DIY 35" spare tire carrier
Discussion in 'General Tundra Discussion' started by CaptSpaulding, Mar 9, 2019.
  1. Mar 9, 2019 at 9:50 PM
    CaptSpaulding
    CaptSpaulding [OP] ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    I've been looking for a dual spare carrier option that didn't take up a majority of the bed space, and fit 35"s. The SDHQ rack is really cool, but takes up too much room. I had 1 spare underneath...uncomfortably tight squeeze and felt it may present clearance issues at some point. That said, I pulled my plastic liner and set out to make my own. I realize this is amateur stuff at best, but I'm still working with 1 arm for the most part. Had fun though.
    I used 3/16" x 1-1/2" x 3' stock for the runner peices and @csuviper great write on adding a DIY bed rail system for the hardware to attach the peices securely to the existing bed rail holes. I drilled and beveled 9/16" holes for four 1/2" carriage bolts with washers and nuts for wheel placement.
    I plan to add a rail to the front of the bed, and potentially the sections left over in the rear. The remaining piece that looks like I didn't measure right, I'll use for a floor jack mount on 1 side and :crazy: on the other.
    I'll spray it with bedliner after I clean out the bed, with plans to have the bed lined soon. Also change the bolts to the same size as the wheel studs and use lug nuts to secure the wheels.
    Thoughts?
    Will I end up warping the bed? Should I add some Rago or TC bed stiffeners? Is this ridiculous and useless? Will people mistake me for B.J. Baldwin now? Did I hurt myself lifting those damn spares up there...yes.
    20190309_131717-01.jpg 20190309_132640-01.jpg 20190309_150229-01.jpg 20190309_170026-01.jpg 20190309_161115-01.jpg 20190309_171247-01.jpg 20190309_170805-01.jpg 20190309_170755-01.jpg
  2. Mar 9, 2019 at 9:59 PM
    Great job! To bad I can't do this due to solid one piece tonneau cover :( gonna have to hack away underneath to fit a 35
  3. Mar 9, 2019 at 10:05 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Hell ya. That’s what I like to see! Don’t get me wrong I love expensive flashy parts as much as the next guy. But I really love do it yourself stuff that gets the job done at a fraction of the price with a little ingenuity. :thumbsup:
  4. Mar 9, 2019 at 10:09 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I like it! Ive been trying to figure out what i could do with the same outcome. I wish one of these manufacturers would put a kit out like this, i dont have the means to make one.
    Major, 15whtrd and Mountun Goat like this.
  5. Mar 10, 2019 at 5:15 AM
    Slayer
    Slayer Member
    Slayer
    Nice Job
  6. Mar 10, 2019 at 5:21 AM
    Good job.
  7. Mar 10, 2019 at 6:24 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Neat idea, but i wouldnt offroad with them mounted like that. They will snap off
  8. Mar 10, 2019 at 8:59 AM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Thank you guys, appreciate the kind words.
    As @Hbjeff mentioned, the carriage bolts may snap while offroading. I did ensure I used grade 5 bolts, 120,000 psi tinsel strength minimum rating. I'm wondering how I can further secure these so I can hit the dirt without worrying. Possibly a block underneath the tires to support the weight better? See attached
    @Larmand You just need a drill and some bits man. Sure, I used my drill press and bench grinder. But I'm also 1 armed currently, ahahah. I can make a template if that'll help?
    @Slayer best name ever!
  9. Mar 10, 2019 at 9:06 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Love it. I would try to get a little more support underneath 'cause that's a lot of weight when wheeling.
    YES, you should get bed stiffeners.
  10. Mar 10, 2019 at 9:07 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    No you dont need to get me a template. I can take some measurements, easy enough. I dont have a drill press but im guessing i could make it happen. I need to get my full size spares 1st.
  11. Mar 10, 2019 at 9:11 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Glad you asked! I was thinking how I will improve on your idea for my truck already haha.
    You could add two more bolts to the inside of the wheel (hub opening) to a plate that spreads past the hub opening.
    Or if ya have a welder like I do, build a steel bracket that extends out to a spreader bar.
    Also it would help to weld a drop bar to the floor for weight support.
    :hattip:
  12. Mar 10, 2019 at 9:16 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Drop bar is a good idea! How long 'til you have mine ready?:wink:
  13. Mar 10, 2019 at 9:16 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Thinking a block/wedge/chalk or "U" shape bottom support would work great.
  14. Mar 10, 2019 at 9:19 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I really think yall are on to something BIG here. I would certainly purchase something like this if a vendor, could produce this. Definitely making the bolts the same size as wheel studs, so we can secure with lug nuts. Maybe if @brimy311 is looking for a new little project. Since he seems to be producing all the goodies everyone is asking for.
  15. Mar 10, 2019 at 9:35 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha couple weeks!
    831Tun[QUOTED] likes this.
  16. Mar 10, 2019 at 10:10 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I have a DIY 40" tire carrier..
  17. Mar 10, 2019 at 10:45 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha woody
  18. Mar 10, 2019 at 10:51 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I don’t think support under the tire is the issue. Its the front back and side to side forces that will pull and break the bolts.
    Had another thought. Maybe if you could make a wheel chock like support and get a ratchet strap around it?
    I think it’s a practical place to store the spares and you’ll figure it out.
    Sunnier and Mountun Goat like this.
  19. Mar 10, 2019 at 6:02 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    We're on the same page here! I'll work on something, following your CAD drawings and add to its stability ;) Pics to follow
    Bed stiffeners also going in for peace of mind
  20. Mar 10, 2019 at 6:35 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha Ataboy!! Can’t wait to see!
  21. Mar 10, 2019 at 7:57 PM
    Slayer
    Slayer Member
    Slayer
    Ha... Back in 2003 I hit a deer while riding my motorcycle.
    killed that sumbitch
    my riding buddies started calling me "the deerslayer"
    over the years it was shortened to just "slayer"
  22. Mar 10, 2019 at 8:04 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    :headbang::headbang::headbang::bowdown:
    TokerJoker and CaptSpaulding[OP] like this.
  23. Mar 13, 2019 at 2:07 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
  24. Mar 13, 2019 at 2:15 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Larmand[QUOTED] likes this.
  25. Mar 13, 2019 at 2:20 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
  26. Mar 13, 2019 at 2:21 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    im pretty sure that would work just like the one he made. he just didn't have the bed tracks to work with. I bet you could use it in the same location!
  27. Mar 13, 2019 at 2:24 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Maybe so, i might give a try but i find the $270 price a bit excessive for this. If brimy can put something i might go that route otherwise ill try fabbing my own up.
    Erichudgins[QUOTED] likes this.
  28. Mar 13, 2019 at 2:25 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    agreed lol im sure the quality Is solid. looks to be the same pieces from the gate I have. but looks to be a pretty simple design.
  29. Mar 13, 2019 at 2:29 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    My tires might have to mount a little higher than the ones posted as i dont have as much bed space with the CrewMax or mount to the rear of the bed. Itll get figured out soon enough.
  30. Mar 13, 2019 at 2:59 PM
    NE_WARRIOR
    NE_WARRIOR [HOONIGAN] Wannabe
    Nick
    Union, ME
    08 DC SR5
