DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Apr 22, 2024 at 5:16 PM
    #3301
    contenderv07
    contenderv07 New Member
    Will
    Thanks I’m not too worried about acceleration , but I had a wrangler with 37s 9 stock gearing) and whoa it was awful:rofl:
    Uhhhh....[QUOTED] likes this.
  2. Apr 23, 2024 at 9:17 PM
    #3302
    allen_rubin
    allen_rubin New Member
    Allen
    2016 SR5 TRD 4x4 Crew Max
    King 2.5's with Camburg Uniball UCA Deaver u748 w/ TC Shackle Fuel Hype 17X8.5 10MM 37X12.5-17 BFG KO2 "Stock Gears" Alpha REX Pro Headlight and Tail Lights Custom Carven Side Exit exhaust ADD Front & Rear Bumpers along with Side Steps Westin Topper / Westin Power side steps
    It’s really not that bad
    contenderv07[QUOTED] likes this.
  3. Apr 29, 2024 at 11:09 AM
    #3303
    hotchops777
    hotchops777 New Member
    Matthew
    EAST TEXAS
    2011 5.7 Silver Sky DC
    6" Procomp Stage 2 lift Black Rhino Sierra 20x10 0 offset on 325x65x20 Nitto Ridge Grapplers Smitty Built M1 front grill
    I recently re-did all my suspension. I'm getting a rear creak/squeak and i cant trace it down. Heres what i have done.
    I replaced the rear leaf springs w/ Deaver U748 and eliminated the lift block. The leaf was installed with the provided bushing for the front from deaver and the bushing provided by Coachbuilder for my Shackle for the rear.
    I also replaced the shock with RC Vertex.
    I've traced down everything on the above parts and have spoken with both build owners. Verified the correct bushing are installed.
    Is this a rear thing for break in period (installed Feb 24) or should i check anything else. Its def coming from the shock leaf spring area but its all brand new and greased. Ive re torqued the ubolts and bolts for both shackle and front of leaf, and the shock.
    I know i need to get a video uploaded but haven't had help to stand on bumper to promote the noise.
    brodesiansneverdie and coTony like this.
  4. Apr 29, 2024 at 11:15 AM
    #3304
    coTony
    Tony
    Montrose, CO
    Nothing common to your setup and mine except the Coachbuilder shackles. I have gotten noise from back there every since I installed everything for 5 years now
  5. Apr 29, 2024 at 11:21 AM
    #3305
    hotchops777
    Matthew
    EAST TEXAS
    Ahh bummer... i know lifts are noisy but this shouldnt be the case when everything is new. Thanks @azTony
    coTony likes this.
  6. Apr 29, 2024 at 11:23 AM
    #3306
    coTony
    Tony
    Montrose, CO
    FWIIW mine was new from the factory and sounded like that but I was told that is the nature of the beast with leaf springs
    CaptRussia253 likes this.
  7. May 11, 2024 at 1:56 PM
    #3307
    Branmuffin
    Branmuffin New Member
    2019 MGM TRD Sport
    Do you have any pictures that show how much poke you have, pretty much looking at this exact setup for my own truck
  8. May 17, 2024 at 9:33 AM
    #3308
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    Anyone know of a good shop in the NorCal area that could do re-gearing?
  9. May 18, 2024 at 5:56 AM
    #3309
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    stellarbuilt?
  10. May 18, 2024 at 3:27 PM
    #3310
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I’m having stellarbuilt do mine, they have a great reputation
  11. May 18, 2024 at 5:42 PM
    #3311
    2TunGet1
    Have you scheduled it yet? Are you doing 5.29’s? What brand are you going with?
  12. May 19, 2024 at 5:24 PM
    #3312
    Js18tundra
    Not yet, still saving Pennie’s, yes I’m going 5.29’s with an auburn grip n loc in the rear
  13. May 22, 2024 at 9:12 AM
    #3313
    brodesiansneverdie
    brodesiansneverdie New Member
    2020 White Tundra SR5 CM
    Toytec Aluma 2.5/2.0 SPC UCAs U748s Method 705s Toyo AT3 285/75r17 RCI Aluminum skid OTT tune Softopper Decked V2 Diode Dynamics
    Just stumbled upon this. I just did basically the same swap you did about 1500 miles ago (MCM Shackles instead of Coachbuilt), and developed a noise at about the 1000 mile mark. I'm going to probably pull everything apart to see if I could have lubed any of the bushings/sleeves better in the next few thousand miles when I upgrade rear shocks, but it sounds like it may just be life with U748s.
    Just out of curiosity, what type of lube did you use on the bushings/sleeves?
