DIY: Baja Designs Squadron-R Sport, 14+ Mount Kit & Bezel
Discussion in '2.5 Gen Tundras (2014-2021)' started by MotoTundra, Aug 29, 2017.
  1. Oct 15, 2017 at 7:30 AM
    #121
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Like @BlueBottle said if the housing is in good shape they dont. Mine unfortunatly did due to me needing immediate gratification. I think the zip ties are a great idea for anti theft. 300 bucks for fogs that can pop out in under 10 seconds could be a quick loss. Mine had a minor shake when I hit a big pot hole or something but the real reason for me was so it would be a PITA to steal them
    Theonlyway[QUOTED] likes this.
  2. Nov 5, 2017 at 9:32 AM
    #122
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Thanks for the write up. I used it
  3. Nov 5, 2017 at 11:01 AM
    #123
    MotoTundra
    MotoTundra [OP] The Ocho
    Don
    You're welcome, how did the install go? How do you like them so far?
  4. Nov 5, 2017 at 11:02 AM
    #124
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Sweet. Looks better than the mori’s already! I want the pros now... ha
  5. Nov 5, 2017 at 11:27 AM
    #125
    Eclipsed & Floating
    Voluptuous Whitey
    I'll probably end up with PROs somewhere but not there. I need snow cutters. I'm hoping this will do it
    30 minutes tops, after my desire to run the bezel around the housing went away. I was kinda hoping to make it work and sit a little more forward. No dice without losing adjustability.
    They look really good. Now I'm hoping output is where I want it
  6. Dec 7, 2017 at 10:43 PM
    #126
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Can you still angle em down a bit when using the new bezel kit?
    Have mine on the way and am just curious a little early. Haha
  7. Dec 8, 2017 at 4:34 AM
    #127
    War_Wagon312
    Rich
    Stock horse
    Yes you can still adjust up or down with the bezels. Just make sure you down wrench the brackets on too tight. If you go a little light on the tightness you can adjust them on the fly.
  8. Dec 8, 2017 at 10:14 PM
    #128
    BlueBottle
    '16 Platinum 4x4
    See fine print
    So I got my Pros in. Popped em in and wow they really are twice as bright! I’ll let the pics speak for themselves.
    My setup is 2018 LED headlamps and Squadron R Pros.
    Lows only
    Lows + Sports
    Lows + Pros
    Pros Only
  9. Dec 9, 2017 at 4:26 AM
    #129
    MotoTundra
    Don
    Wow. They are legit!! Looking good!!
  10. Dec 9, 2017 at 4:55 AM
    #130
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    The pros look NIce! Which pattern did you decide to go with?
    MotoTundra[OP] likes this.
  11. Dec 9, 2017 at 5:37 AM
    #131
    Eclipsed & Floating
    Voluptuous Whitey
    Damnit!!!!!!
  12. Dec 9, 2017 at 6:04 AM
    #132
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Those are wide cornering
    Right!? It’s crazy bright.
  13. Dec 9, 2017 at 6:14 AM
    #133
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    I wish these were ok to use on streets with oncoming traffic. They look great but I want something I can use on a regular basis.
  14. Dec 9, 2017 at 6:23 AM
    #134
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yeah. Only sae dot led housings are rigid or Morimoto. I don’t like how the rigid looks.
    GodlessPro likes this.
  15. Dec 9, 2017 at 7:04 AM
    #135
    94slowbra
    john
    new orleans
    2016 TRD pro
    I had the morimoto ones on my last f150 and they were great. Enough light, looked good and fit like oem. That doesn't seem to be the consensus over here, the fit seems to be hit or miss. I'm not opposed to the rigids but I'm unsure of how they would look in a round opening. The pics online differ with how far they stick out. But I don't want to run the risk of spending the $$$ on the BD ones only to not be able to run the full time. First world problems I suppose.
