Distance to empty indicator changed with new battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by Harlan, Apr 22, 2020.
  1. Apr 22, 2020 at 4:53 AM
    Harlan
    Harlan [OP] New Member
    2016 Double Cab Long Bed 4WD
    Something weird happened. I just replaced my battery (95K miles). Started engine and it shut down. Started again and ran normally. OK. Something about the fuel system according to mechanic. Went to fill up with gas and distance to empty indicator shot up from around 300 miles remaining (which it's done since I owned it and I always thought seemed to low) to 425.
    It was like replacing the battery reboot the computer. Is that what happened?
    Thanks in advance.
  2. Apr 22, 2020 at 5:14 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    It will take awhile to adjust; after replacing or disconnecting the battery it will rest to default and normalize / readjust over the course of a week or so.
  3. Apr 22, 2020 at 6:13 AM
    It will readjust as mentioned, and it's only an estimate. Most dont even pay attention to it. As far as starting, it is normal for the first start to immediately shut down after a battery is reconnected.
  4. Apr 22, 2020 at 6:16 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    It just reset the ecu due to power interruption. It will level back out to what it was before after a couple fill ups. Don’t get your hopes up. A miracle did not occur.
    TXMiamiFan likes this.
  5. Apr 22, 2020 at 6:45 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    As others said, it resets the computer when you remove the Negative.
    However, I found it takes awhile (many tanks) to go back to normal and I was averaging around 3,500 miles per month before I sold the truck.
  6. Apr 22, 2020 at 7:37 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    So if we want better fuel efficiency, just replace battery or remove negative battery connection!
    Nice!
    TXMiamiFan and Voyagermike like this.
  7. Apr 22, 2020 at 8:25 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    that is completely normal. to avoid that, you can use one of these:
    https://www.amazon.com/gp/product/B07QV2QFTC/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
    it will save all your radio presets, your ecu settings, and any custom tune (which is why i bought it).
    it works great.
    NewImprovedRon likes this.
  8. Dec 11, 2024 at 9:45 PM
    3201MCC
    3201MCC New Member
    Brett
    2020 Tundra TRD Pro
    Changed the battery a year ago in my 2020 tundra TRD pro and the mpg reads about 4 mpg higher than actual mpg. Prior to the battery change it was very accurate
  9. Dec 26, 2024 at 6:45 PM
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    ‘24 Platinum MGM
    Sorry to bring this back from the dead but I recently removed by battery terminal to clean around battery and now my digital speedometer and distance until empty is completely gone. Anyone have any suggestions?