  14. May 22, 2024 at 10:50 AM
    #3314
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  15. May 22, 2024 at 4:38 PM
    #3315
    brodesiansneverdie
    Glad to hear it! That's what I'll be going with when I re-lube. I went with the same stuff I use for my SPC joints which energy suspension should work fine, but I suspect that's where at least some of my noise is coming from.
  16. May 22, 2024 at 5:48 PM
    #3316
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Define NorCal, I know of several good shops from Monterey to Auburn
  17. May 23, 2024 at 6:25 AM
    #3317
    2TunGet1
    Willing to drive anywhere in NorCal provided it’s a good shop. Preferably around Sacramento to Auburn.
    I drove to Las Vegas to have my suspension done.
  18. May 23, 2024 at 6:38 AM
    #3318
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Stellarbuilt in Sacramento has an outstanding reputation in the Toyota community. Or Chance at Califab in Sacramento, a buddy of mine had some work done there and says Chance's work is absolutely second to none.
    2TunGet1[QUOTED] likes this.
  19. May 23, 2024 at 10:24 AM
    #3319
    rockmup
    rockmup New Member
    Todd
    WFO Concepts is in Auburn, great guys.
    Lavender Brothers in Seaside- Toby Lavender is the owner.
    Wayside Automotive in Seaside - My brother Sam owns 3 shops
    All of these guys have great reputations.
  20. May 23, 2024 at 12:06 PM
    #3320
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    That is a terrible vehicle, it'll give you a lot of problems, why don't you let me come pick it up and remove it off your property.
    V3N0M and CaptRussia253 like this.
  21. May 28, 2024 at 10:44 PM
    #3321
    jeri3EAR
    jeri3EAR New Member
  22. May 29, 2024 at 9:59 AM
    #3322
    hotchops777
    Matthew
    EAST TEXAS
    Im kicking myself, I have the deavers installed backwards. They were correct left and right but i had to flip both sides. Once i did that everything went whisper quite. They were installed wrong for 6 weeks. I work remote and hardly drive and deaver said it happens all the time. I just used a blue all purpose poly grease i had in the shop/ dont know the brand sorry.
  23. May 29, 2024 at 1:48 PM
    #3323
    brodesiansneverdie
    I've put some more miles on them and mine have actually gotten a lot quieter. Can't tell if that's good or bad lol, but self clearancing is still clearancing.
  24. Jun 4, 2024 at 12:16 PM
    #3324
    Orange 2017
    Orange 2017 New Member
    2017 lifted and supercharged
    My 2017 inferno orange on 37/12.5/20
  25. Jul 1, 2024 at 2:51 PM
    #3325
    Kantoosion
    Kantoosion New Member
    J
    SD
    Inferno Crewmax
    Finally joined the Dirty 7 Club! :yes:
    Nitto Recon Grapplers 37x12.5x18
    SAGE63, V3N0M, CaptRussia253 and 4 others like this.
  26. Jul 13, 2024 at 7:45 AM
    #3326
    allen_rubin
    Allen
    With the new leafs did it at 2” of lift in the rear? I just installed mine with a 1” shackle and it lifted the rear to have about a 2” rake now like from factory lol do these settle at all?
  27. Jul 14, 2024 at 12:14 PM
    #3327
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    They’ll settle a bit, but I’m pretty sure I’ve got more than 2” from mine after a couple years, about 70,000 miles, with about 10K of those towing. My truck is also a fat 7,200# pig with plenty of weight on the rear.
    I probably had 4” lift in the rear when I first out the U748s in. Still a heave 2” I’m sure.
    Wish they made a spring that performed like this model, but with only 1” lift.
  28. Jul 14, 2024 at 12:20 PM
    #3328
    allen_rubin
    Allen
    yea, I have a 1” shackle, going to put in the 3/4”. But the rake is a little much haha
  29. Jul 16, 2024 at 7:58 PM
    #3329
    Js18tundra
    you got 4”? With a 1” shackle? How much weight on them when towing? How much did they sag when towing?
  30. Jul 16, 2024 at 8:51 PM
    #3330
    Chad D.
    Chad D. New Member
    Western Oregon
    My shackles are +1.5” OAL, so closer to 0.75” lift from them.
    I didn’t take accurate measurements, but it was pretty tall till the springs broke in! Sits about perfect now, with just a little rake.
    Every day, it has a canopy, Bedslide, box of tools and gear, and a 50L Dometic fridge full of beers. 100# spare tire under the bed.
    Towing my travel trailer, it’ll squat pretty hard till I get the WDH set. Then it’s nice again. My tongue weight is around 800#. The springs are legit and handle everything I have thrown at them. After they broke in and settled, they’re perfect for my use.
    reywcms likes this.