  16. Dec 9, 2017 at 7:21 AM
    #136
    BlueBottle
    '16 Platinum 4x4
    See fine print
    The Morimoto fit fine on my truck. But I wasn’t satisfied in the light output. I wanted more lol. And more. Which is how I ended up with the Pros.
    This was when I was still running Phillips LED bulbs in the stock housing.
  17. Dec 9, 2017 at 8:46 AM
    #137
    Eclipsed & Floating
    Voluptuous Whitey
    The rich light coming fro my S2s overpower my squadron sports though I have driving combos for my fogs, which I really like
  18. Dec 9, 2017 at 8:55 AM
    #138
    MotoTundra
    Don
    I know exactly how you feel. I still went with the @Baja Designs though. I don't regret it but I do wish I could run them more, just because.
    I wish there was a high/low setting available. It would be nice to run low in the city more for safety to be seen like a DRL, even some type of backlighting; then have the option to use high and unleash them when needed on backroads or inclement weather.
    It doesn't seem to be BD's style (off road, top notch bright lights) but I know I would he interested (if I didn't already buy the Squadron's). When it comes to making that type of product I don't know what the challenges would be and/or the extra cost.
  19. Dec 13, 2017 at 5:43 PM
    #139
    mungk
    mungk New Member
    Washington DC
    2017 Cement Pro
    BLUE CLIPS! spent half an hour trying to figure out why people were able to pop out their shrouds so easy on youtube. Guess i'm gonna have to go in from behind.
  20. Dec 13, 2017 at 5:53 PM
    #140
    MotoTundra
    Don
    I'm going to add this to my original post, does anyone know what year they started using the blue clips? Any photos or tips how to get them off?
  21. Dec 13, 2017 at 6:07 PM
    #141
    BlueBottle
    '16 Platinum 4x4
    See fine print
    My 2016 platinum has them.
  22. Dec 16, 2017 at 3:14 PM
    #142
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    how the heck did u take of the pins to put on the new plugs for the plug and play?
  23. Dec 16, 2017 at 3:16 PM
    #143
    MotoTundra
    Don
    Can you show me what you mean with a picture?
  24. Dec 16, 2017 at 3:47 PM
    #144
    Tundra4us
    Tundra4us New Member
    "D"
    Hey fellas, need some pointers on the BD install into stock housing. I am getting poor fit into the plastic housing with gaps from the bezel to the housing. Is this common? Also does it matter how the light is orientated; lead at top or lead at the bottom.... I have seen it mounted both ways. I feel like an idiot! Thanks.
  25. Dec 16, 2017 at 3:59 PM
    #145
    MotoTundra
    Don
    I didn't have any fitment issues with the fog light going into the plastic housing. I did have some trouble getting the plastic housing to click back into the bumper perfectly, it took a few tries.
    I mounted my fogs with the leads on the bottom. My thought process was that due to gravity and water, the harness should be on the bottom to reduce any risk of moisture getting in there.
    I have no clue if that makes any sense, just explaining what I did and why.
    Good luck!
    Watt maker and NewImprovedRon like this.
  26. Dec 16, 2017 at 4:02 PM
    #146
    fisherman951
    Tony
    2017 crewmax 4x4
    I figured it out. I missed that their was 2 extra plugs for the plug and play harness at the bottom of the box. I thought I needed to remove from other harness
  27. Dec 16, 2017 at 4:03 PM
    #147
    MotoTundra
    Don
    Gotcha. Good deal!
  28. Dec 16, 2017 at 4:23 PM
    #148
    Tundra4us
    "D"
    MotoTundra, Yeah makes perfect sense. Thanks. Now that I have looked at this more, it really can't be tight to plastic housing cause that would eliminate any adjusting.
  29. Dec 16, 2017 at 4:38 PM
    #149
    MotoTundra
    Don
    :thumbsup:
    You and @fisherman951 need to post up some pics and your initial thoughts after you finish up!
    BlueBottle likes this.
  30. Dec 16, 2017 at 4:41 PM
    #150
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Did you upgrade to the pro yet????
