Dirty Deeds!
Discussion in 'Dirty Deeds Industries' started by Munk, Feb 24, 2018.
  1. Apr 14, 2018 at 10:08 AM
    #61
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Do try to loosen the nut or bolt? All this rust I can't really tell @dirtydeeds
  2. Apr 14, 2018 at 10:09 AM
    #62
    Thee_Oddball
    Thee_Oddball New Member
    Eric
    Chicago
    2013 Double cab 4x4 5.7L, 78,000 miles, Nautical blue.
    do you drive through pools of salt everyday????
    15whtrd and Pudge[QUOTED] like this.
  3. Apr 14, 2018 at 10:11 AM
    #63
    Pudge
    CT
    Pretty much all winter around here. And I'm pretty good about giving the underside a bath when I can during winter
    15whtrd likes this.
  4. Apr 14, 2018 at 10:15 AM
    #64
    Pudge
    CT
    Maybe this will help?
    Stormtrooper81, Casper3 and 15whtrd like this.
  5. Apr 14, 2018 at 10:18 AM
    #65
    15whtrd
    15whtrd Mr. Blonde
    Hit it with a wire wheel or brush and some penetrant. Let it sit and go for it. Maybe you should have some replacements on deck too.
  6. Apr 14, 2018 at 10:21 AM
    #66
    Pudge
    CT
    Yeah I'll let the pb blaster sit. I'm thinking I may not get this done today
  7. Apr 14, 2018 at 10:23 AM
    #67
    PB is good stuff. Great for cleaning rims...
  8. Apr 14, 2018 at 10:26 AM
    #68
    dirtydeeds
    Keith
    USA
    more than I can list here
    The nut is welded to the mid pipe. So you’re trying to remove the bolt in this case.
    Really sorry to see all that rust.
    15whtrd, Pudge and Black Wolf like this.
  9. Apr 14, 2018 at 10:27 AM
    #69
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You might need some heat too, like a propane torch. Or a grinder to cut the bolts. Just be careful, obviously.
  10. Apr 14, 2018 at 10:28 AM
    #70
    Pour some syrup on it..................should loosen it up.......:cookiemonster::facepalm:
    Ike74, Casper3, 15whtrd and 1 other person like this.
  11. Apr 14, 2018 at 10:30 AM
    #71
    dirtydeeds
    Keith
    USA
    After a drive, right when you get home while exhaust is still hot, drench with PB. rhe Pores of the metal are all opened up when hot.
  12. Apr 14, 2018 at 10:41 AM
    #72
    Pudge
    CT
    If I do have to cut. I cut the nut and bolt head off? Or just start with nut?
  13. Apr 14, 2018 at 10:51 AM
    #73
    15whtrd
    15whtrd Mr. Blonde
    If you’ve got another car to drive I think you should just go for it and roll the dice. If the bolt snaps go get a stainless one at the hardware store.
    gorillanibbles likes this.
  14. Apr 14, 2018 at 11:00 AM
    #74
    Pudge
    CT
    I've got 3 of the 4 loose a little at a time. The 4th one won't grab and spears rounded off so I think I'll have to cut it. Sucks.
  15. Apr 14, 2018 at 11:02 AM
    #75
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Pudge likes this.
  16. Apr 14, 2018 at 11:03 AM
    #76
    Pudge
    CT
    I worry if I cut it I still won't get it out cuz of the rust
  17. Apr 14, 2018 at 11:05 AM
    #77
    Pudge
    CT
  18. Apr 14, 2018 at 11:09 AM
    #78
    UTTundra
    UTTundra New Member
    Lou
    Utah
    If you try the extractors, use a hammer to tap it onto the bolt head so its on there good and tight before attempting to turn.
    Stormtrooper81 and Pudge[QUOTED] like this.
  19. Apr 14, 2018 at 11:11 AM
    #79
    Pudge
    CT
    Thanks man. You think it's ok to use in impact gun? That's the only way I can get these Bolts to budge
    Edit Irwin description says air gun is ok. But it's 3/8 so I'll need a step down which scares me it'll break
  20. Apr 14, 2018 at 11:14 AM
    #80
    UTTundra
    UTTundra New Member
    Lou
    Utah
    With the extractor? Not sure if they're designed to be used in with an impact, but if you can't get it by hand...
    I do think Irwin makes a separate set that are designed for impact use.
  21. Apr 14, 2018 at 11:49 AM
    #81
    Pudge
    CT
    I'm at Lowe's now. I have the extractor which I'll try. If I have to cut what size bolt? I forgot to measure @dirtydeeds @UTTundra
  22. Apr 14, 2018 at 11:50 AM
    #82
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    If you have files try and smooth the drive head of the bolt, remove as much rust as you possibly can with a wire wheel or brush. Check to see how the socket fits and if it’s still tight, spray the life out of it with pb or mouse milk or aero Kroil. If the socket is slightly loose put some aluminum tape inside of it. Turn your impact to its lowest setting and hammer on it to help work the oil in, sometimes it helps to hit it in the tightening direction lightly to break the rust and then start going back and forth all while spraying it.
    Good luck!
    15whtrd and Pudge like this.
  23. Apr 14, 2018 at 12:00 PM
    #83
    UTTundra
    UTTundra New Member
    Lou
    Utah
    14mm head with a M10 1.25 x 35 pitch is what I'm seeing on other posts
    Pudge[QUOTED] likes this.
  24. Apr 14, 2018 at 12:03 PM
    #84
    Pudge
    CT
    Thank you sir!
    UTTundra[QUOTED] likes this.
  25. Apr 14, 2018 at 12:25 PM
    #85
    Pudge
    CT
    UTTundra likes this.
  26. Apr 14, 2018 at 12:36 PM
    #86
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Hell yea! Nothing like giving a stubborn bolt an ass whoopin'. Did you get the impact set or the regulars?
  27. Apr 14, 2018 at 12:39 PM
    #87
    Pudge
    CT
    Impact. Needed it
  28. Apr 14, 2018 at 1:13 PM
    #88
    Pudge
    CT
    Almost done. I forgot clamps for the resonator. Working on that now
    Stormtrooper81 likes this.
  29. Apr 14, 2018 at 1:49 PM
    #89
    Pudge
    CT
  30. Apr 14, 2018 at 1:55 PM
    #90
    Rica25
    Ricardo
    Tulare
    The resonator comes with clamps
    15whtrd likes this.
