DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Nov 29, 2020 at 9:42 PM
    #1141
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
    [/QUOTE]
    Has the setup you mentioned with zero offset
  2. Nov 29, 2020 at 10:06 PM
    #1142
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Don’t see this talked about much.. but after installing my 37s first I rubbed on my body mount, then after alignment and increasing my caster to 3.8 and 4.3, I was rubbing on my reservoirs.. running Fox 2.5 with total chaos UCA, and +25 wheels.. guess this is one of the downsides of a wheel with a higher offset than zero.
    thankfully I have the “universal” reservoir mounts with self tapping screws and just repositioned them to a much more upright position and was able to get them out of the way.
    Rub marks from before:
    Previous Position:
    Updated Position:
  3. Dec 1, 2020 at 8:37 PM
    #1143
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    What’s that one extra fresh hole for? :rofl::rofl::rofl::rofl:
    SC_TRD[QUOTED] likes this.
  4. Dec 1, 2020 at 8:44 PM
    #1144
    Trdwillie14
    Billy
    2014 trd off road
    The 701s are zero offset. I test fit it the 37 with bmc chop and your caster moved up ur good
    SC_TRD likes this.
  5. Dec 1, 2020 at 9:07 PM
    #1145
    SC_TRD
    Colin
    Round Rock, Tx
    What my homie Billy is trying to say is that 37s should fit with zero offset in the streets and under boring street driving conditions.
    If you plan on wheeling and possibly stuffing that front tire, your front fenders are likely in for for some hard hits, unless you compensate and go less than 12.5” wide.
    @Trdwillie14 :fistbump: hahaha
    GodlessPro, Saltyhero13 and chugs like this.
  6. Dec 2, 2020 at 4:24 AM
    #1146
    GreatBallsOfFire
    GreatBallsOfFire "I wanna go fast" - Ricky Bobby
    Seth
    Fairbanks, AK
    2017 Pyrite Mica Sequoia Limited
    So with the zero offset my tires will stick out further and at full bump they will hit the fenders, so I guess thats a pro because then I will have an excuse for my wife on why I need to get those dope looking glass fenders.
  7. Dec 2, 2020 at 8:15 AM
    #1147
    SC_TRD
    Colin
    Round Rock, Tx
    :headbang:
  8. Dec 2, 2020 at 8:48 PM
    #1148
    Trdwillie14
    Billy
    2014 trd off road
    Just wondering what your offset is ?
    Rica25 likes this.
  9. Dec 2, 2020 at 9:40 PM
    #1149
    SC_TRD
    Colin
    Round Rock, Tx
    I remember lurking this too, the set up is sweet. They say it a few pages back... +18
  10. Dec 3, 2020 at 6:27 AM
    #1150
    Trdwillie14
    Billy
    2014 trd off road
    Dude we are lurkers
    Rica25 likes this.
  11. Dec 3, 2020 at 8:12 AM
    #1151
    SC_TRD
    Colin
    Round Rock, Tx
    it’s how I learn :anonymous:
  12. Dec 3, 2020 at 8:37 AM
    #1152
    Trdwillie14
    Billy
    2014 trd off road
    @SC_TRD
    SC_TRD likes this.
  13. Dec 7, 2020 at 12:02 PM
    #1153
    TexasYota
    TexasYota Custom Yotas
    Fabian
    2014 Black Tundra CM SR5
    Fab Fours front & rear replacement bumpers, Toyo Open County 35x12.50x18, Method NV Wheels, OME suspension Front & Rear, Camburg 1.5 Uniball UCA's, Coachbuilder 3" Shackles, and much more
    Hey Guys, I've been looking into getting into 37's like the rest of y'all. My truck as of now is on OME 3/1 lift with heavy duty coils, Camburg 1.5 uniball UCA's, Coachbuilder Rear Shackles, Method NV 305s 18' with a +25 offset, and a mild BMC. Right now my truck is on 35x12.5x18 Toyo Open County MT's. I have been looking into getting the Cooper STT Pro's in a 37x13.5x18 mounted on my methods I already have. Anyone know if this will work or what else would need to be done?
    Mountun Goat likes this.
