DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. May 20, 2019 at 12:59 PM
    #301
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Even with a +25, you still have to trim for articulation
    Gee Dub, Yota100 and jewsNbrews like this.
  2. May 20, 2019 at 1:01 PM
    #302
    Yota100
    Yota100 New Member
    14 Tundra 4x4 97 T100 4x4
    14 Tundra 2.5 kings all around with remote reservoir and adjusters with 700# springs Total chaos bushing style control arms Camburg 1.5 inch lift shackles Coachbuilder polt bushings in leaf springs Bmc and front bumper trimmed 37x12.50x17 toyo MTs 17 inch Icon rebounds +25 offset 5% tint Winjet taillights True dual flowmaster super 40s ARB summit bumper Smittybuilt 12k winch White Knuckle Offroad sliders
    Yeah not as much tho. I've pretty much sold myself on the +25 haven't placed the order just yet
    Erichudgins and Berdine like this.
  3. May 20, 2019 at 1:46 PM
    #303
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Start with plus 25... @tbrown has +25 and hes on 13.5s... 0 offset looks nice but +25 would be more friendly
    KevinK, Berdine, Watt maker and 3 others like this.
  4. May 20, 2019 at 2:16 PM
    #304
    smy
    smy New Member
    You should expect a bit more cutting if going with 0 offset.
    Berdine likes this.
  5. May 20, 2019 at 2:31 PM
    #305
    matictundra
    matictundra [OP] New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I kept mine because 95% of it's life will be on pavement. Plus, I really don't rock crawl.
    Berdine likes this.
  6. May 20, 2019 at 2:47 PM
    #306
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I like scaring people going around corners at the red light @ 40-50mph with that ganagsta lean #nosway
  7. May 20, 2019 at 7:40 PM
    #307
    smy
    smy New Member
    makes sense. I'm assuming you aren't rubbing the front sway bar then?
    Mountun Goat likes this.
  8. May 21, 2019 at 8:01 AM
    #308
    showtime240
    showtime240 New Member
    On CST website, it states must use 18" wheels or large with the CST Spindles. How were you able to use 17"?
  9. May 21, 2019 at 8:53 AM
    #309
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    The backspacing specs on the Method wheels in a 17" clear the tie rod.
  10. May 21, 2019 at 9:18 AM
    #310
    showtime240
    oh man bad ass! Ive been in the mood to change up my setup!
    What is your total lift? I also have the CST spindles with OME 614s & two shims for an 8inch lift with 37s now.
    but I got a great deal on 6112s... so thinking about dropping it back down a bit with 17/18s and 37s
  11. May 21, 2019 at 9:43 AM
    #311
    sdhq_offroad
    GILBERT, AZ
    I would say roughly 3.75-4" total? Zero preload in the coilovers.
    BajaTurd and showtime240[QUOTED] like this.
  12. May 21, 2019 at 2:23 PM
    #312
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    It's awesome to see so many getting onto 37s!
    Did you also change your uppers to heimed adjustable ones for the 0 offset? I can't remember.
    For us to get 100% articulation and no rub, we had to push the LCA as far forward as possible even with the aggressive BMC. Then we use the heims on the UCA to dial in the alignment. Even then we run a pretty low amount of caster in order to stay off the body mount when fully tucked and turned. (the lower caster also helps in rock crawling situations)
    Don't think I've posted in here for a while.
    95FCCBB1-169A-4686-8DBB-B51499305189.jpg FBEC8A0A-7369-45E3-9C40-1500621C24F4.jpg
  13. May 22, 2019 at 8:05 AM
    #313
    showtime240
    So you went with the 17" Methods that have the Zero offset?
    That means with the CST Spindles kicking out each front wheel an extra 1 inch/25.5mm, the real offset is -25.5mm?
    How much trimming did you do for 4 inch lift, -25 offset and 37s?
  14. May 22, 2019 at 8:34 AM
    #314
    Erichudgins
    Eric
    Murfreesboro, TN
  15. May 22, 2019 at 9:50 AM
    #315
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    :bowdown:
    Erichudgins[QUOTED] likes this.
  16. May 22, 2019 at 10:05 AM
    #316
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    Truck is looking ridiculous man:thumbsup: Get that thing in the dirt:cheers:
  17. May 22, 2019 at 10:56 AM
    #317
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    daaaayyyyuuuum. good thing it's white or else i'd never be able to stop staring at it :wink:
  18. May 22, 2019 at 11:12 AM
    #318
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    What more can I say.....
  19. May 22, 2019 at 11:59 AM
    #319
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    That's a slick looking truck my friend!
  20. May 22, 2019 at 12:17 PM
    #320
    matictundra
    Franco
    AZ
    Correct, no rub.
    Erichudgins, Berdine and Mountun Goat like this.
  21. May 24, 2019 at 7:24 AM
    #321
    Kwint23
    Kwint23 New Member
    Ken
    2018 Tundra CM
    Ok I'm wanting to do 37's now seeing all your guys trucks. I have 6112's in the front on the top setting and coach builder shackles on the rear. Wanting to put icon 6 speed wheels on it. Would I be able to fit them like this or will I have to do ucas. If I have to do Bmc and remove away bar I will. And the other question is do your trucks still fit in your garage with a 7 ft door. And any vendors that you would recommend for said wheels.
  22. May 24, 2019 at 10:10 AM
    #322
    Berdine
    Binghamton, NY
    @matictundra has the same setup, used jba ucas, but not needed. Just added piece of mind.
  23. May 24, 2019 at 5:19 PM
    #323
    Yota100
    Yota100 New Member
    Six speed would be good since you can get the +25 offset
    Mountun Goat and Erichudgins like this.
  24. May 28, 2019 at 1:08 PM
    #324
    KevinK
    Tundras to Sedona
    Talk to Joey at @sdhq_offroad for the parts. He knows what you need and can get it all.
    Mountun Goat, Erichudgins and Berdine like this.
  25. May 30, 2019 at 4:53 AM
    #325
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
    Do those uca's give you the added caster? Im on 3 inch lift with 0 offset wheels and bmc
    Mountun Goat and Berdine[QUOTED] like this.
  26. May 30, 2019 at 2:31 PM
    #326
    matictundra
    Franco
    AZ
    Yes. But I did my bro truck with stock UCA and it's fine with 37X13.5 tires.
  27. May 30, 2019 at 5:23 PM
    #327
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Thanks!
  28. Jun 1, 2019 at 5:57 AM
    #328
    Monkeyballs
    Monkeyballs New Member
    Kelly
    2014 black platinum
    Lifted
    What kind of tire pressure are guys running in your 37’s
  29. Jun 1, 2019 at 7:38 AM
    #329
    matictundra
    Franco
    AZ
    Call the tire manufacturer and they will calculate for you (you will need the truck info for baseline to calculate) or do the chalk mark (more accurate). I did both and they came within 1 psi of each other. I’m running 36 psi at the front and 34 psi at the rear.
  30. Jun 1, 2019 at 7:54 AM
    #330
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I run 35 up front and 32 in the rear. I chalk my tires and check the wear pattern. This setup seems to be nice and flat and feels proper also
    tundra_20 and Berdine like this.
