DIY: Baja Designs Squadron-R Sport, 14+ Mount Kit & Bezel
Discussion in '2.5 Gen Tundras (2014-2021)' started by MotoTundra, Aug 29, 2017.
  1. Oct 10, 2018 at 9:01 AM
    #241
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Yes you have to remove all clips and bolts. After all hardware and fasteners are removed then it should wiggle out. You have fasteners on the bumper/fender and frame.
  2. Nov 17, 2018 at 8:16 AM
    #242
    multimile
    multimile New Member
    2020 Crewmax Cement
    D1C72AE4-0432-4534-9CBE-0048B47DD3E3.jpg I installed these the other day and can’t get over the gap between the OEM fog light bezel and the Baja kit. Is this much gap normal? Disclaimer, I absolutely suck at installing shit, broke tabs/plastic removing the wheel well liners and my passenger side fog light bezel won’t align correctly to pop back into the bumper all the way (today’s task), so this likely could be my install error. I just couldn’t see any other way to remove this gap in each.
    Other than the gap, I love the lights and as others have said, way to bright for on coming traffic, but I plan to use them as brights more than anything.
    MotoTundra[OP] likes this.
  3. Nov 17, 2018 at 8:20 AM
    #243
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    We are usually able to get them a little tighter but a little bit of gap is normal.
  4. Nov 17, 2018 at 8:26 AM
    #244
    multimile
    2020 Crewmax Cement
    My passenger side is slightly better, don’t have a pic handy. It seems to me that the metal brackets that pop into the tabs of the oem housing could be slightly shorter to close this gap.
  5. Nov 17, 2018 at 8:34 AM
    #245
    jagged155
    jagged155 New Member
    2018 Platinum Pro
    great write up. I ordered that set last week and looking forward to installing
  6. Nov 17, 2018 at 9:08 AM
    #246
    multimile
    2020 Crewmax Cement
    Yeah it’s got to be something I messed up. I’ll take another look when I have my passenger light out today. Thanks for the tips.
    MotoTundra[OP] and Watt maker like this.
  7. Nov 18, 2018 at 6:27 AM
    #247
    MotoTundra
    MotoTundra [OP] The Ocho
    Don
    I noticed a small gap with mine, but once mounted on the truck it isn't noticable, and I have a touch of the OCD.
    Hopefully a second check of that one will correct it.
    multimile likes this.
  8. Nov 18, 2018 at 7:31 AM
    #248
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    It took me several tries to get the gap to get smaller. I was able to get it small enough to my satisfaction in the end. There will be a small gap on the inside edge of fog light, no matter hard you try. If you don’t install the foam or install the foam pieces correctly the gap will be quite large. The foam pieces are a PIA to install. Take your time and get the foam pieces to fit properly. Also, dont install the fender liner back until you completed aiming the fog lights.
  9. Dec 10, 2018 at 4:37 PM
    #249
    JayPee
    JayPee New Member
    Chandler, Az or San Gabriel, Ca
    2017 Toyota Tundra Sr5 TRD 4x4
    in my dreams
    I know this is an old thread but how do you do tje anytime fog?
  10. Dec 10, 2018 at 4:38 PM
    #250
  11. Dec 11, 2018 at 6:49 PM
    #251
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Sub'd.
    Looking at the BD to replace factory fog lights on my 2017 CM Limited.
  12. Dec 11, 2018 at 7:51 PM
    #252
    MotoTundra
    Don
    They expect to have SAE DOT approved fogs coming soon, just an FYI.
    tundracap[QUOTED] and Watt maker like this.
  13. Dec 11, 2018 at 8:07 PM
    #253
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
  14. Dec 12, 2018 at 5:04 AM
    #254
    MotoTundra
    Don
    :thumbsup::thumbsup:
    Looking good!!
    hi_rawb[QUOTED] likes this.
  15. Sep 5, 2019 at 6:01 PM
    #255
    MotoTundra
    Don
    Update: I have had these installed for over two years now and still love them. No issues at all!
    Watt maker, lbcdan and Pinay like this.
  16. Sep 5, 2019 at 6:13 PM
    #256
    lbcdan
    lbcdan Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    ditto. 1 year for me!
  17. Sep 5, 2019 at 7:43 PM
    #257
    lbcdan
    Daniel
    Long Beach, CA
    forgot to mention, in case people werent aware, there is a SAE version of these lights as well that you can run on the street. I just ordered a set to put in the fogs and I am moving the Squadron wide angle to ditch light brackets.
