DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. May 31, 2022 at 1:38 PM
    #2011
    fishmando
    fishmando New Member
    What did you go to afterwards? I don't need mud traction, I'm more of a fire roads and dry terrain person.
    Cruzer[QUOTED] likes this.
  2. May 31, 2022 at 1:44 PM
    #2012
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Oh that'll be perfect for you then. I saw an ad on Craigslist for 5 40" tires for $400 - bought it with a quickness - Atturo Blades 40x13.5.17 and sold the 39s.
  3. Jun 3, 2022 at 10:38 AM
    #2013
    Kur
    Kur New Member
    Mesa, AZ
    08, 5.7, Double Cab Tundra, White
    How are those patagonias holding up? What kind of wear/mileage are you getting?
  4. Jun 7, 2022 at 9:50 AM
    #2014
    kos221
    kos221 New Member
    2007 4X4 DC
    I don't drive the truck too much. I might have 2000 miles on them. The fronts are starting to feather a little. They grip nicely in mud and are smooth on gravel. The tread blocks clear out quickly. Pavement grip is not great in dry and worse in rain. They feel firm and are consistent in corners but the limits of traction are lower. I can easily make the back tires howl (they don't squeal) in first or second gear. MPG at 12-13 highway didn't change from 35/11.50 tires.
  5. Jun 7, 2022 at 10:00 AM
    #2015
    kos221
    kos221 New Member
    2007 4X4 DC
    Most tire manufacturers recommend at least an 8.5 inch wide wheel with a 12.5 inch wide tire. Factory 18s at 8 inches wide are not recommended. If you do put a 12.50 inch wide tire, you will rub on the UCA. I used 1.25 inch wheel spacers to fix that.
    pvn.beluga likes this.
  6. Jun 7, 2022 at 10:34 AM
    #2016
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I ended up giving up on 37's for now. I bought some 285/75/18 Cooper discover at3s and they fit almost perfectly. I can make a full u turn going forward but can't back out of my driveway without rubbing. Bought some bumper shims to help with that.
    Hightide likes this.
  7. Jun 8, 2022 at 7:04 PM
    #2017
    Wildtrout
    Wildtrout New Member
    Seattle
    2018 Tundra Crew Max
    OME BP51 Front and Rear, Complete de badge, ARE Z Series camper shell, Decked system, TRD CAI, painted hood bulge and grill surround, WeatherTech mats
    Hey All, haven’t posted in a while. 2018 Tundra CM doing great. Might be moving to 37x12.5x18s Nittos all around. Currently running 37x11.5x18 Nittos Ridge Grapps which is a size only Nitto makes. Had an issue with my front passenger tire which renders me with two, almost new tires in the rear, with a fading pair upfront. All this to say I was stunned by the lack of stock for any other brand through Discount Tire. Wanted two new Ridge Grapps for the front but they are on “indefinite back order.” Sucks, hence the possible change to a 12.5 width.
  8. Jun 9, 2022 at 9:38 AM
    #2018
    Kur
    Kur New Member
    Mesa, AZ
    With Discount being probably the single most famous and largest tire distributor in the country, you would think there would be a larger selection of tires there. Some brands aren't even sold at Discount and even within brands there are plenty of models that aren't sold at Discount either. At least online...
    That being said, 9 out of 10 times if you actually go in the store instead of just looking online, the salesmen can look up and get you almost any tire out there, as long as it isn't backordered to oblivion.
    Kind of a pain, but those certificates are worth the hassle to me. Those certificates have saved me several thousands of dollars over the years.
    And while some places have warranties and guarantees, they are all pro-rated by tire wear. So if your tires last a while, you might only get $50 credit towards a new tire, which is nothing these days. The Discount certificate covers the tire fully all the way down to 3/32in. You just have to buy a new certificate for the new tire.
  9. Jun 9, 2022 at 9:43 AM
    #2019
    SAGE63
    San Diego County
    Actually you do not have to by the certificate for the new tire... just replaced one that failed for my daughter. told them we were selling the car and did not have to buy a replacement certificate... they did not even charge for any labor
  10. Jun 9, 2022 at 9:43 AM
    #2020
    Wildtrout
    Seattle
    To be honest, there was a larger issue with my wheel, etc that caused the problem. I just don’t feel like going into it all. Certs from Discount wouldn’t have helped. The point being, I was in the store and the mngr showed me all brands, and most sizes, and all were 0 for stock. I ordered the last 4 37x12.5x18 size that Discount had anywhere in the nation, though they claimed to have 200 of that size and make as “inbound.”
  11. Jun 9, 2022 at 9:52 AM
    #2021
    Kur
    Kur New Member
    Mesa, AZ
    That is true. But I always buy the certificate for the new tire. Doing so, I have gone through 12 tires on my Jeep with only having bought the first 4 used (the certificates transferred to me) and one new to use as a spare. The other 7 I got free of charge due to the certificates. And being 33x12.50r15 Goodyear MTR/Ks, they weren't cheap tires.
