DIY: Battery Hold Down Install
Discussion in 'General Tundra Discussion' started by csuviper, Mar 8, 2017.
  1. Mar 8, 2017 at 2:33 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This install was performed on my 2012 5.7L Rock Warrior Crew Max.
    Parts included in kit from @Coupe - Link to sale thread:
    • (1) Battery hold down bracket
    • (2) j-hooks
    • (2) padded washers
    • (2) lock nuts
    Tools and extras needed:
    • 10mm socket or wrench
    • 11mm socket or wrench
    • Battery acid neutralizing spray
    Ok this is an easy one guys. I don't have much in terms of progress pics for this one either.
    1. Use a 10mm (TBC) socket or wrench to remove the negative terminal.
    2. Use a 11mm (TBC)socket or wrench to remove the positive terminal.
    3. Use a 11mm (TBC)socket or wrench to remove the existing j hooks. In my case i had to remove the wing nuts by hand.
    4. Clean the stock battery with acid neutralizing spray. (Or install a new battery like i did and clean the battery tray and under the tray before installing the new battery).
    5. Hook the new j-hooks in place and set the new battery hold down bracket so the holes line up with the j-hooks. Should be centered on the battery.
    6. Use a 11mm (TBC) socket or wrench to tighten the bracket down to the new battery.
    I went a step further and replaced the stock terminals as well.
    Shadowfax1, WVI, CJ21 and 9 others like this.
  2. Mar 8, 2017 at 2:55 PM
    csuviper
    Broomfield, CO
    The hold down sizes were created for stock Tacoma and Tundra batteries. Some aftermarket batteries are slightly narrower in size like the Northstar battery that i installed. Because of this there is a little bit of overhang.
    I know @Coupe is working on an updated version of the bracket that will allow for adjustment for the narrower batteries.
    Despite the slight overhang the battery is fully secure in place and i have no worry of it moving at all either.
    RitcheyRch likes this.
  3. Mar 8, 2017 at 2:58 PM
    Stig
    Stig New Member
    Nice job! I'm gonna have to at least get those terminals. Where did you get them?
  4. Mar 8, 2017 at 3:11 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Nice! I need to get those! I keep getting corrosion on my hold down bracket.
    NewImprovedRon likes this.
  5. Mar 8, 2017 at 3:25 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Looks great!
  6. Mar 8, 2017 at 3:29 PM
    TheBeast The Beach
    I keep spraying that red thing terminal protector over it.
  7. Mar 8, 2017 at 3:31 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Sprayi
    spray it with what?
    TheBeast[QUOTED] likes this.
  8. Mar 8, 2017 at 3:34 PM
    TheBeast The Beach
  9. Mar 8, 2017 at 3:44 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
  10. Mar 8, 2017 at 3:50 PM
    TheBeast The Beach
    Amazon has it..I usually order while wearing my PJs instead of fighting crowds at autozone..:)
    Krezz and Law323 like this.
  11. Mar 8, 2017 at 3:55 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    That's how I get through Christmas shopping LOL
  12. Mar 8, 2017 at 4:07 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    Looks great and those terminals are awesome.
  13. Mar 8, 2017 at 10:29 PM
    csuviper
    Broomfield, CO
    Law323 likes this.
  14. Mar 8, 2017 at 10:36 PM
    csuviper
    Broomfield, CO
    This is the cleaner I mentioned
    NewImprovedRon and T-Rex266 like this.
  15. Mar 8, 2017 at 11:05 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Did the terminals come with cover protectors?
  16. Mar 9, 2017 at 6:33 AM
    csuviper
    Broomfield, CO
    Krezz likes this.
  17. Mar 9, 2017 at 6:33 AM
    csuviper
    Broomfield, CO
    No
  18. Mar 9, 2017 at 11:27 AM
    10forty2
    10forty2 New Member
    Doug
    NC
    2017 Tundra TRD-4x4 XSP-X
    Or you could go old school..... Use baking soda/water to clean the corrosion and a light coat of petroleum jelly to protect. Much cheaper and IMHO works just as good.
    To the OP...I do like that holder and the terminals, though!
    csuviper[OP] likes this.
  19. Mar 19, 2017 at 10:01 PM
    csuviper
    Broomfield, CO
    Received the first of the adjustable @Coupe battery hold down brackets. Looks awesome and very beefy.
    WVI, CJ21 and Lilly like this.
  20. Mar 20, 2017 at 9:35 PM
    csuviper
    Broomfield, CO
    Completed the install of the new bracket. It fitns nice and tight with the skinny width of the battery and the handle on one side. Definately not moving now. Great design.
    Need to trim the jhooks down a bit. Dimensions provided to coupe so when others order it will be the right length.
    Just realized I put it in backwards from where I had it before.
    WVI and RitcheyRch like this.
  21. Mar 20, 2017 at 9:58 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    Having that large of a positive battery terminal exposed would make me nervous. Am I missing something obvious?
  22. Nov 9, 2017 at 7:46 AM
    csuviper
    Broomfield, CO
    No issues. Terminals are far enough apart and its only 12-14V
  23. Aug 5, 2021 at 9:17 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    how tall are the new j hooks he sent you?
  24. Feb 6, 2022 at 9:12 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Yes puting a 34r in an need new j hooks!! how tall are the new j hooks he sent you?
  25. Feb 6, 2022 at 12:58 PM
    csuviper
    Broomfield, CO
    I never had any issues with that when I installed. Sorry
