DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Jul 9, 2019 at 4:37 PM
    #481
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    haha!! For sure, someone's alternator is going down, and steering bushings are definitely going to get smoked. I think we have a need....a need for speed! :burnrubber::bikewhoops: Where's the Top Gun Volleyball high five emoji on this piece?
  2. Jul 10, 2019 at 9:10 AM
    #482
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
  3. Jul 10, 2019 at 11:33 AM
    #483
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    Just saw this on YouTube. I wonder how long until they make this for the tundra? Full cab mount relocation kit. 37s will have so much room might have to go bigger!
  4. Jul 10, 2019 at 12:52 PM
    #484
    Justincase76
    Justincase76 New Member
    Justin
    Mount Julio, TN
    2016 Tundra
    a lot
    KevinK, Erichudgins and jewsNbrews like this.
  5. Jul 10, 2019 at 12:54 PM
    #485
    Justincase76
    Justin
    Mount Julio, TN
    2016 Tundra
    a lot
    with that many we can just go to Windrock and make all kinds of problems happen...
  6. Jul 10, 2019 at 2:08 PM
    #486
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    I can see it now..... " trying to fit 40s with shims and shackles" will have to relocate my body mount?"
  7. Jul 10, 2019 at 3:42 PM
    #487
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    With new body mount relocation the 37s be like...
  8. Jul 10, 2019 at 3:56 PM
    #488
    matictundra
    matictundra [OP] New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Not true with 3" lift because rubber mount itself still in the same location, you ending up interfering with rubber mount itself and actual body cab the more negative offset you have from ideal of +18mm to +25mm.
    KevinK, Mountun Goat and jewsNbrews like this.
  9. Jul 10, 2019 at 4:42 PM
    #489
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Agree to disagree. The way I see it from the video is if you remove a ridiculous amount of the body mount there is going to be alot more room for tires/negative offset regardless of lift size. Not an engineer by any means but i do know more room = more room for larger tire
    jewsNbrews and Mountun Goat like this.
  10. Jul 10, 2019 at 5:56 PM
    #490
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    That’s a rad mod. I like it!
    jewsNbrews likes this.
  11. Jul 10, 2019 at 7:11 PM
    #491
    Erichudgins
    Eric
    Murfreesboro, TN
    I'm gonna agree to disagree again.. unless your going with higher offset wheel or a larger lift the relocation of the body mount would be irrelevant. I've had to trim pinch moldings on the firewall.. I'm well clear of my body mount however. So even with relocation, with a 0 or negative offset wheel, at 3 inches of front lift, the firewall then becomes the limiting factor
    jewsNbrews, KevinK, TRON and 2 others like this.
  12. Jul 10, 2019 at 7:31 PM
    #492
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Oooh. I see what your getting at now. If your lift size/offset hits the pinch welds still then no it is not applicable to you. But this is the dirty seven club post some have more than a 3" and not having to worry about pinchwelds as much. That's the side I'm looking in from. But I do see what your saying now my bad
    jewsNbrews and matictundra[OP] like this.
  13. Jul 11, 2019 at 7:04 AM
    #493
    showtime240
    showtime240 New Member
    I'm gonna have to agree to really agree.
    This is correct, if you go outside of the range of the sweet offset, then the pinch weld and fender area come into play. The Body mount becomes irrelevant
  14. Jul 11, 2019 at 7:54 AM
    #494
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    :drool:
  15. Jul 11, 2019 at 10:45 AM
    #495
    KevinK
    Tundras to Sedona
    How stoned was that dude at the beginning? :rofl:
    and yeah, as others have said, for the Tundra, an aggressive chop is as much as you need (even for low lift, high offset). you can get it right up close to the firewall with a serious chop.
    In fact the most useful thing for more clearance would be if you could rotate the mount itself, more so than shifting the frame horn. As you can see I actaully trimmed right up and partway through the bolt.
