DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Aug 3, 2019 at 12:55 PM
    #631
    Rubberdown
    Won’t affect your alignment at all to remove sway bar. Undo end links and mounts, and slide it out one side. I can’t remember if I had to do something with the skid plate or something to make room but it came right out.
    Mountun Goat likes this.
  2. Aug 3, 2019 at 1:13 PM
    #632
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    At the moment I have no skid plate on as I’m breaking in my new gears and it’s going to need the oil changed soon so I left it off so I have full access to it now. Should be real easy to remove. Thank you. I’m glad I don’t have to do another alignment. But now my front locker is leaking again so it’s going back to the shop. It was supposed to be fixed when they did my gears, but I guess not. Thanks again.
    Mountun Goat and Trdwillie14 like this.
  3. Aug 3, 2019 at 4:06 PM
    #633
    Jimes
    Jimes New Member
    Removed the swaybar and took the truck for a ride to meet Trdwillie14 to give him the stock pro skid plate I had. Honestly thought it would be sloppy, but it drove fine. You will feel it when taking a hard turn though. Good thing I don’t drive like a maniac. No more rubbing. Now I need to figure out how to dial in the hyper tech inline speedo calibrator. I put in 37 inch tires and 5.29 gears in the fields it asked for, but was still way off. Anyone do this and got it dialed in? Looking for numbers to put in to make it work properly. Thanks in advance.
  4. Aug 4, 2019 at 5:25 PM
    #634
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    What tires did you get? They can vary pretty widely from actual 37
    Rica25 and Mountun Goat like this.
  5. Aug 4, 2019 at 7:52 PM
    #635
    Jimes
    Jimes New Member
    Bf Goodrich KM3 37x12.5r18s. I got it dialed in after I took apart my dash twice. Like a clown I figured I put in the proper numbers in the options and thought it would be good. Nope. The second time I left the usb cable plugged in and had to go thru the process of driving with my garmin gps and my Gaia app open and put it on cruise control and see if it matched. If it was off pull over adjust the numbers again until I got. After 7 times of going from 36.5” tires all the way up 43.5” tires it finally matched up perfectly. So the hyper tech thinks I have 43.5” tires and 5.29 gears. So if you do this mod leave that cable installed so you don’t have to remove the dash again.
  6. Aug 5, 2019 at 3:23 AM
    #636
    Justincase76
    Justincase76 New Member
    Justin
    Mount Julio, TN
    2016 Tundra
    a lot
    Weird that it matched up with tires that aren’t even close to what is on it
  7. Aug 5, 2019 at 5:07 AM
    #637
    Jimes
    Jimes New Member
    Ya it’s really far off but according to both devices on cruise control on a long flat road it’s spot on at 43.5” tires. I’m not sure if it’s all in my head, but the truck does feel like it’s driving better. It’s supposed to adjust shift points. Now I also have a DAP tune and a pedal commander installed on the truck so not sure how or what is taking precedence over what cause the DAP tune is supposed to adjust shift points as well. But with my new gears and the way it’s setup I keep the pedal commander on City +2 and it wants to go. Before the gears I had to have it on sport +3 to make it move like it does now, but it was actually dumping more gas in the motor to achieve the same goal. If you don’t have gears yet I would highly recommend it and at least the hyper tech inline calibrator. I’m going to remove the DAP tune for fun just to see if that makes a difference or if the hyper tech is kicking that tune out.
  8. Aug 5, 2019 at 6:06 AM
    #638
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
  9. Aug 5, 2019 at 6:22 AM
    #639
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    Just sitting here on my 34's, scrolling through looking at all the big boy (and girl) trucks. One day.......
    SAGE63, Cfincke, CP17Tundra and 6 others like this.
  10. Aug 5, 2019 at 7:05 AM
    #640
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    It all starts with a dream..
  11. Aug 5, 2019 at 7:14 AM
    #641
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    And quickly becomes an obsession.
  12. Aug 5, 2019 at 11:58 AM
    #642
    matictundra
    matictundra [OP] New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Yup, I was on 34's but always wanted 37's. I had a chance and pulled the trigger.
