DIY: AIP & Timing Valve Replacement Write-Up
Discussion in '2nd Gen Tundras (2007-2013)' started by Nor7, Jul 30, 2016.
  1. Jul 30, 2016 at 8:25 PM
    Nor7
    Nor7 [OP] Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    So a few requests to do a write up. 6 months ago I got P0419 code and P2442 so I replaced the pump and valve using the Chilton Manual Procedures. Got the CEL and codes for the other pump and valve so I replaced those last night. Enjoy, I would have taken more pictures but my hands quickly became filthy and I didn't want to foul up my fancy smartphone.
    Step 1: Find and locate connectors under hood (Below). Disconnect connectors and remove cable connectors. Both are located on passenger side towards the front of the truck. NOTE: I HIGHLY Recommend that you mark the connectors so you remember which one goes back where. If you're replacing both at the same time (which is a smart idea), Pump 1 connector connects closer to the grill and Pump 2 connector is practically underneath the main air intake tube/hose. Example, female and male connectors mark with an A for one and B for the other, then mark the same A and B on the new connectors. Once they feed back through into the engine compartment, you will have no idea which is which.
    (This picture needs to be rotated)
    (excuse my low tech pointing)
    Step 2: Remove front passenger wheel.
    Step 3: Pry back plastic cover in wheel fender.
    Step 4: You will see pump assembly in fender well (Below). Pull out rubber hoses, then find and remove qty 2 bolts and qty 2 nuts to free bracket assembly (10 mm).
    Step 5: Pull out assembly and loosen air inlet hose to appropriate pump (Below). Pumps are not bolted in, just pry out rubber 'legs?' from pump.
    Step 6: Install pump assembly by following steps in reverse order.
    Step 7: Crack a cold one, you're done.
    For the valve, Bank 1 is on the right side of the engine compartment and is bolted to the block with 3 bolts and is bolted to the air injection flange with 2 bolts. Just pops out then pop the new one in.
    JTP, T-Rex266, ColoradoTJ and 4 others like this.
  2. Jul 30, 2016 at 8:29 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Nice write-up! I'm sure this will come in handy for many!
  3. Jul 30, 2016 at 8:37 PM
    TheBeast The Beach
    Thanks for the write up. Love the low tech pointing
    ColoradoTJ and Spvrtan like this.
  4. Jul 30, 2016 at 8:46 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    What year is the truck?
    I noticed the "snorkels" are the upgraded model that are supposed to be the fix for the air pump problem. Did you install these when you replaced pump?
  5. Jul 30, 2016 at 8:47 PM
    Nor7
    2011, Yes I replaced the snorkel with the upgraded one when I did the first pump.
  6. Jul 30, 2016 at 9:01 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    You sir are the man!!!
    The arrows are amazing. Crazy you added so much texture and realism with those computer generated arrows
    Chukardog, JTP, Wvmoonshiner and 3 others like this.
  7. Jul 30, 2016 at 9:05 PM
    csuviper
    Broomfield, CO
  8. Jul 30, 2016 at 9:09 PM
    Nor7
    Hah, I should do a write up on the arrows. Lol they're just cardboard that I cut and wrapped in green tape around a screwdriver.
    JTP, driverdog, MotoTundra and 2 others like this.
  9. Jul 30, 2016 at 9:10 PM
    Nor7
    ColoradoTJ, Law323, driverdog and 3 others like this.
  10. Jul 31, 2016 at 11:00 AM
    Nice job and great write up.
    Some people have been getting quotes of 4000.00 to replace both pumps. I have been thinking about buying a set and sitting on them until I need them. Other option is to just wing it and deal with it when needed. Lastly, one of the vendors on this site is developing a bypass kit. The question I have is were the pumps pretty easy to get? Price?
    Thank you.
    driverdog likes this.
  11. Jul 31, 2016 at 7:11 PM
    Nor7
    Started around 8pm and was done at about 10pm. Roughly two hours. Took me a little longer the first time.
    Write up took me about 15 minutes.
  12. Jul 31, 2016 at 7:21 PM
    Nor7
    Don't buy them unless you need them. You have a 2012 so likely you've got a 50/50 chance you won't need them ever. The $4k quote is usually on the 4.7L engines as they require more disassembly than the 4.6L.
    I've got mixed feelings about the bypass kit. I've heard a few horror stories about the ECM flash upgrade from the dealership causing the bypass kits to throw an error code and not being able to pass emissions.
    I bought everything from Amazon and was pretty easy to get, the same parts are used in the Sequoia and a few other vehicles.
    Upgraded Air Inlet Tube: $30?
    Pump 1: $164
    Pump 2: $164 (they're identical)
    Valve 1: $275
    Valve 2: $180
    Case of Bud: $20
    Having enough $$ leftover to buy a gadget for the garage that I'll probably only use once in 10 years: Priceless
  13. Jul 31, 2016 at 7:24 PM
    Thanks for the information. This helps everyone else out.
  14. Aug 10, 2017 at 6:40 PM
    wilbret
    wilbret New Member
    Could you share info on the parts you chose from Amazon? Particularly the air inlet tube and valves?
    Amazing DIY. Thanks!
    aperezsh likes this.
  15. Aug 11, 2017 at 10:56 AM
    Nor7
    It's all in here.
    EvilOne likes this.
  16. Aug 11, 2017 at 11:05 AM
    wilbret
    wilbret New Member
    Thank you sir
  17. Aug 12, 2017 at 7:29 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    Im going to fab up some of those for use in my next build pics.
  18. Aug 12, 2017 at 7:34 PM
    JTP
    The Big Black Moose
    GiantsFanDan and NewImprovedRon like this.
  19. Mar 18, 2018 at 6:54 PM
    TTTUNDRA
    TTTUNDRA New Member
    EvilOne likes this.
  20. Mar 18, 2018 at 7:06 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Your arrows are awesome!!!
  21. Apr 1, 2018 at 8:01 PM
    Nor7
    If you order the replacements, you should be able find them visually since you know what they look like. I didn't have to remove anything to get to them except the plastic engine cover. I'll try to get a pic for you next chance I get.
  22. Apr 2, 2018 at 12:00 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Awesome guide! I've been planning on doing this eventually. One (or both) of my pumps have some rocks or something inside them.
  23. Apr 2, 2018 at 5:18 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Good stuff. Will pull down to check for corrosion..
  24. Apr 2, 2018 at 5:19 AM
    Les7311
    What’s the symptoms?
  25. May 15, 2019 at 1:24 PM
    Molina.al
    Molina.al New Member
    Alexander
    2012 tundra dc
    Hi everyone I had this issue as well and replaced everything. However now is showing me an issue with one valve Bank 2
    Do you know which is the bank 2 the passengers or drivers side valve ?
    Thanks
