Dirty Deeds Injectors
Discussion in '1st Gen Tundras (2000-2006)' started by Hooptytrix, Jun 9, 2020.
  1. Jun 28, 2020 at 6:35 PM
    #61
    Hooptytrix
    Hooptytrix [OP] Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
  2. Jun 28, 2020 at 6:49 PM
    #62
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I don't even have a shade tree to turn wrenches under, so maybe this will be a cool weather project.
  3. Jun 29, 2020 at 4:47 AM
    #63
    Professional Hand Model
    Hand Protectors
    I guess this makes you NOT a Shade Tree Mechanic like @FrenchToasty
  4. Jun 29, 2020 at 5:06 AM
    #64
    Rex Kramer
    Georgia
    True, and I am happy to jump into the water - no pushing is necessary.
  5. Jun 29, 2020 at 9:16 AM
    #65
    skywalker474
    skywalker474 New Member
    san diego
    06 DC 4x4 trd
    I was chasing some rich codes, and in the process of fixing, decided to try keiths injectors, since mine were pushing 250k.
    Fuel trims are nice now. Havrnt driven through a full tank yet to see mpg.
    06 DC, 1.5hrs total time.
    Was a little hesitant, but its not bad. I didnt even loosen the 17mm banjo or the pcv hose. Just the 10mm nuts for the rail, and one 10mm bolt on the backside. Theres enough room to wiggle the rail up.
  6. Jun 29, 2020 at 12:24 PM
    #66
    Hand Protectors
    Are you measuring fuel trims with a device? If so, what are you using.
  7. Jun 29, 2020 at 1:15 PM
    #67
    NWPirate
    Zach
    WA
    :popcorn:Nice thread.
    Looks like a good list of preventive maintenance I could do on my wife's sequoia. I read somewhere there was one O2 sensor that was a bastard to reach, any truth to that?
  8. Jun 29, 2020 at 1:22 PM
    #68
    Hand Protectors
    Having just done all 4 on my 2002, I can say the rear o2’s were tricky as the 4 nuts were rusted and needed cutting off. Once those nuts were removed the put back was simple. As far as the fronts, I found both challenging as the connectors were difficult to properly access and not ruin the harness.
    NWPirate[QUOTED] likes this.
  9. Jun 29, 2020 at 1:26 PM
    #69
    NWPirate
    Zach
    WA
    Gotcha, thanks.
    Someone said they had to pull the exhaust manifold to get to one. Could of been operator error though.
  10. Jun 29, 2020 at 1:52 PM
    #70
    Hooptytrix
    Dirty South
    I had a lot of trouble with the 1 by the manifold on driver's side. Ultimately I had my buddy take care of it
  11. Jun 29, 2020 at 2:00 PM
    #71
    Hand Protectors
    If you have Golden Hands, then there is no need for a buddies help. The Gorilla Arm Technique coupled with Sun Zsu Screwdriver Twist Technique yields success. Multiple disciplines yield Victories every time Grasshopper.
    bmf4069 and NWPirate[QUOTED] like this.
  12. Jun 29, 2020 at 2:17 PM
    #72
    NWPirate
    Zach
    WA
    I'll YouTube that, can't quite picture that technique :rofl:
    bmf4069 likes this.
  13. Jun 29, 2020 at 2:28 PM
    #73
    Hand Protectors
    Sensei couldn’t see but he could picture. Look and find.
  14. Jun 30, 2020 at 10:57 AM
    #74
    skywalker474
    san diego
    06 DC 4x4 trd
    Just a basic $100scanner, under live data. Long term should be less than 10 for normal, or its compensating, if my undersranding is correct. Mine was over 20 near idle low rpm, suspecting leaky injectors, since full pressure full throttle numbers were fine. But back to single digits now all around.
    Side post for O2 stuff.
    i had a hastle with the pass side O2 on the manifold. Even sawzalled the top off to get a good socket on it after trying everything else. Instead of pulling the manifold, i pulled the 2ft exhaust section just after and machined a nut into a bung, welded it in, and just relocated new O2 like less than 4" downstream which should effectively be nothing.
