DIY: Baja Designs Squadron-R Sport, 14+ Mount Kit & Bezel
Discussion in '2.5 Gen Tundras (2014-2021)' started by MotoTundra, Aug 29, 2017.
  1. Jan 6, 2018 at 11:47 AM
    #211
    MotoTundra
    MotoTundra [OP] The Ocho
    Don
    They look great @Abel Sneed , you can tell by the pictures they are doing their job!
    I see what you mean about the foam. I will say I don't have the foam and I haven't had any vibration issues. Hopefully you will be good to go.
  2. Jan 8, 2018 at 9:17 AM
    #212
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Thanks for posting your feedback and pictures. The truck looks great with the lights on there. Glad you're enjoying the lights!
    -Bailey, Baja Designs
    www.bajadesigns.com
    MotoTundra[OP] likes this.
  3. Jan 21, 2018 at 11:40 AM
    #213
    zlaneb
    zlaneb New Member
    Austin, TX
    @Tundracollector how do you angle them down, and when you do it do you need a new bezel and also, does it create a gap in the fitment. I'm ready to go with these in Amber and cornering if I can validate how to angle them down.
    Thanks!
    Z.
  4. Jan 21, 2018 at 4:36 PM
    #214
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Well the bezels weren’t offered yet when I bought my squadrons so I do have a small gap. Also from what I seen, the bezels don’t let you adjust the squadrons very much because they make contact with the fog light surround.
    It’s really easy to tilt them down, since you have to mount the brackets on the squadrons, just rotate the brackets a bit before tightening them.
    I know that’s a sucky description but all you need to do is have them in front of you and you’ll get it.
  5. Jan 21, 2018 at 5:24 PM
    #215
    zlaneb
    zlaneb New Member
    Austin, TX
    Cool - thanks for the reply!
  6. Jan 21, 2018 at 5:41 PM
    #216
    Baja Designs
    Bill
    San Marcos, CA
    As @Tundracollector said, Their kit was installed before our Squadron Angled Bezel was included. The Squadron Angled bezel was designed to eliminate the gap found on these kits but does limit your adjustment. If you are looking for maximum adjustment, and don't mind a small gap, purchase our Squadron-R Series Lights and Fog Pocket Kit but keep the standard Round Bezel instead of installing the Squadron Angled Bezel.
    Squadron-R, Sport, Pair
    https://www.bajadesigns.com/products/Squadron-R-Sport-LED-Light-Pair.asp
    OR
    Squadron-R, Pro, Pair
    https://www.bajadesigns.com/products/Squadron-R-Pro-LED-Light-Pair.asp
    Plug and Play, Fog Pocket Kit (14-18 Tundra)
    https://www.bajadesigns.com/product...-Current-Tundra-14-Current-Fog-Pocket-Kit.asp
    We do offer a 10% Discount to Forum Members! This also includes $5 shipping to the Lower 48. Code: BDForums
    www.bajadesigns.com
  7. Jan 21, 2018 at 5:42 PM
    #217
    MotoTundra
    Don
    X2 regarding the angle and the bezels. In my opinion with the bezels they get mounted into the angle BD set them at. I think the angle is fine as it is, but I see what you are trying to do for street use. With enough tools and motivation I'm sure you can find a way to angle them down somehow.
    Edit: BD beat me to the punch with a better answer.
  8. Jan 21, 2018 at 6:19 PM
    #218
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I feel like the bd’s are wasted when pointing them down.
  9. Jan 21, 2018 at 6:43 PM
    #219
    Tundracollector
    They are wasted when they are off too, tilting them slightly allows me to run them all the time without being too blinding
  10. Feb 1, 2018 at 12:16 PM
    #220
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    I finally got mine in and installed! I ordered mine back before Christmas, but because I am a cheap Canadian I had them shipped to the border and had my folks border hop and pick them up. Finally went for a family visit and picked them up! Thanks to the OP for the description. I was able to set them up and get them ready to go before heading out to the garage to install them (-20 degrees Celsius). Should have arranged them a bit better but the passenger side is on the right and drivers side is upside down on the left.
    I took a snapshot of the housing from the back to show the blue tab as it sits I just undid them from here and installed them from the well well without pulling the housing. It was pretty cold and I was worried the plastic tabs would just snap. Just used a screwdriver to pop out the blue tab and took out the one screw and popped in the new lights and buttoned everything back up! Took about 20 minutes per side.
  11. Feb 1, 2018 at 1:17 PM
    #221
    MotoTundra
    Don
    Nice! What are your thoughts on the output?
  12. Feb 2, 2018 at 11:30 AM
    #222
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Well, my squadron sports arrive today. Since I had pulled my stocks out from the front, I plan to do the same. I cut off the clip holding the wire harness to the truck earlier so I have more play in the wires. My plan is to attach the squadrons and then push into to place from the front and avoid going through the wheel well. I'll post back results.
  13. Feb 2, 2018 at 12:22 PM
    #223
    Baja Designs
    Bill
    San Marcos, CA
    If you have any photos of the truck during the day or night, we'd love to see them! Feel free to share:
    https://www.tundras.com/threads/baja-designs-general-discussion-thread.2844/
    www.bajadesigns.com
  14. Feb 2, 2018 at 1:43 PM
    #224
    4Runner
    4Runner New Member
    Columbia, SC
    Success....
    Watt maker and MotoTundra[OP] like this.