  16. Jul 11, 2019 at 7:41 PM
    #496
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    Finally got my 37s. I know a little late to the show, but can’t wait to see how the truck drives with my new 5.29s and tires. I went with the 37x12.5r18s BF Goodrich km3s. Waiting on my truck to get back from the gear shop. Both lockers were leaking badly. Bad initial install. New shop was very picky and showed me all the issues in person and should be ready tomorrow. Then I can take it into the dealership to put the tires on and do the alignment.
  17. Jul 11, 2019 at 7:55 PM
    #497
    Jimes
    Jimes New Member
    I had no choice to get these. I need more clearance. I got my ass stuck messing around in Tahoe area trying to climb over a ledge. Bad angle and tow hitch was in the dirt and couldn’t go forward or backwards. I thought it was hilarious as that was my first time getting stuck. Wife not so much. Ha ha. Was just on a solo day trip and didn’t air down and just went about it all wrong. With no winch. I had to dig out the hitch and put a rock on my back tires to get out. Wish I got a side view pic. And like a dumb ass I left the key to my maxtrax at home. 3DA7FD5A-807C-41B1-A06A-136AE5FDF245.jpgBE299627-6DF0-4A9F-803E-F4AB0F84BDD6.jpg5F7D9F74-5E5A-4ED6-99F4-5276225EC1B4.jpgED0A8A1F-CDC2-4B90-BEEE-6DA6815BC33B.jpg
  18. Jul 12, 2019 at 7:31 AM
    #498
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Tried out this dune stuff out in Florence Oregon Dunes, had some pretty fun times.
    LRM-EXPORT-94761524923690-20190708-07055_0a65da2529fa777e1db94e4f5c38765f095e0d79.jpg
    LRM-EXPORT-94390175396383-20190708-06594_ba461840e0756ecfb5078341e9737efc77dc3153.jpg
  19. Jul 12, 2019 at 7:38 AM
    #499
    TheBeast The Beach
    fun !
    we got some closer in SoCal though :)
    5.7TRDProm[QUOTED] likes this.
  20. Jul 12, 2019 at 7:59 AM
    #500
    5.7TRDProm
    Dara
    I know... pismo, dumont, glamis, but I actually like it here more better... less foot traffic and not crowded ;)
    TheBeast[QUOTED] and jewsNbrews like this.
  21. Jul 12, 2019 at 8:43 AM
    #501
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    That's the PNW for you. Some awesome rural areas.
  22. Jul 12, 2019 at 9:05 AM
    #502
    escuzi_me
    William
    Nashville, TN
    Doesn't matter you are here at the show now! Looks glorious
    What dreams are made of! Didn't know I needed to add this to my list! @Erichudgins @Hattori @tbrown @lunchbox @Red Fox @jmevis @00Tyler10 @EAK you down?
  23. Jul 12, 2019 at 9:15 AM
    #503
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
  24. Jul 12, 2019 at 9:16 AM
    #504
    5.7TRDProm
    Dara
    And I love it! I dont have to worry about wandering kids because the parents are busy cheering drinks at a camp post or no over hill spotters while one is trying to send it for the gram. Sadly, my trip is about to come to an end in 2 more days, been on the road around since the 4th.
  25. Jul 12, 2019 at 9:16 AM
    #505
    Justincase76
    Justin
    Mount Julio, TN
    2016 Tundra
    a lot
  26. Jul 12, 2019 at 9:18 AM
    #506
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Next time come up to the east side...juniper dunes is awesome just outside Tri-Cities Wa.
  27. Jul 12, 2019 at 9:19 AM
    #507
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    :sawzall::welder::spending:is all it takes!
    escuzi_me, BlackSheep and tbrown like this.
  28. Jul 12, 2019 at 9:24 AM
    #508
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    I only had 35’s for a while too...it’s a matter of time my friend
    escuzi_me and jewsNbrews like this.
  29. Jul 12, 2019 at 9:39 AM
    #509
    escuzi_me
    William
    Nashville, TN
    It can be done!
  30. Jul 12, 2019 at 9:54 AM
    #510
    5.7TRDProm
    Dara
    I'll keep that in mind!
