Ditch light bracket?
Discussion in '3rd Gen Tundras (2014+)' started by Casper3, Oct 28, 2017.
  1. Jan 12, 2018 at 4:58 AM
    OBXTundra
    OBXTundra New Member
    2010 Tundra, 5.7, 4x4, Flex-fuel, TRD
    I researched the yellow light a bit last night. It does perform better in foggy conditions, dense rain, and snow. The yellow light "cuts through" better, where white light will reflect and make a "wall". Looks cool too. I want to change my factory fogs over to accept a standard LED pod, will probably go with yellow/amber as well.
  2. Jan 12, 2018 at 5:13 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2016 SR5 TRD Offroad CM
    Rago with extensions. These are the Freedom LED offered in the group buy and some cheap LEDs that I modified to be yellow.
    ARamirez73, r4z0r51o and CJ21 like this.
  3. Jan 12, 2018 at 5:20 AM
    OBXTundra
    @Backslider is that 3M protective film that you used to get the yellow?
  4. Jan 12, 2018 at 5:36 AM
    Backslider
    Tooele, UT
    Yeah, but I opened the lights up an applied it on the inside ofnthe lens. So far they habe held up fine.
  5. Jan 12, 2018 at 5:38 AM
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Well sweet I always thought they did better. and I've seen a few of the conversion to fit a pod in the factory spot, they look pretty damn good when they do that.
  6. Jan 12, 2018 at 10:03 AM
    14burrito
    14burrito New Member
    You dont need shorter mounts....just need to rotate the mounts you have, they are installed backwards.
    Berdine likes this.
  7. Jan 12, 2018 at 12:11 PM
    ccdawnpatrol
    ccdawnpatrol New Member
    Torrance, CA
    2017 SR5 MGM CM 4x4 5.7L
    Anyone seen any Tundras with led spotlights? Are they even legal in some states?
  8. Jan 12, 2018 at 1:34 PM
    Berdine
    Berdine New Member
    Binghamton, NY
    2016 MGM Crewmax TRD
    Thanks, I ended up doing that. They look soo much better now! And these leds are bright as hell!
    14burrito likes this.
  9. Jan 12, 2018 at 2:50 PM
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    ADS C/O w/clickers, ADS bypass rear, Icon UCAs, Toytech shackles, chrome delete, Pro grille, TRD dual exhaust dumped, de-badged, black LED tail lights. BHLM w/projectors, 295 70 18 Cooper STT pro on stock rims w/1.25" Spider Tracks. N_Fab bumper w/Baja Design fogs and ditch lights, 13" antenna x, RCI skid, All Pro sliders, ARB compressor
    I'm not sure exactly what you're referring to but my Baja Designs on the ditch brackets are spots. I've got a feeling you're talking about something much larger though?
  10. Jan 12, 2018 at 8:37 PM
    ccdawnpatrol
    Torrance, CA
    I was thinking something like this. It would kinda be nice to actually aim a solid light in a specific direction. But I love the idea of having solid brackets to hold some legit lights so that is why I am currently looking at Rago Fabrication. http://www.larsonelectronics.com/p-...dGybxg3-kwmr8EGKUGreGIjsJLn9LjwxoCGKcQAvD_BwE
  11. Jan 12, 2018 at 8:46 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    @sdhq_offroad A-pillar mounts keep my @Baja Designs S2pros very low and tight to the hood as not to have a tall and obvious mount. After all, I’m not going for them to stand out, rather functionality instead.
    CC9D26A2-3D0B-430E-8A32-BA905E9D09DA.jpg C2F73804-DD11-4A00-AF95-9BF51372FA9C.jpg 2D63ED23-0E90-4BC6-BC71-7E46AAA6A7A5.jpg
  12. Jan 12, 2018 at 9:06 PM
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    I'm trying to figure out how you mounted the BDs in the bumper 'cause I have some to go there too.
    Eclipsed & Floating likes this.
  13. Jan 12, 2018 at 9:11 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Magic
    boardude likes this.
  14. Jan 12, 2018 at 9:14 PM
    Eclipsed & Floating
    Voluptuous Whitey
    These fit perfectly and are adjustable so you can angle in any direction you want. These are the ones @boardude encouraged me to get and they are perfect
    Berdine, boardude and 831Tun like this.
  15. Jan 13, 2018 at 12:19 AM
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    Thanks. I thought I'd see the strap part in the photo but I don't. I'm sure I'll understand it better if my bumper ever shows up.
  16. Jan 13, 2018 at 2:36 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    Who did you order the bumper through?
  17. Jan 13, 2018 at 5:46 AM
    Eclipsed & Floating
    Voluptuous Whitey
    The strat is not a strap, it’s a slotted and flat-ish post that has holes and grooves for bolts
  18. Jan 13, 2018 at 6:12 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2017 SR5 / TRD Blazing Blue Pearl
    I have been thinking about mounting these on ditch light brackets facing forward. I can't decide how they would look. I kinda like the round look but not sure if they're to big.
    OBXTundra likes this.
  19. Jan 13, 2018 at 6:22 AM
    #49
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    Here's a pic of how they mount
  20. Jan 13, 2018 at 8:11 AM
    #50
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    Thanks, mystery solved. :thumbsup:
  21. Jan 13, 2018 at 8:14 AM
    #51
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    Ordered from 4WP on black Friday.
  22. Jan 13, 2018 at 8:24 AM
    #52
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    Oh geez, wonder if there were/are on back order from n-Fab. It will be worth the wait
  23. Jan 13, 2018 at 8:28 AM
    #53
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    I spoke with N-Fab, "cause 4wp couldn't tell me sh**, it should've left Texas at the beginning of last week and headed to 4WP warehouse in Compton Ca. 4wp anticipated shipping date has been bumped out to the 18th of this month.
  24. Jan 13, 2018 at 8:31 AM
    #54
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    Not too much longer then
  25. Feb 10, 2018 at 7:52 PM
    #55
    kcaustin66
    kcaustin66 New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    question guys with the ditch brackets are they or can they aim straight forward
  26. Feb 10, 2018 at 8:31 PM
    #56
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    Maybe I don't understand the question but my ditch lights point straight forward.
  27. Feb 10, 2018 at 8:40 PM
    #57
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    The brackets wrap around the hood. As far light direction your cam aim the light straight ahead or off to the side. Mine are angled out a bit
  28. Feb 10, 2018 at 8:56 PM
    #58
    kcaustin66
    kevin
    I found some that fit a 2nd gen tundra will they fit 3rd gen tundra (the brackets look the same)
  29. Feb 10, 2018 at 8:59 PM
    #59
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    I looked up Rago Fab and they list different ones for 2nd and 3rd gens but they look the same. So, kinda hard to say if they'll fit or not.
  30. Feb 11, 2018 at 5:36 AM
    #60
    OBXTundra
    They can point straight forward. They can aim whatever direction you set the pod. But the reason I went with ditch lights was to have them pointed about 30 degrees off to each side, it puts a lot of light where you wouldn't normally have any with any other light setup.
    If Rago has a different set for 2nd and 3rd gen then I assume there are minor differences. Based on the finished product and the tight clearances, he seems like the kind of operation that does his homework.
    831Tun likes this.