  15. Jun 30, 2020 at 1:19 PM
    #75
    Hooptytrix
    Dirty South
    The fuel trims cfl is most likely the upstream o2 sensors. I have/had the same issue. Replace all 4 02 sensors
    skywalker474[QUOTED] likes this.
  16. Jun 30, 2020 at 8:00 PM
    #76
    skywalker474
    san diego
    06 DC 4x4 trd
    I would agree with that being the likely cause, but i replaced them prior to this prob due to lean codes, fine for 4months, then rich codes lol.
  17. Jun 30, 2020 at 8:05 PM
    #77
    Hooptytrix
    Dirty South
    Sounds like you went exactly the same direction as I. All sensors replaced and the injectors. My truck is running damn good at the moment but still not 100%
    I removed the coolant lines from the throttle body and rerouted them. At least the cfl hasn't come back yet
  18. Jun 30, 2020 at 8:11 PM
    #78
    skywalker474
    san diego
    06 DC 4x4 trd
    Hopefully were good for another 200k!
    sas bypass, some O2 sensors and injectors isnt too much to ask for a 14yr old truck.
  19. Jun 30, 2020 at 8:18 PM
    #79
    Hooptytrix
    Dirty South
    Hard to believe it's 15 years old, running smoothly and plenty of power. I'm sitting at 104k miles and basically ran through a shit load of maintenance. Hopefully I will good for the next decade
  20. Jun 30, 2020 at 8:41 PM
    #80
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It’s a baby at 104k. Mines at 200k and it runs like a top After being rolled over!
  21. Jun 30, 2020 at 8:52 PM
    #81
    Hooptytrix
    Dirty South
  22. Jul 4, 2020 at 1:27 PM
    #82
    04TundraTRD
    04TundraTRD Once upon a time....
    Neil
    Kentucky, near Louisville
    2004 Tundra TRD 4WD AC
    TRD Supercharger, Bilstein 5100's on all four corners, Setting 4 on the fronts, 1" Front Diff Drop Kit, Suspensionmaxx Front Sway bar end links, 1" lift shackles out back, 1.5" wheel spacers all around, 285/75R16 BFG AT TA/KO2's, Front Brush Guard with 20" LED light bar, Kool Vue Dodge style tow mirrors, Yellow Box Speedo Corrrecter by Yellr, Volant CAI, Banks Monster 3” Catback Exhaust, LED's on the interior, LED Headlamps and LED Back Up Bulbs
    Looks like a lot of good info here guys. I don’t have any codes but I’m wondering if I should be considering doing my injectors. I’m about to hit 290k on the OEM’s. Any thoughts?
  23. Jul 4, 2020 at 1:40 PM
    #83
    Hooptytrix
    Dirty South
    Start with all 4 02 sensors. Then this will be a nice upgrade
  24. Aug 4, 2020 at 6:09 PM
    #84
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    You mention need two new nuts for the rear. Are they standard nuts? Or something I need oem
    Thanks
  25. Aug 4, 2020 at 6:13 PM
    #85
    Hand Protectors
    I bought mine right from the Stealer. They keep them in stock as the parts guys said they need them all the time. They were cheap at maybe $3 bucks total for all 4. You need 2 per rear sensor.
    Rex Kramer likes this.
  26. Feb 21, 2021 at 8:57 AM
    #86
    04TundraTRD
    Neil
    O2 sensors, MAF sensor and a set of Dirty Deeds injectors going in this week. Next up is a call to Keith about the exhaust system.
  27. Mar 29, 2021 at 7:37 PM
    #87
    04TundraTRD
    Neil
    Well it's been a while. Got all my O2 sensors and MAF sensor done and the injectors too. Truck runs great and the power band feels much smoother. I haven't really checked on the fuel mileage since I've been doing some towing.