  13. Aug 5, 2019 at 9:22 PM
    #643
    Treemite
    Treemite New Member
    AZ
    Hot sweaty day in the garage, got my bmc done and some minor trimming to the bumper end caps. I think I might need to trim a little more in front. Get some pictures up tomorrow. I'm still running the stock uca, can the tires be moved back any with a proper alignment? Running Toyo R/Ts
  14. Aug 5, 2019 at 10:33 PM
    #644
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    @Justincase76 and @Erichudgins got me all trying to keep up!:cheers: I finally got my truck back last week so the next round of updates are right around the corner! TRON looking fresh after the new DIRTY SEVENS, a new front end paint job, dent repair, and new front bumper powdercoat :cool: Also fixed the bedside/tailgate gaps and smoked the brake lights
  15. Aug 6, 2019 at 9:03 PM
    #645
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    :bowdown:
    TRON[QUOTED] likes this.
  16. Aug 6, 2019 at 9:34 PM
    #646
    TheBeast The Beach
    fresh fresh fresh !
  17. Aug 7, 2019 at 9:22 PM
    #647
    Treemite
    Treemite New Member
    AZ
    I towed a 2k trailer today up a pretty steep grade at 7,500ft. Was very surprised at how well it did with stock gearing, that 5.7 is a beast!
  18. Aug 8, 2019 at 4:54 AM
    #648
    ou77kg
    ou77kg New Member
    Erik
    2016 Tundra CM Platinum 4x4
    Great looking DC, one of my favorites so far. Well done on the build.
  19. Aug 15, 2019 at 9:29 AM
    #649
    Limber
    Limber New Member
    Chase
    to much to list
    Ok Im guessing with a -12 offset I would be doing alot of cutting to fit 37's right
  20. Aug 15, 2019 at 9:36 AM
    #650
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    What lift do you have?
  21. Aug 15, 2019 at 9:49 AM
    #651
    Limber
    Limber New Member
    Chase
    to much to list
    Currently just spacers but I'm getting ready to redo the front with either toytec 2.5 or ome 613 with and SPC UCA . I just put 35's on but getting ready for the next steps after I have the suspension gears and armour installed to finish the project
  22. Aug 15, 2019 at 9:55 AM
    #652
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    I wouldn't attempt 37s with a -12 with spacers or that lift. I have -18 wich is just a fuzz further out with a 7" lift and my 35s hit plastics everywhere and body mount at full turn. I Just put 38s on and have probably removed 10 lbs of metal and plastic to make them fit because of my negative offset . 37s need 0+ or big lift. But if you do attempt it take pics cuz I wanna see!
    tundra_20 and Mountun Goat like this.
  23. Aug 15, 2019 at 9:59 AM
    #653
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Definitely in on this one. 37 Nittos on ICON/TotalChaos setup with rear Airlift. Great looking trucks on this thread. A Tundra with 37s looks freakin sweeeeet:
  24. Aug 15, 2019 at 10:12 AM
    #654
    Limber
    Limber New Member
    Chase
    to much to list
    All I'm try is to find out what Offsets work. I hate the wheels I have and looking to change them as well in the process
    jewsNbrews and Mountun Goat like this.
  25. Aug 15, 2019 at 10:18 AM
    #655
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    If I remember correctly 0 is as far as I have seen with a 3inch on 37s but he also was having issues making them fit. @joonbug I think had 0 offset. But the more positive the easyer there going to fit
  26. Aug 15, 2019 at 10:33 AM
    #656
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah, 37’s with a 0 offset and only 2.5” of lift is pushing it. I should be fine once my new arms come in. But I also have an aftermarket front bumper and glass fenders. I honestly would not even attempt a negative offset.
  27. Aug 15, 2019 at 10:39 AM
    #657
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Something is not right here. Is your truck clean? Probably just a camera filter no way you put tire shine on?
  28. Aug 15, 2019 at 10:43 AM
    #658
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Pic was taken right after my annual car wash and those tires just got put on and America's Tire put a little tire dressing on it. I don't have any tire dressing so my tires will never look like this again. :anonymous:
    tundra_20, Rica25, jewsNbrews and 5 others like this.
  29. Aug 15, 2019 at 10:54 AM
    #659
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    You have a steel front bumper? I have the 613 springs on mine with the arb front bumper (no winch yet) and it’s stiff enough. I do run SPC uppers with coachbuilder shims. Body mount chopped and 37x12.5s on stock wheels. I run 1.5” wheel spacers up front to clear the tires on the uppers. (Anyone know what offset this would be?)
    Pic cause why not.
    jewsNbrews, Treemite and joonbug like this.
  30. Aug 15, 2019 at 11:06 AM
    #660
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Stock is +60 offset (yours could be different)
    1.5" = ~38mm
    so your resulting offset would be +22
    Edit: Someone should probably double check this
