Dirty Deeds Exhaust 8" w/ resonator vs 10" w/o resonator
Discussion in 'Performance and Tuning' started by Kevin80, Sep 15, 2020.
  1. Sep 15, 2020 at 10:35 AM
    Kevin80
    Kevin80 [OP] New Member
    2016 SR5 Crewmax
    I have a 10" system that I did not install the resonator on, but I have always wanted something a little bit more aggressive... the kicker is I tow a camper a handful of times per year.
    If I switch to an 8" system but install the resonator will I get a more aggressive sound without making it unbearable when towing?
    Thanks for any advice.
  2. Sep 15, 2020 at 10:59 AM
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    "Unbearable" is very subjective. I run the 10" without a resonator and I'm fine with it when towing, but others have said they can't take it even when they are not towing without the resonator. From my understanding the 8" is only going to be a bit more raspy and slightly louder most of the time, but the drone while towing is bad enough that Keith recommends the 10" for any towing. Your best bet is going to be calling Keith and talking to him about your goals. You might wind up needing a custom system, and he does those too.
    tundraatx, rcjh0891 and mambo143 like this.
  3. Sep 15, 2020 at 11:01 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Sound is so subjective but in my case, my 10" system with resonator is ideal for towing. As a 67 year old construction worker/shooter, my hearing is by no means "good" either! We tow 8 to 10 hours at a stretch, every year. My 10" system 'informs' me as to what's going on with the engine and transmission but still sounds "grown-up".
  4. Sep 15, 2020 at 11:17 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Keith gave me the same advice. He tows a lot. I run a 10 with resonator and it’s plenty loud when I want it to be, no highway drone, and has a nice purr at idle and around town. People comment on it all the time.
  5. Sep 15, 2020 at 12:57 PM
    GiantWinston
    GiantWinston New Member
    Justin
    2016 MGM SR5 5.7l 4x4 Crewmax
    Toytec Boss Lift (3.5" front / 2.5" rear) 295/65/R20 Nitro Ridge Grapplers 2018 LED Headlight Conversion Pioneer AVH-W4400NEX Headunit
    Anyone know how comparible the sound of the dirty deeds exhaust is to the TRD pro exhaust? I'm guessing the dirty deeds with 10" resonators is the closest comparison in terms of volume?
  6. Sep 15, 2020 at 1:16 PM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    I've run the TRD exhaust, 12 inch BAM with tailpipe resonator, 8 inch BAM with tailpipe resonator, and currently 8 inch BAM with 1 resonator behind the muffler and 1 in the tailpipe.
    The 8 inch BAM with 2 resonators is my favorite.
    None of the BAM's that I've used are louder than the TRD exhaust on the inside - as long as you use the tailpipe resonator, but they're all louder than TRD exhaust on the outside.
    My biggest issue with TRD was the helicopter sound at steady highway speeds. Other than that, I thought the exhaust sounded good.
    tundraatx, AZTundra and Hightide like this.
  7. Sep 15, 2020 at 2:11 PM
    GiantWinston
    Justin
    Thanks for this. I'm thinking before the year is out I'll be picking up one of their exhausts. Based on the comments in this thread, and since I tow regularly, I'll likely end up with the 10" resonator version, but I could be persuaded to pick up the 8".
    08TXTundra likes this.
  8. Sep 15, 2020 at 3:01 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    When I had the 12 inch with resonator, I always thought it was too quiet - never too loud. More like a slightly deeper toned version of stock. And I hate drone and excessively loud exhausts.
    You'll hear the 8 most of the time, but it's not obnoxious or annoying.
    The 10 with resonator should split the difference between the 8 and 12.
  9. Sep 15, 2020 at 3:15 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Which one did the best on the butt dyno?
  10. Sep 15, 2020 at 3:17 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    I'm running the 8" with the resonator and tow a lot. Too me it sounds better while towing at least on flat terrain, I almost went with the 6" though. If you live/tow in hilly terrain you'll definitely turn some heads and might grow tired of it.
    tundraatx likes this.
  11. Sep 15, 2020 at 3:26 PM
    AZTundra
    Paul
    Phoenix, AZ
    I too have the helicopter sound at certain rpms and speed with trd exhaust. Anyone running the resonator on the trd? If so, would that eliminate the drone?
  12. Sep 15, 2020 at 3:39 PM
    Kanobi13
    Kanobi13 New Member
    DD exhaust
  13. Sep 15, 2020 at 3:59 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I’d go 8” with resonator. Depending on how often you tow, he does have a plug that allows you to take the resonator off and plug the hole if it’s too quiet for you when your not towing.
  14. Sep 15, 2020 at 4:05 PM
    Kanobi13
    Kanobi13 New Member
    Its easy to go back and forth between stock mufflers and DD if you dont like the noise towing just put stocker back on
  15. Sep 15, 2020 at 5:07 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    No difference that I could feel between the BAM systems. All felt stronger than OEM across the entire range.
    The TRD had less low end torque (you could feel it lugging between 45 and 60 mph in 6th), but good mid range and top end.
    Hightide[QUOTED] likes this.
  16. Sep 15, 2020 at 5:16 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    I have an entire thread on this in the performance section. I experimented with H pipes and resonators with TRD.
    The H pipe got rid of the helicopter sound, restored low end torque, but got rid of the throaty burble too. The tone was deeper, smoother and a little droney.
    The resonators made the interior very quiet and tempered the exterior sound too. Resonators and h pipe was nearly stock sounding. Resonators with true dual setup was like a quieter TRD. The helicopter sound was there but not annoying - you had to listen for it.
    AZTundra[QUOTED] likes this.
  17. May 24, 2021 at 6:05 PM
    Jshamilton
    Jshamilton New Member
    Jeremy
    2020 tundra platinum, metallic grey
    Rica25 likes this.
  18. May 24, 2021 at 6:06 PM
    Jshamilton
    Jeremy
    Would anyone want to trade their 8inch dirty deeds exhaust for a 10"? I want more than what the 10inch offers.. I've only had my system for 5 months now. 2020 Tundra platinum
    Hightide and Rica25 like this.
  19. May 24, 2021 at 6:40 PM
    Hightide
    Abalama
    Magic School Bus
    @dirtydeeds
    Keith will trade for the cost of shipping.
  20. May 24, 2021 at 6:46 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    This is true. I went the other way 8 to 12 inch.
