DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Jun 1, 2019 at 3:51 PM
    #331
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    How much lift and what offset does your brother have? @Jman245 is trying to run 0 offset on 3” lift. I don’t think that will work with the stock UCA. Unless the bmc goes all the way into the firewall maybe?
    Jman245[QUOTED] likes this.
  2. Jun 1, 2019 at 4:58 PM
    #332
    matictundra
    matictundra [OP] New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    He is running +25mm.
    Jman245 likes this.
  3. Jun 2, 2019 at 7:17 AM
    #333
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
    That is the kicker! With the 0 offset, I would have to do a more aggressive bmc. Or would uca's help me enough to get away from that? Im thinking bumper spacers too.... thanks guys for all the help!
  4. Jun 3, 2019 at 1:52 PM
    #334
    Yota100
    Yota100 New Member
    14 Tundra 4x4 97 T100 4x4
    14 Tundra 2.5 kings all around with remote reservoir and adjusters with 700# springs Total chaos bushing style control arms Camburg 1.5 inch lift shackles Coachbuilder polt bushings in leaf springs Bmc and front bumper trimmed 37x12.50x17 toyo MTs 17 inch Icon rebounds +25 offset 5% tint Winjet taillights True dual flowmaster super 40s ARB summit bumper Smittybuilt 12k winch White Knuckle Offroad sliders
    well 37s have been ordered with new wheels
    SK_Tundra, escuzi_me, Berdine and 6 others like this.
  5. Jun 3, 2019 at 2:10 PM
    #335
    showtime240
    showtime240 New Member
    Are you guys looking at the weight of the tires?
    They vary allot.
    For example: 37 12.5/17s
    Toyo RT = 79lbs
    Nitto Ridge Grappler = 81.48lbs
    Flaken Wildpeaks AT3 = 82.5lbs
    BF Goodrich KO2 All Terrain = 69.49lbs
    Nitto Terra Grap = 75.13lbs
    Cooper AT3 = 68lbs
    Cooper Max = 79lbs
    I didnt really look at any MTs
    SK_Tundra, Mountun Goat and escuzi_me like this.
  6. Jun 3, 2019 at 2:14 PM
    #336
    Yota100
    Yota100 New Member
    on toyo MTs it was a 6 pound difference if i remember right between 35 and 37 on a 17 inch wheel
    Mountun Goat likes this.
  7. Jun 3, 2019 at 3:43 PM
    #337
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    :eek:
    That’s a much bigger difference than I thought between ko2 and Toyo or Nittos. Is it different rubber compounds or nobs that make that much difference?:confused:
    Mountun Goat and jewsNbrews like this.
  8. Jun 4, 2019 at 6:41 AM
    #338
    showtime240
    well technically they are classified as a different tire
    An All Terrain Tire will most always weigh less than a Mud Terrain Tire
    However, now manufactures have created a hybrid tire like the RTs or Ridgegrapplers hence the different weights when compared to the all terrain KO2 or Coopers
  9. Jun 4, 2019 at 8:29 AM
    #339
    matictundra
    Franco
    AZ
    I weigh my wheel and tire, came out to 110 lbs.
    Mountun Goat, showtime240 and Berdine like this.
  10. Jun 4, 2019 at 1:46 PM
    #340
    showtime240
    Which tires did ya go with?
    I'm thinking K02s at 69lbs and the Methods I am looking at are 31lbs
  11. Jun 4, 2019 at 2:45 PM
    #341
    matictundra
    Franco
    AZ
    I went with Nitto Ridge Grappler 37x12.5 and Fuel vector 20x9+20mm.
  12. Jun 4, 2019 at 3:03 PM
    #342
    smy
    smy New Member
    Have you guys replaced the oem jack? If so, with what? looking to replace with a bottle neck jack and hopefully have it fit where the oem went. Tried a 21" max jack but it's just quote not enough to change the tire (when needed).
  13. Jun 4, 2019 at 3:07 PM
    #343
    matictundra
    Franco
    AZ
    I'm using the oem bottle jack with 1 2x8x8 and 2 2x4x6 wood. My plan is use the 2x8x8 as base and the two 2x4x6's to the vehicle side. Luckily, I haven't done this on the trail or on the road but tested in the garage.
  14. Jun 4, 2019 at 3:11 PM
    #344
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    Ugh.. seeing you guys on 37s... gave me an itch. dammit. I would have to get different wheels (offset) to get another 2 inches taller tho. Pic on 25s
    Would like to fill that fender a lil more.
  15. Jun 4, 2019 at 3:37 PM
    #345
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    :sawzall:
  16. Jun 4, 2019 at 9:21 PM
    #346
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
  17. Jun 4, 2019 at 9:25 PM
    #347
    Duneflyer
    Darren
    Yuma AZ
    I have an aluminum floor jack with blocks. Goes in the tool box perfectly.
    Watt maker and Mountun Goat like this.
  18. Jun 5, 2019 at 5:44 AM
    #348
    escuzi_me
    William
    Nashville, TN
    Send it!
  19. Jun 12, 2019 at 10:27 AM
    #349
    KevinK
    Tundras to Sedona
    Yeah 25 or so is the sweet spot.
    For 0 offset to work, you need:
    Adjustable UCA like the icon billet, aggressive bmc, cut stock bumper (spacers don’t move it far enough and make it look funny), stock skid plate trim or replacement, sway bar delete, a shop willing to perform your alignment correctly by using the UCA heims.
    BFG 37s are so light because they’re actually 36 inches and not 37. Somewhere I have pics of our Toyo RT 37s next to our friend’s BFG “37s” and the difference is enough to make you sick.
    My buddy just bought some Patagonia Milestars in 37 for like $200 each. They have decent reviews and a pretty light weight.
    joonbug and escuzi_me like this.
  20. Jun 12, 2019 at 10:28 AM
    #350
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
  21. Jun 12, 2019 at 10:28 AM
    #351
    Yota100
    Yota100 New Member
    Should be joining this club tomorrow truck bed full of 37s!
  22. Jun 12, 2019 at 10:33 AM
    #352
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Dont just say sht to say it. Post the proof
  23. Jun 12, 2019 at 10:36 AM
    #353
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Heres mine, 37 cooper stt pro
    But I refuse to call them "dirty sevens" :rolleyes::rolleyes::rolleyes:
  24. Jun 12, 2019 at 10:41 AM
    #354
    escuzi_me
    William
    Nashville, TN
    great looking rig!!
    osidepunker[QUOTED] likes this.
  25. Jun 12, 2019 at 10:44 AM
    #355
    osidepunker
    Alex
    2013 Tundra DC 4x4
    thx homie!
  26. Jun 12, 2019 at 11:47 AM
    #356
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Do you have decals/graphics along your bedside?
  27. Jun 12, 2019 at 11:50 AM
    #357
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
  28. Jun 12, 2019 at 1:12 PM
    #358
    5.7TRDProm
    Dara
    Very... just saying :yes:
    Erichudgins[QUOTED] likes this.
  29. Jun 12, 2019 at 1:43 PM
    #359
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    ? Nope
  30. Jun 12, 2019 at 2:59 PM
    #360
    KevinK
    Tundras to Sedona
    I was being nice to my friend.
    Erichudgins and joonbug like this.
