Dipstick length?
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra6883, Aug 10, 2020.
  1. Aug 10, 2020 at 8:57 AM
    Tundra6883
    Tundra6883 [OP] New Member
    Shawn
    I'm sorry I realize this is a a dumb question. I've been checking my oil in my 4.7 and I swear the dipstick is too short. First off it only has two lil round dimples where the oil should be able to be seen which everyone I've had check it says the same thing you can't tell if there is any oil in it at all. So if anyone knows the correct length or if I should should just go ahead and drill the dimples through I'd appreciate it. I'm gonna call advance to see just dislike them overpriced dicks thanks if anyone has an answer.
  2. Aug 10, 2020 at 9:03 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've heard in the past some people say the stick is too short to pick up oil. I don't think you're alone on this.
    Mine works fine but after a change it can be hard to see the oil. I will measure mine on lunch break today and post.
    Out of curiosity, how much oil have you put in and which oil filter are you using?
  3. Aug 10, 2020 at 1:17 PM
    Professional Hand Model
    Hand Protectors
    There was a TSB from Toyota on short dip sticks on some years/versions. New oil is hard to read even on a proper dipstick. Flipping it over and reading both sides helps.
    TX-TRD1stGEN likes this.
  4. Aug 10, 2020 at 1:31 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah it is! I have to touch it to know if the oil is on there or not.
  5. Aug 10, 2020 at 3:07 PM
    halfbid
    halfbid New Member
    2006 DC Tundra
    Mine measures 23 3/16" from the tip to the area where it seats on the dipstick tube.
    Here is a pic of the tip for an additional reference point.
    bmf4069 and FrenchToasty like this.
  6. Aug 10, 2020 at 5:56 PM
    shifty` In South Dakota Trouble ain't hard to find
    Just the tip. And remember now, it's not how deep you fish, it's how you wiggle your worm.
    And PHM is correct. Another member here had that issue and I feel like he got ribbed and chastised a bit until the info about the TSB for too-short-dipstick was shown.
    bmf4069, Darkness and FrenchToasty like this.
  7. Aug 10, 2020 at 5:58 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    My work van was doing the same thing, ends up, it needed 5qts!!!!!!
    Darkness likes this.
  8. Aug 10, 2020 at 8:12 PM
    Tundra6883
    Shawn
    Thanks everyone