  15. Feb 2, 2018 at 2:19 PM
    #225
    Baja Designs
    Bill
    San Marcos, CA
  16. Feb 2, 2018 at 2:28 PM
    #226
    MotoTundra
    Don
    :thumbsup:
  17. Feb 2, 2018 at 5:23 PM
    #227
    4Runner
    4Runner New Member
    Columbia, SC
    And what a difference in lighting. Can’t wait to get my retro headlights next month to really see and match the 5000k temp. Love them!
  18. Feb 2, 2018 at 6:30 PM
    #228
    MotoTundra
    Don
    Sounds like you are going to own the night. A retro and some BD's are a great combo in my opinion!
  19. Mar 27, 2018 at 3:20 PM
    #229
    tundraoverland1
    tundraoverland1 New Member
    Las Vegas
    2015 White Tundra crewmax TRD 4x4
    IG: sfarrisjr88
    Do you drive with these on daily?
  20. Mar 30, 2018 at 9:53 AM
    #230
    back_cast
    back_cast New Member
    Denver, CO
    So this is for the 2018 Tundra's...or at least mine lol. I had read a bunch of the previous installs and was prepared with way too many tools. I wanted to post this up to hopefully save some new truck owners some time and frustration.
    I got the Squadron Sport Wide Cornering Amber lights from bajadesigns.com and used the "BDForums" code to get the lights for $337 shipped to my door.
    The kit included the two lights with the bezels already installed, the mounting hardware, all the wiring harness stuff to make it plug 'n play, and some small foam squares that are now included to help with vibration and to keep the lights secure. (It's debatable whether or not that foam is needed....pretty snug without)
    Tools needed -
    • Plastic trim pry tool
    • Phillips head screwdriver
    • Alan wrench for Baja light housing brackets
    Before picture
    After removing the interior fender wall...luckily not breaking those little clips/tabs that hold the plastic liner to the chrome bumper. And I didn't find the dreaded blue tab that is located on some of the Tundra fog light housings...And 20 minutes of frustration on how to remove the housing, I was left with this.
    After feeling around for a while from the back side of the light, I decided that it may be easier to remove the housing from the front of the vehicle. And I was right. The only thing holding the housing in place are two tabs. All you need to do is depress the top tab with a little plastic pry tool and pull it out from the top slowly and then pull it out from the bottom.
    Here is what the top tab looks like.
    The factory wiring harness is clipped into the frame of the vehicle so the light is not going to give you much room when you pull it out from the front of the vehicle. Don't panic. Just reach over the top of the light and depress the connector clip from the housing. You should be able to do this with one hand.
    Go ahead and attach the metal hardware to the new Squadron housings. Cut the foam pieces and apply them to metal tabs like this. I used a pocket knife and super glue.
    Install the light into the factory housing and slowly coax some of the foam between the metal light bracket and the factory housing area. I used a pocket knife. It doesn't need to be pretty in my opinion.
    Put the wiring harnesses together as instructed with the Baja instructions. I didn't have a voltmeter so I went with my intuition. I'm not sure how Toyota decides on the coloring scheme but here's how it was for my truck. On the passenger side, from the factory wiring, pink was positive and white with a black stripe was negative. On the driver side, blue was positive and white with a black stripe was negative. For the baja lights, brown is positive and black is negative. Anyways, get all that straight and pop the housing back into the bumper. Put it back in as you pulled it out. Insert on the bottom and gently pop it in up top. As you can see the gap between the light and the housing is negligible with the bezels.
    After it's all buttoned up....
    Hope some of that helps you new owners out. I can post up some night photos later if ya'll want.
  21. Mar 30, 2018 at 6:56 PM
    #231
    MotoTundra
    Don
    back_cast likes this.
  22. Apr 2, 2018 at 8:54 AM
    #232
    Baja Designs
    Bill
    San Marcos, CA
    Looks great! Thanks for sharing your install with us.
    www.bajadesigns.com
  23. Apr 13, 2018 at 2:16 PM
    #233
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
    Yea dude :)
  24. Jul 3, 2018 at 7:53 AM
    #234
    MotoTundra
    Don
    Well I've had them for almost a year now. Still Loving them, no issues at all!
    War_Wagon312 likes this.
  25. Jul 3, 2018 at 7:59 AM
    #235
    Baja Designs
    Bill
    San Marcos, CA
    Happy to hear!
    Almost a year though?! Where is time going? :confused:
  26. Jul 3, 2018 at 12:31 PM
    #236
    MotoTundra
    Don
    I know, time is flying!
  27. Jul 4, 2018 at 7:27 PM
    #237
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Same here. Mine are still going strong. Bought the clear lenses to swap the amber ones out but can't bring myself to do it.
  28. Jul 4, 2018 at 7:41 PM
    #238
    MotoTundra
    Don
    Haha funny you mention it, I have been considering it, but same thing, not sure I want to leave the Amber.
    Driving home tonight there was a ton of smoke in the roads from fireworks, the Amber cut through it pretty decent!
    Pudge likes this.
  29. Jul 5, 2018 at 2:40 AM
    #239
    War_Wagon312
    Rich
    Stock horse
    Hahaha exactly! You never know when you are going to need them! Murphy's law!
  30. Oct 9, 2018 at 11:46 PM
    #240
    Firepiko
    Firepiko New Member
    Maui, Hawaii
    2018 MG TRD Sport Crewmax
    Can anybody explain how to remove the plastic fender well? Do you pull the whole plastic fender straight out? Or do you pry the clips off to get the fender off? Any help would be appreciated, thank you.