  14. Dec 7, 2020 at 12:22 PM
    #1154
    TexasYota
    Fabian
    This is a picture of the lift components and the wheels and tires when it was first installed, and a more recent photo because why not?20170920_182405.jpg 20200906_120326.jpg
  15. Dec 7, 2020 at 12:31 PM
    #1155
    SC_TRD
    Colin
    Round Rock, Tx
    Think @Mountun Goat can help you out. I believe he is rocking the OME coilovers.
    Really for stuff like this though, you will just need to test fit or be open to cutting more.
  16. Dec 7, 2020 at 12:42 PM
    #1156
    TexasYota
    Fabian
    Ok I DM'd him, I'm not opposed to cutting more if needed I just wanted to know if would even clear even with cutting more
  17. Dec 7, 2020 at 12:57 PM
    #1157
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Hey there. I’m on the same setup with SPC uppers and coachbuilder shims on drivers, one on passenger (tundra-lean). 37x12.5x18 and +18 wheel and 1.5” spacer haha. Confusing yep. Do I rub with an aggressive bmc? Yep slightly, my lower control arm cams were seized according to my last wheel alignment, I have been spraying the cams with bolt break spray in hopes of re aligning with max forward cam settings.
  18. Dec 7, 2020 at 1:03 PM
    #1158
    SC_TRD
    Colin
    Round Rock, Tx
    Just a heads up, 13.5” is really wide and will likely cause you more rubbing than @Mountun Goat as those will stick out another .5” into your Body Mount.
    Also some food for thought, the Cooper’s really run true to size and are a true 37” tire and I believe even my 12.5” wide coopers state they are actually 13” wide. BFG runs a bit smaller so could grab the KM3 and likely have slightly less rubbing/issues as well.
    Good Luck!
    TheBeast and Mountun Goat like this.
  19. Dec 7, 2020 at 1:11 PM
    #1159
    TexasYota
    Fabian
    Dam, I was hoping that I could just slap them on and have minimal issues. I wanted the Cooper vs the KM3s since they are about $400-$500 cheaper. Seems like most 37 M/Ts come in a 13.5 only
  20. Dec 7, 2020 at 1:17 PM
    #1160
    TheBeast The Beach
    speaking of KM3s..they seem sold out everywhere..looking for some 35's in 18" though...
  21. Dec 7, 2020 at 1:26 PM
    #1161
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Well i may be missing something, but Dan said that in addition to his +18 o/s wheels he's on 1.5" spacers, which makes his true offset more like -20 or so. so even if your tires are 13.5", his 12.5s will stick out like 3/4" more than yours. right?
    Mountun Goat and SC_TRD like this.
  22. Dec 7, 2020 at 1:39 PM
    #1162
    SC_TRD
    Colin
    Round Rock, Tx
    Ahh yes, you are correct. I missed the spacers :anonymous:.
  23. Dec 7, 2020 at 1:41 PM
    #1163
    SC_TRD
    Colin
    Round Rock, Tx
    There is also this option, Toyo makes a 36” tire for an 18” wheel.
    TheBeast likes this.
  24. Dec 7, 2020 at 1:45 PM
    #1164
    TexasYota
    Fabian
    Im not sure about the offset and spacers they all get a little confusing. I swear I've seen someone running 37s with +25 offset. Or is it just the width that is going to be hard to work with? I want to even go as far to say that they were running Coopers I might have to scan this forum again
  25. Dec 7, 2020 at 1:46 PM
    #1165
    TexasYota
    Fabian
    I like Toyos I just wanted to try something different but I may have to look into those just incase
  26. Dec 7, 2020 at 1:48 PM
    #1166
    TexasYota
    Fabian
    Anyone know his setup?
  27. Dec 7, 2020 at 1:49 PM
    #1167
    TexasYota
    Fabian
    He has the same wheels I have with the same tires I want
  28. Dec 9, 2020 at 10:46 AM
    #1168
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
  29. Dec 9, 2020 at 10:54 AM
    #1169
    fundra_goes_west
    Evan
    2022 SQ8
    And since it will be asked. It doesn’t just rub, it has ALL THE RUB. CMC and gears next week.
  30. Dec 9, 2020 at 11:06 AM
    #1170
    SC_TRD
    Colin
    Round Rock, Tx
    You should also know us vultures will also ask for suspension and wheel specs!
    Looks great, and like it will get some great use!
