Disappointed Tundra New Owner
Discussion in '2nd Gen Tundras (2007-2013)' started by MajorC, May 27, 2019.
  1. Jun 1, 2019 at 4:08 PM
    Viking
    Viking New Member
    Jerry
    2007 metalic brown double cab Tundra
    We have a 1998 Ford Windstar that would go into "limp mode" with a misfire of one or more cylinders, would do it while cruising down the freeway at 65mph and drop the tranny into lower gears and run at about 35mph. I stopped using alcohol added fuel and most of the problems went away, plus I gained 8 mpg. The final straw with the Windstar was when we were 60+ miles from home and the damn transmission didn't want to upshift, when we got home I parked it and went in to Grants Pass Toyota dealership and bought a 2006 Sienna XLE Limited that had just over 100,000 miles that ran great and shifted perfectly. Far as I'm concerned, we will probably never by another Ford, especially after buying the 2007 Tundra, which due to the 5.7 engine, seems to have cancelled out my bucket list desire for a Mustang GT. The dealer printed out a Carfax for me before we bought the truck and because it was well serviced, at 244,000 miles I didn't hesitate to buy it.
    nuclearlemon likes this.
  2. Jun 2, 2019 at 8:20 AM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    I got my 2007 5.7 with 151k on it with perfect toyota records plus 1 owner. When i research more into the issue i went with a dap tune since it avoids this issue you were having and i still pass inspection.
    RitcheyRch and MajorC[OP] like this.
  3. Jun 2, 2019 at 9:04 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    But how is that suppose to help decide if a vehicle is good. Would you rather have one that hasnt had failures and doesnt show a big report on CF, or one that was constantly in the shop getting stuff repaired. Personally, I would rather stay away from a vehicle with a long list of repairs.
  4. Jun 2, 2019 at 9:23 AM
    Adam New Member
    Dang man. I woulda installed the bypass for you. Just woulda cost a couple of beers. Not that tough.
    TunaDr, RitcheyRch and MajorC[OP] like this.
  5. Jun 4, 2019 at 7:16 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    If this is a warranty issue, anyone know if I can research my truck to see if it's been fixed? I'm the second owner of this truck...
  6. Jun 4, 2019 at 7:21 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    Apparently, it's very labor intensive to replace the AIP. I'm not sure how much the parts cost, but the labor is probably costly.
    Splicerforever likes this.
  7. Jun 4, 2019 at 7:26 PM
    sundance
    sundance New Member
    You can buy reman parts now. Not that expensive. It is labor intensive because it hard to get to. Which everything is on a 5.7.
    Bypass is way to go. Sometimes you can just clear the codes and move on. I have a friend that did it and its been almost a year since.
  8. Jun 4, 2019 at 7:40 PM
    Chards77
    Chards77 New Member
    Akron, OH
    07 4x4 SR5 DC
    As previously stated if a dealer or other reporting repair shop has done it it will be on a Carfax. A dealer will have a record via the VIN or you can look it up yourself online at, https://www.toyota.com/owners/
    MajorC[OP] likes this.
  9. Jun 6, 2019 at 9:50 AM
    MajorC
    MajorC [OP] New Member
    Major
    2007 Tundra SR5
    If it was fixed at a dealership it will be on the CarFax report. It wasn't a Recall, but an "enhanced warranty." 10 years or 150, 000 miles. Some 2010's - 2014's are still under warranty. Doesn't matter how many owners. Hope this helps.
  10. Jun 6, 2019 at 9:53 AM
    MajorC
    Major
    2007 Tundra SR5
    The parts for mine were over $1,000.00 Some type of housing, two air pumps, two electric solenoids, and a bag full of other stuff.
  11. Jun 6, 2019 at 10:01 AM
    sundance
    sundance New Member
    You can get aftermarket pumps for less than $200 now. I don't know how reliable they are.
    Moisture is what causes problems with the pump and the valves. They added a purge cycle and other logic that works to keep the moisture down in newer models. I know they have in the 14 plus but I think they have added it in the 13s as well. I know I can hear mine run from time to time.
    The bypass works good for your model. It doesn't work at all on newer models. I wouldn't be afraid to use it at all for an 07.
    RitcheyRch likes this.
  12. Jun 6, 2019 at 10:59 AM
    marcfs71
    marcfs71 New Member
    Marc
    2010 Grey Tundra TRD Offroad Pkg with TRD Supercharger
    Dual Exhaust
    Never heard of AIPS problems before. If I have a similar problem with my 2nd gen, I will troubleshoot and do the bypass if necessary. Good luck with the repair.
  13. Jun 6, 2019 at 11:08 AM
    sundance
    sundance New Member
    I think they added the Air pumps in 05/06. All 07 plus had them. Even the 4.7 and 4.6s.
