DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Feb 27, 2021 at 11:36 AM
    #1441
    Trabs00
    Trabs00 Lifetime Social Distancer
    Travis
    Seattle, WA
    2012 Black Tundra CM
    7" BDS lift King 3.0 Performance series with RR and adjusters 37" Yoko Geo MT Front bumper Demello Offroad Rear Bumper Expedition 1 ATC canopy AMP power steps Alu-cab RTT Alu-cab shadow awning Alu-cab shower cube
    Yeah that would solve the issue, friend of my went that way but with 35s.
    Reason I want to run 17s is that the tire and wheels I want are only in 17. Overall the tire selection of 37s x 18 is quite limited compared to 17s and 20s
    Also 37s on 18s are a lot more expensive current Discount Tire prices
    37x12.5r17 BFG KM3 $384 Grabber X3 $352
    37x12.5r18 BFG KM3 $481 Grabber X3 $516
    I run a 5 tire rotation so DAMN a lot more $$$
    Skew12, Seffagus and TheBeast[QUOTED] like this.
  2. Mar 4, 2021 at 11:25 PM
    #1442
    TexasYota
    TexasYota Custom Yotas
    Fabian
    2014 Black Tundra CM SR5
    Fab Fours front & rear replacement bumpers, Toyo Open County 35x12.50x18, Method NV Wheels, OME suspension Front & Rear, Camburg 1.5 Uniball UCA's, Coachbuilder 3" Shackles, and much more
    20210303_154651.jpg That yota life . . .
  3. Mar 7, 2021 at 8:35 AM
    #1443
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
  4. Mar 9, 2021 at 9:17 AM
    #1444
    Trabs00
    Travis
    Seattle, WA
    Such a sweet rig. I love the Prinsu rack. I've wanted one forever but it just won't fit with my Alu-cab RTT without pushing it too far back off the canopy :(
  5. Mar 9, 2021 at 6:47 PM
    #1445
    Kelvin
    Kelvin New Member
    Any of you guys know if clearing 37’s on 2 Gen Sequoias is essentially the same for the front? I know the back is a different story, like I might have to limit up travel or something. My Tundra never came in and I don’t think it will at this point so I’m looking at other stuff. Already have DK UCA’s and front bumper. There’s some other advantages to the Sequoia that works for me, like fitting in my garage, and I can sleep in it.
    Setup will probably be Kings and 18mm offset 17’s.
    SC_TRD likes this.
  6. Mar 13, 2021 at 6:32 AM
    #1446
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    I picked up my truck yesterday from getting 5.29's and a grip pro limited slip installed. Decided to trailer it home instead of turning a 3 hour drive into a 6 hour drive breaking it in. Just a quick drive felt much better with the new gears.
  7. Mar 17, 2021 at 4:49 PM
    #1447
    Trabs00
    Travis
    Seattle, WA
    Swapped out tires and wheels :)
    37 x 12.5 r17 yoko g003 M/T
    Kansei KNP Offroad wheels 17 x 8.5 -10
  8. Mar 17, 2021 at 7:26 PM
    #1448
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    What’s your offset ?
  9. Mar 17, 2021 at 9:10 PM
    #1449
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    I don’t think the sequoia would be any different. All front end components are interchangeable, so should be the same.. my only concern would be that the OEM front bumper is all one piece, so you will have to hack it to fit an aftermarket bumper on there which is definitely a must for fitting 37s nicely. Shouldn't be too difficult to cut though, I have seen multiple people do to.
    Kelvin[QUOTED] likes this.
  10. Mar 17, 2021 at 9:18 PM
    #1450
    SC_TRD
    Colin
    Round Rock, Tx
    Trabs00 and Trdwillie14[QUOTED] like this.
  11. Mar 17, 2021 at 9:25 PM
    #1451
    TheBeast The Beach
    nice wheels !
    what made you choose the -10 offset vs 0 offset they also have.
  12. Mar 18, 2021 at 2:06 PM
    #1452
    Trabs00
    Travis
    Seattle, WA
    I wanted more clearance of my coachbuilder steering arm end link / Heims. I test fit a 17" +15 offset wheel and my end links were pretty much rubbing on the tire.
    with my calculations based on my current wheels (20") and swapping to 17" wheels that 0 offset would likely work, but that -10 would definitely clear all suspension components.
  13. Mar 18, 2021 at 2:10 PM
    #1453
    Trabs00
    Travis
    Seattle, WA
    That said, turns out I made a small mistake in my conversion of offset to backspacing and the 0 offset would have likely been a slightly better choice.
    I like a wide stance so I'm fine with the -10. I have a top Heavy truck so a wider stance is a good thing. The tires stick out maybe 1/3" more than they did with my previous setup 37s on 20 x 10 -12 offset
    With brand new M/T tires I am getting rub on rear fender well (even with BMC) but this is due to mechanic not giving me more caster (Move wheel forward) when I upgraded to Icon UCAs (I never rubbed with my LR UCAs)
    TheBeast and 831Tun like this.
  14. Mar 18, 2021 at 2:12 PM
    #1454
    Trabs00
    Travis
    Seattle, WA
  15. Mar 18, 2021 at 2:12 PM
    #1455
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Icon UCAs?? Here we go again.:rofl:
  16. Mar 18, 2021 at 2:13 PM
    #1456
    Trabs00
    Travis
    Seattle, WA
    Oh, black lug nuts on order! I want all chrome gone!