    MotoTundra[OP] and Luckydog like this.
  18. Sep 5, 2019 at 8:08 PM
    #258
    MotoTundra
    Don
    Good call! I will edit the original post tomorrow to show their new SAE lights.
    Please let me know how you like them.
    lbcdan[QUOTED] likes this.
  19. Sep 5, 2019 at 8:10 PM
    #259
    lbcdan
    Daniel
    Long Beach, CA
    Will do. Hopefully getting them within the next week. Ordered switchpros too get everything wired in.
  20. Sep 5, 2019 at 8:14 PM
    #260
    MotoTundra
    Don
    Can't wait to see the setup!
  21. Sep 18, 2019 at 8:44 PM
    #261
    Moco
    Moco New Member
    Marcos
    Boerne
    2019 Tundra TRD Pro, 2015 JKU Rubicon, 2016 HD 48
    35DA1C2C-9A9A-48D0-97E6-61064F1C9910.jpg 7E7B2E28-A2E7-4147-BFCB-1E0B93325C3C.jpg F5475559-DABA-40BF-99B0-C826251B4C7F.jpg
    Out with the old and in with the new. Just installed the sports and could not be happier. Crappie pics but much better light than the factory Pro fogs pic is with new Sports and DRL only and it’s amazing shout out to Baja Designs can’t wait to finish my install with ditch lights and rears
  22. Sep 18, 2019 at 9:09 PM
    #262
    Moco
    Moco New Member
    Marcos
    Boerne
  23. Sep 19, 2019 at 5:35 AM
    #263
    MotoTundra
    Don
    :thumbsup::thumbsup: Looking good!
  24. Oct 10, 2019 at 2:04 PM
    #264
    Alaska
    Alaska New Member
    2017 Tundra TRD 4x4 ~Quicksand~
    Baja Designs Squadron WC fogs
    My Squadron WCs just arrived. I'm going to do the install tonight. I appreciate this thread in helping me get the ball rolling on what to expect! Cheers:thumbsup:
  25. Oct 10, 2019 at 5:55 PM
    #265
    MotoTundra
    Don
    Good luck with the install, glad this could help. Make sure you post up pics of them!
  26. Oct 10, 2019 at 6:04 PM
    #266
    lbcdan
    Daniel
    Long Beach, CA
    First impressions, they look exactly like the regular squadrons but with a cutoff. Originally, I was very concerned with the cutoff and blinding oncoming drivers. My tundra is lifted and it’s pretty level which means the fogs are pointing straight forward, not down. After two weeks of driving with them on at night, not a single person has flashed their high beams or complained. As of now, I am very happy with my purchase and I moved my old squadrons up to ditch light brackets. 34592032-5A36-4A9B-AA63-CD2DA3737E46.jpg
  27. Oct 10, 2019 at 6:05 PM
    #267
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    @MotoTundra thanks for taking the time in creating the thread. It gave me the courage to take this on myself. Your step by step instructions were right on. It took me about 90 minutes to get both sides done. Thanks again!
  28. Oct 10, 2019 at 7:39 PM
    #268
    MotoTundra
    Don
    That's awesome, good to hear. I may consider doing the same. Your truck looks great. Which brackets did you go with for the ditch lights and how do you like them?
    Absolutely, glad it helped! Your truck is sick btw.
    rmvcard0303[QUOTED] likes this.
  29. Oct 10, 2019 at 8:17 PM
    #269
    lbcdan
    Daniel
    Long Beach, CA
    I went with Victory 4x4. They are low profile. So far they seem like a quality product. I do have one that may not be aligned correctly (my end) because the squadron bracket hits the paint when I lift my hood. I will fix this weekend and let you know.
  30. Oct 11, 2019 at 10:04 AM
    #270
    Alaska
    Alaska New Member
    Night and day difference! The install was pretty straightforward and your thread helped a lot. I have a 2017 and did not have a blue clip holding the lights in. Checking the current on my factory harness, blue (driver side) and red (passenger side) was hot and white was not. Although brown is typically ground in a lot of applications, along with black, I used the brown to connect to the power on my lights too. I too had a gap between the light and housing but based on the bracket provided, there is no way to eliminate this gap. You would need to fabricate a new bracket that allows the light to slide forward or position the "L" behind or under the screw.
