disable alarm chirp?
Discussion in 'General Tundra Discussion' started by 14txtss, Feb 21, 2015.
  1. Feb 21, 2015 at 11:03 AM
    14txtss
    14txtss [OP] New Member
    Ron
    Houston
    2017 attitude black platinum 5.7 4x4
    Anyone know how to turn off the alarm chirp on newer trucks? I've found this kind of info for a forerunner, but can't seem to find it for Tundra's. Thanks in advance!
  2. Feb 21, 2015 at 2:21 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I believe it requires software that you could purchase for a couple hundred plus connectors to computer or have toyota do or
    Or find the sound module and disconnect the wires.
  3. Feb 21, 2015 at 8:08 PM
    The dealership can turn it off.
  4. Feb 22, 2015 at 2:06 PM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    If you don't have/want the Techstream software, or don't want to have a dealer do it... in my `06 I found the little "squeaker" under the master cylinder and wrapped it with electrical tape- I couldn't hear the chirp unless I was standing right next to it. I haven't looked for it in `14 though, so I'm not sure if this is still do-able.
  5. Feb 23, 2015 at 10:19 AM
    14txtss
    Ron
    Houston
    I bought my daughter an 01 4 runner, and disabling the alarm chirp was done through a sequence of key fob button pushes and ignition key positions, as strange as that sounds. That's why I thought maybe the same thing could be done on my Tundra.
  6. Feb 23, 2015 at 9:34 PM
    csuviper
    Broomfield, CO
    I've looked into this but unfortunately the newer ones don't have this. Tried on my 07 Tacoma with no dice either.