    TheBeast[QUOTED] likes this.
  17. Mar 18, 2021 at 2:21 PM
    #1457
    Trabs00
    Travis
    Seattle, WA
    :monocle:
    Pardon my ignorance... can you elaborate?
    831Tun[QUOTED] likes this.
  18. Mar 18, 2021 at 2:27 PM
    #1458
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    A lot of people, myself included, have trouble getting the preferred 0* caster with Icon tubular UCAs. It's also pretty much impossible to get much more than 3* caster. Ideally, with 37s, you're gonna want 4-5* or more. If you have their heimed UCAs you'll be able to get there.
  19. Mar 18, 2021 at 2:32 PM
    #1459
    Trabs00
    Travis
    Seattle, WA
    OK thanks! I used to have the Light Racing / SPCs and had Plenty of caster adjustment to get clearance with 37s that stuck out just as far as these wheels.
    When I had my Icon Billet Delta Joint UCAs installed, the shop didn't adjust for enough caster compared to what I had with my LR UCAs. I had rubbing before the new wheels, just more now with 10/32nds more tread!
    :fingerscrossed: With the heims on the billet UCAs they will be able to get enough caster to stop the rub
    831Tun[QUOTED] and SC_TRD like this.
  20. Mar 18, 2021 at 2:57 PM
    #1460
    TheBeast The Beach
    I'm really liking the KNP offroad in bronze color +10 offset. Has that SCS F5 flair and since scs not making the f5 for tundras I might grab the kansei. Plus they are down the street from me. Let us know long term longevity of those rims.
    https://kanseiwheels.com/collections/kansei-offroad-wheels/products/kansei-knp-truck-textured-bronze
    Trabs00[QUOTED] likes this.
  21. Mar 18, 2021 at 3:55 PM
    #1461
    Trabs00
    Travis
    Seattle, WA
    Yeah, love these wheels. They are a lot like the SCS indeed. They are also just like my FN 5-start that I had on my 4Runner, but they were 16's. Another thread where they are pulling together people to have FN wheels make a production run of 17s for Tundras of the two popular styles the 5-star and 6-shooter. Looks like they will be +18 or +25 I think, which for me won't clear my suspension, plus not ready to order until late spring or so (date TBD). I couldn't wait any longer and found the Kansei.
    Happy so far, but only on day 2 haha, I will keep posted
  22. Mar 19, 2021 at 10:30 AM
    #1462
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Well, I had 285/75/18's installed for about 3 weeks. I was trying to convince myself that I liked them, but they were just to small and skinny.
    Went back to Discount Tire and said I made a mistake. They originally said they couldn't help me, but after some arguing, they agreed to refund me for the tires and put the cost towards a set of 37's.
    They tried to discourage me and said there was no way 37's would fit a Tundra with a 3" lift. I told them to leave me alone. I did an aggressive BMC and trimmed the front fender. I am on stock UCA's and have Toytec Alumas 2.5's up front. No rubbing.
    Lesson learned....just go big and you wont regret it. Went with Nitto Terra Grappler G2sIMG_9576.jpg
  23. Mar 19, 2021 at 10:37 AM
    #1463
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I did a very similar thing two years ago with 35" KO2s that lasted a month on my truck before going back to DT. They were just too small, and I hadn't even leveled the front end yet. The guys at DT tried the same argument with me when I told them I wanted 37s. I just said if they rub, I'll cut some more. I have not regretted one mile of that decision :fistbump:
    Edit: nice looking truck btw. Love the color, and the cap is just the icing on the cake
  24. Mar 19, 2021 at 11:04 AM
    #1464
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    Does anyone run resi's with a +25 offset? Any clearance issues? Perhaps placement of the resi is key.
  25. Mar 19, 2021 at 11:57 AM
    #1465
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Is that the AT Summit? And what leaf springs are you running? I about to purchase the Summit and do my suspension upgrade right before its finished being built.
  26. Mar 19, 2021 at 6:58 PM
    #1466
    Boisefly
    Boisefly New Member
    Boise, ID
    Thanks man. No regrets here either.
    Nice truck dude!! I’m a big fan of the cap...looks like you are too.
  27. Mar 20, 2021 at 3:23 AM
    #1467
    STravis
    Travis
    Ruidoso, NM
    It's the AT Atlas. I am running custom Deavers, but I would suggest getting the camper and weighing the truck before you order so you know exactly what you need.
    Damie Street[QUOTED] likes this.
  28. Mar 20, 2021 at 4:27 AM
    #1468
    Damie Street
    Edsel
    South Carolina
    Thanks for the advice. I was wanting Deavers also. Have heard nothing but great things about them.
    STravis[QUOTED] likes this.
  29. Mar 20, 2021 at 6:32 AM
    #1469
    so_juanderful
    so_juanderful New Member
    Honolulu, HI
    2017 Cement Tundra TRD Pro
    Update after 5 months with 37s at 0 offset, haven’t destroyed my fender yet lol
  30. Mar 20, 2021 at 10:40 AM
    #1470
    Trdwillie14
    Billy
    2014 trd off road
    Very good to know
    Deaner likes this.