  14. Jun 6, 2019 at 12:50 PM
    Chards77
    Chards77 New Member
    Akron, OH
    07 4x4 SR5 DC
    My 2010 GX460 (thru present) stil have the air pumps. The originals failed around 90-110k per my Lexus dealer. Not sure if the replacements have better life expectancy
  15. Jun 6, 2019 at 1:16 PM
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    Will these bypass kits let you pass smog inspection in California?
  16. Jun 6, 2019 at 1:30 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    This is what the Toyota dot com site says about my vehicle: There are no open Safety Recalls or Special Service Campaigns for your vehicle.
    But in a post above someone claims the 2011 Tundra is part of the AIPS recall? And no, it does not show my truck as having any work done to repair this issue.
    I called Toyota and they said that my truck has not had the AIP replaced but my truck is covered under their "Customer Care Program" so it's not a recall. I have until August 2021 or 150k to get the AIP replaced IF AND ONLY IF, my truck is having problems with the AIP like the OP's truck had. So, basically, if my truck doesn't have any issues, then Toyota is not going to replace anything. If my truck has AIP issues and it's less than 10 years and 150k miles, the dealership will fix the problem.
  17. Jun 6, 2019 at 2:15 PM
    Chards77
    Chards77 New Member
    Akron, OH
    07 4x4 SR5 DC
    @Yodder J , yes it'll be fixed if it breaks.
    And on the Toyota owners site you create an account and load the VIN of the vehicle. It gives you the history including diagnostics and services that the owner declined. Which is significantly more than you get from Carfax, which only logs work completed not work needed.
    This is how you can see a Toyota vehicles real history. I've looked at cars with problems diagnosed and not repaired before. Where the seller claimed it was not an issue at all.
    I.E. the used GX I purchased had the air pump work done already. In the case of the Tundra I took a nice discount because the frame was rusty, knowing it was eligible for the warranty inspection and repair.
    RitcheyRch and sundance like this.
  18. Jun 29, 2019 at 9:33 PM
    Splicerforever
    Splicerforever New Member
    Rich
    2008 Toyota Tundra SR5 4x4
    None
    It costs about 2400.00 to have AIP done.
  19. Jun 29, 2019 at 9:35 PM
    #49
    Splicerforever
    Rich
    None
    Costs 2400.00 if the dealership does AIP repair.
  20. Jul 8, 2019 at 6:04 PM
    #50
    FXFormat
    FXFormat New Member
    When i buy used vehicles, i try to find ones that gets driven regularly like 12K miles a year, cars that sit for a long time, tends to have more issues, stuff gets seized, clogged, rubber cracks etc..
    Hence my 2008 with 185K miles drives like new, with the only issue i have is the shit gas mileage, but that's partly my fault because i drive like a douche. In your case, 45K miles in 12 years, that car sat around for quite awhile. Sorry about your troubles, good luck with it.
  21. Jul 8, 2019 at 6:13 PM
    #51
    Rubberdown
    What is the code that the computer has pulled? It will tell you the single part that is bad. Toyota wants to replace all of it for no reason. It’s generally one of the valves going bad as it gets loaded up with carbon. Please please please find out specifically what part is bad, and then based on that you can replace the single part for relatively cheap.
    Where about are you located? If it’s near Houston I could give ya a hand.
  22. Jul 10, 2019 at 3:30 PM
    #52
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I looked up my service history on Toyota's site. My truck had both pumps replaced at 10 months old and 13k miles.
    NewRider likes this.
  23. Jul 17, 2019 at 2:44 AM
    #53
    Boudreaux93/4x4
    Boudreaux93/4x4 New Member
    M. A.
    MS
    '13 White Tundra DBLCab SR5 4x4, TRD, RWP
    I'm definitely NO expert like y'all when it comes to working on the trucks. But before I bought my '13 Tundra this yr. I had the Carfax report AND luckily it was at the dealership, with the same mechanic that has serviced our other Toyotas since '83. My '13 had one owner only with 70,000 mil. I made sure the mechanic checked that truck out from top to bottom BEFORE it was ever mine. Needed four new tires, new brakes/pads, of course, oil & filter change, etc...all on Toyota's dime.
  24. Jul 17, 2019 at 3:11 AM
    #54
    NewRider
    NewRider New Member
    Travis
    Roaming the Shenandoah's
    2014 Tundra Limited Crew cab w/Flatbed
    Flatbed
    Toyotaowners.com
    Type in your VIN and you can see everything done at a dealership. Maybe not quite as good as a Carfax that reports a multitude of shops but I’m betting in your situation that old couple took it back to the stealership for everything so you can find all sorts of stuff.
  25. Jul 17, 2019 at 4:16 AM
    #55
    wktjr
    wktjr New Member
    Maine by way of New Jersey
    2013 Tundra SR5, Black Crewmax
    A carfax on my truck will be pretty thin since I haven't had any issues.
  26. Jul 25, 2019 at 5:55 AM
    #56
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    If you do bypass kit, can you still smog in calif?
