9OKPW_c3c2d31c8d8bb39a0e78e53d6e394468045a9508.jpg
    Once I was happy with the shape and smoothness I hit it with several coats of primer, wet sanded with 400 paper, applied the color matching paint and clear coats:
    vccZbLDXEb_58pClL8i3D0MadclXAvhcjjfXcAW7_5f5c285e5e1db2fa058d535fbe1d1d4db1bb5936.jpg
    Used 3M double sided tape to secure to the headlights and..... Whammy!!
    nz9-RbVNQ7zhdOD8w4YxaKARG48c4vuXO8vvGIXq_21baf3d484d6e5dd401a8a60b2f969100aa4c342.jpg
    Z2DddeWj91WQRlA4p_gI1_2adtD3I7rT2gH9M2Mq_fe041909c4dba68502d7a990c3c2f2d74682656c.jpg
  2. Aug 7, 2016 at 3:49 PM
    Nicely done man!! Added to the DIY sticky.
    PureTundra, Bob and boardude[OP] like this.
  3. Aug 7, 2016 at 3:51 PM
    mudsweatngearz
    mudsweatngearz New Member
    Grant
    Arizona
    2016 Limited TRD CM 2016, Tacoma TRD Sport, 2005 Tacoma TRD Sport
    Window tint
    Wow! great write up. You are very talented. Is there a practical use for doing this or is it for looks? Still trying to decide if I like it looks wise, could grow on me.
    Practically it may help keep UV clouding at bay some.
    PureTundra, T-Rex266 and boardude[OP] like this.
  4. Aug 7, 2016 at 4:09 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Thank you sir! It's all for looks really. I really liked them on my Taco and wanted some for the Tundra. I like the way the eyelids follow the contours of the fender and grill
  5. Aug 7, 2016 at 4:10 PM
    mudsweatngearz
    Grant
    Arizona
    Window tint
    I will say you really do live up to your screen name tho.....LMAO
    boardude[QUOTED][OP] likes this.
  6. Aug 7, 2016 at 4:17 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Nicely done, came out great
    (And good work on that detailed write up)
  7. Aug 7, 2016 at 4:20 PM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    What kind of beer works the best for this project? Lol
    KrazieZ and T-Rex266 like this.
  8. Aug 7, 2016 at 4:36 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Gracias!
    I started with a couple blondes during the fiberglass and resin stage but quickly moved to IPAs when I got to the shaping and sanding part lol.
    T-Rex266 likes this.
  9. Aug 7, 2016 at 4:40 PM
    frogger
    frogger just boost it
    Stephen
    Louisville Ky
    2008 S/C Tim Mica SR5 5.7L DC 4X4
    too much to list
    Nice work...looks great
  10. Aug 7, 2016 at 7:03 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    They look great! I have always wanted to try to mess with fiberglass, maybe someday I will give it a try.
    Great write up. Thanks for sharing.
    I dare you to make some color matched fiberglass fillers for your front bumper......
    Double dog!
    boardude[OP] likes this.
  11. Aug 7, 2016 at 7:35 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    You had to pull the double dog lol! That kinda fiberglass work might be out of my skill set, but I like where you are going with this.. now you have me thinking of my next potential mod!
    MotoTundra[QUOTED] likes this.
  12. Aug 7, 2016 at 8:36 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Haha I'm not familiar with fiberglass construction but if it's possible l really think it would look sick! Definitely one of a kind! I love that bumper and also like when mesh or diamond plate fills those gaps, but something color matched and shiny, oh sh*t!!!
  13. Aug 7, 2016 at 9:08 PM
    Well done. :thumbsup::thumbsup::thumbsup:. By the way, Dechutes IPA (Oregon) is great. Oregon grows the best hops in N/A. Not my humble opinion. Fact.
  14. Aug 7, 2016 at 11:42 PM
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    :cheers: :drool: Looks so good! I gotta check these out soon!!
  15. Aug 8, 2016 at 4:44 AM
    I'm a little confused on the part list requirements. I see you have beer listed 3 times. Was that a misprint or just a needed requirement? Can I just get the beer all at once or should I go to 3 different liquor stores? Can one substitute whiskey or will this project come out crazy?
    Little help here.....
    :D:thumbsup:
    Looks great IMO, how many hours do you think are invested in your project?
    Better yet, probably should measure this project by six packs.
    Well done.
    TRON and T-Rex266 like this.
  16. Aug 8, 2016 at 10:12 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    One of my favorite IPAs - I don't doubt that fact at all. The truth is in the taste!