    Before I built my Jeep, I also went through probably 6 or 7 stock sized tires using the certificates.
    So yeah, I don't buy extended warranties on anything, but I will ALWAYS buy the Discount Tire certificates, and because of that I won't buy tires anywhere else.
    EvoTundra likes this.
  12. Jun 9, 2022 at 12:33 PM
    #2022
    TNTundra223
    TNTundra223 New Member
    Where did you get that rear bumper? Custom?
  13. Jun 9, 2022 at 6:03 PM
    #2023
    Millwood21
    Millwood21 New Member
    Jade
    2017 Platinum
    I just picked up my first tundra last week. After reading this thread about 3 times through during my truck search over the past couple weeks I think I’m about to dive into the 37s right off the bat. Those of you running a 13.5 how is your clearance. And how much more cutting was involved. 13.5 seem to be about $110 cheaper per tire.
    Boisefly and TNTundra223 like this.
  14. Jun 9, 2022 at 6:56 PM
    #2024
    starfish.pat
    starfish.pat New Member
    Patrick
    2008 Grey SR5 TRD Double Cab Short Bed
    I'd like to submit my request to join the Dirty 7 Club...I even got a spare!
    37s on 17" wheels might be my favorite look on these trucks. And the 4-5 inch lift doesn't look so giant now that the big tires are filling up the wheel wells.
    I can't wait to test these bad boys out!
  15. Jun 9, 2022 at 8:36 PM
    #2025
    TNTundra223
    Keep us posted can’t wait to see the end result!
    Millwood21[QUOTED] likes this.
  16. Jun 9, 2022 at 8:39 PM
    #2026
    Zero One Actual
    Now go to 17’s and hug yourself daily.
  17. Jun 9, 2022 at 11:01 PM
    #2027
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
  18. Jun 10, 2022 at 4:14 AM
    #2028
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    May sound weird but getting new tires wondering would it be easier to fit an A/T 37 then a M/T would anyone know? I think I’m gonna go with the new Mickey Thompson boss
    831Tun likes this.
  19. Jun 10, 2022 at 6:43 AM
    #2029
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I've heard nothing but great things regarding the baja boss in both A/T and M/T
    Trdwillie14[QUOTED] likes this.
  20. Jun 10, 2022 at 7:23 AM
    #2030
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Good call. I did exactly that, within 6 weeks of buying my truck I was on 37's. Good luck
  21. Jun 10, 2022 at 8:00 AM
    #2031
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    37s have been getting me to the good spots this spring!
    D71D67DA-BA17-43A0-AAB5-9A02E9C8AD14.jpg 955F337A-1022-486C-8A5B-85BA4EE26368.jpg 11F94C34-4730-42DB-9E89-EB81391F514D.jpg 5937AA82-3B0E-4D13-B3BA-F2262505450B.jpg
    Deaner, Helo, TOYOTARIG and 16 others like this.
  22. Jun 10, 2022 at 8:37 AM
    #2032
    Millwood21
    Jade
    2017 Platinum
    Everything I need has been ordered but tires. Wheels are on the ups truck. About a month or so out on the suspension I was told. Just a waiting game at this point!
    reywcms likes this.
  23. Jun 10, 2022 at 8:59 AM
    #2033
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    What suspension?
  24. Jun 10, 2022 at 9:28 AM
    #2034
    Millwood21
    Jade
    2017 Platinum
    I went with the fox 2.5 setup from Accutune. Ordered some shackles from coachbuilder this week. I ordered icon billet uppers couple weeks back when I started my truck search. I was going to go with a lesser lift but that buy once cry once really got me!
  25. Jun 10, 2022 at 9:45 AM
    #2035
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    WOOT! That's an amazing looking rig @CaptainCobb, glad we're in the DC crew!
  26. Jun 10, 2022 at 12:13 PM
    #2036
    Kur
    Kur New Member
    Mesa, AZ
    What front bumper is that?
  27. Jun 11, 2022 at 12:34 PM
    #2037
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited *sold*
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    :drool:
  28. Jun 11, 2022 at 2:06 PM
    #2038
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    The AT might be a better choice for you brotha.
    joonbug and Trdwillie14[QUOTED] like this.
  29. Jun 11, 2022 at 4:34 PM
    #2039
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Looks like an awesome adventure there buddy.
    sea_weathered[QUOTED] likes this.
  30. Jun 11, 2022 at 5:08 PM
    #2040
    Trdwillie14
    Billy
    2014 trd off road
    I was thinking that and out here not a lot of off roading it’s a ton of driving esp where we live
    831Tun[QUOTED] likes this.
