Ditch lights...thoughts?
Discussion in 'Lighting' started by Weavin Pro, Apr 12, 2021.
  1. Mar 17, 2023 at 12:56 PM
    Petergoose1
    Petergoose1 New Member
    2020 pro army green
    I could use more light out front and all around for that matter. It is the dark corners that are problematic, more so now that the truck is higher now
  2. Mar 17, 2023 at 1:31 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Go wide lens for your fogs to cover the corners and spot for your Ditch to go above your headlights. You could even go fancier and have the relay pull from your high beams and make your Ditch work with your high beams. Then do the fog light mod and have the ability to run your fogs anytime and you'll have it all on when you need it.
    Petergoose1[QUOTED] and reywcms like this.
  3. Mar 17, 2023 at 1:48 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Driving lights is a style of the light pattern but still for offroading. Best thing to do is put rock guards on the lights when your on paved roads. I never get flak for my ditch lights and I'm in California where a smelly fart can get you fired.
  4. Mar 27, 2023 at 8:06 PM
    2020cement_tundra
    2020cement_tundra New Member
    Nick
    SC
    2020 tundra
    I’ve got the driving pattern DD, they are super bright. Brighter than my aftermarket LED headlight and fog bulbs. Like others said I run them at night, but cut them off for oncoming traffic. I too thought they look a bit akward there but they are more function than looks for me 2E3DA65F-881D-47F3-8AB9-E864450375E8.jpg
  5. Mar 29, 2023 at 7:21 AM
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
  6. Mar 29, 2023 at 7:46 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Well see now you confused me, most of my night time wheeling is done in Costco parking lots..