  17. Aug 8, 2016 at 10:25 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Haha originally I had beer listed more in the parts list but didn't want anyone to think the main purpose of the project was to get drunk. This DIY is from my second attempt at this. Lets just say that bourbon was a variable factor during my first attempt lol.
    Not including curing and drying times I probably spent 3-4 hours with the shaping and sanding taking the majority of the time. I am pretty anal on things being perfect so I may have spent a little more time on sanding these than I needed. For me that converts to about 1.53 six packs lol
  18. Aug 8, 2016 at 10:32 AM
    1.53 six packs...LMAO. Great!!!
    Glad you picked up on my weird sense of humor.
    The eyelids look sharp and like when people DIY projects.
    I have to be honest though, before I opened this thread, I thought it was one of those eyelashes girls put on their cars. Thankfully, you maintained your Man Card and upgraded to Platinum.
  19. Aug 8, 2016 at 10:37 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Ahahahaha My wife would divorce me if I were to even own a pair of those eyelashes. I think our sense of humor is pretty similiar, just like our names (my name really isn't Batman, its Kris).
    ColoradoTJ likes this.
  20. Aug 8, 2016 at 10:41 AM
    So would mine. A few things were mandatory before my wife would walk down the isle with me:
    - If I spent more than 1K on a wedding ring for her, she would say no.
    - No minivans ever...no. matter. what
    - No station wagons...ever.
    - A DUI would equal an immediate divorce.
    I thought that was reasonable.
    NewImprovedRon and boardude[OP] like this.
  21. Aug 8, 2016 at 10:56 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Compared to some of the requirements I have heard from friend's wives, that is very reasonable lol! My wife would agree with all those especially your 2nd and 3rd points. When we had the "Do you want kids" talk when we were dating the next question was "would you ever own a mini van?". I grew up in late 80's Astro vans and when I told her that it almost ended our courtship lol.
  22. Aug 8, 2016 at 11:03 AM
    Isn't that a fact. My wife's best friend requirements is a page long, (no kidding) and on that page is a 7 carrot diamond. She is always wondering where all the good "brothers" are at. I just laugh and say "guess they are all gone, can't imagine why you can't find a man with that criteria?" :rolleyes:
  23. Aug 8, 2016 at 11:08 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    haha yeah that requirement alone might reduce your match.com results to single digits lol. We went cheap with the ring and spent the money on the honeymoon and mas tequila instead.
  24. Aug 8, 2016 at 4:35 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 Mall Crawler Extordinare
    All Pro Long Travel with Walker Evan Coil Overs, All Pro Expedition Leaves with Walker Evan Resi Shocks, All Pro IFS, transmission and E-Locker skid plates/guards, ARB Bumper with Kragen LED flood lights, 10,000lb SuperWinch, All Pro Rear Bumper, All Pro Sliders, Custom RTT Rack with Roto Pack, ARB Simpson RTT, Bed Tray. 285x75R16 Mickey Thompson MTZs and 285x75R16 Yokohama Geolander it g072. Airaid Short ram intake, Intake manifold spacer, Borla Cat back Exhaust.
    Extremely well done. My only gripe is you should have made a cast mold after they dried to sell to peps. Send them just the rough primed shells. When I got my Trex lids for my Taco, that's all they were. 7 years and still going strong on my Taco.
    MotoTundra likes this.
  25. Aug 8, 2016 at 6:08 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah I actually thought about that since there isn't anyone else making these but I travel for work pretty often, sometimes every week. Don't really want a second job right now lol
    Krazie Sj[QUOTED] likes this.
  26. Aug 8, 2016 at 6:15 PM
    But then you can "make it rain" and say "I'm rich bitch!"
  27. Aug 8, 2016 at 6:26 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Hahaha classic!!
    Sh*t I would probably just accept BevMo or Total Wine gift cards to keep my "project" beer fund going lol
  28. Aug 8, 2016 at 6:56 PM
    I see no harm in doing that as well.
    You're throwing the bomb ass parties for all Tundras.com members once a year right? Have a huge meet and greet, BBQ, and some damn good laughs.
  29. Aug 8, 2016 at 9:20 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Very nicely done. Looks professional. I would buy from you if I had a 2014+
  30. Aug 14, 2016 at 3:47 PM
    Lee's rig
    Lee's rig Party naked
    Lee
    North nj
    2014 DC and 2014 single cab both 8' bed with 5.7
    To many
    At first I thought wtf!!!! Glad I looked because I actually like them. Good job.
