Diode Dynamics SS3 SAE Pro fog lights installed. Update 4/17/21. Now with SS3 Max.
Discussion in 'Lighting' started by Danman34, Dec 13, 2019.
  1. Jun 8, 2021 at 5:59 PM
    #541
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
  2. Jun 10, 2021 at 1:28 PM
    #542
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    Finally got to test my SS3 Pros at night. They are amazing. Went from stock halogen fogs to Morimoto XBs to DD SS3 Pros. Morimotos will be in the market place soon after the test last night.
    Oey12, omgboost and memario1214 like this.
  3. Jul 8, 2021 at 11:28 AM
    #543
    xdmelarton
    xdmelarton New Member
    Richard
    2017 Tundra TRD Pro CM
    @memario1214 after reading 19 pages on these SS3's...just pulled the trigger on your store for these. Running 17 halogens headlights and fogs.....just want something to see the deer on the side of the roads. Thanks to all for great comparisons and pic's
    omgboost likes this.
  4. Jul 8, 2021 at 3:25 PM
    #544
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Well these will certainly help that problem!
    Appreciate the support!
    Oey12 and xdmelarton[QUOTED] like this.
  5. Jul 8, 2021 at 4:50 PM
    #545
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Ordered a set of DD SS3 Pro's for ditch lights from your site during the Independence Day Sale. Going to mount them on my new Rago Low Pro mounts as soon as everything gets delivered.
    memario1214[QUOTED] likes this.
  6. Jul 8, 2021 at 4:58 PM
    #546
    memario1214
    Colton
    Missoula, MT
    Good man! Which pattern did you snag?
  7. Jul 8, 2021 at 4:59 PM
    #547
    memario1214
    Colton
    Missoula, MT
    Oh there you are! Combo should be a good choice :D
  8. Jul 9, 2021 at 9:33 AM
    #548
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    I ordered the Combo pattern for sure, thought that would be best for my application. Correct?
  9. Jul 9, 2021 at 9:47 AM
    #549
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Soon to be 4WC Raven host. Mods to come.
    @kuokoa
    Got a dremel with the small cut off wheel or small hacksaw blade? You can cut a slot for a flat blade screwdriver to get it off (if the bolt head is not recessed).
  10. Jul 9, 2021 at 12:22 PM
    #550
    memario1214
    Colton
    Missoula, MT
    Yeah given where you’re mounting it for sure! I also don’t know the remainder of your lighting situation so you can’t go wrong there! Best part is that you can always change the pattern as well down the road. :D
  11. Jul 9, 2021 at 12:25 PM
    #551
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Anyone else's bezels seem to be really loose from Toyota? Fogs mount in good, just the plastics seem very shaky.
    IndianaGeologist likes this.
  12. Jul 10, 2021 at 1:10 AM
    #552
    tdub88
    tdub88 New Member
    Todd
    2017 Tundra SR, 4x4
    I installed some cheapies, but now are going to install some DD's. I used some black caulk around the first set and they are rock solid. Get them close then caulk the plastic trim in and then adjust to perfection. Should be good. Caulk is not permanent, so no probs changing down the road.
  13. Jul 10, 2021 at 11:55 AM
    #553
    memario1214
    Colton
    Missoula, MT
    Did you do the zip-tie mod on installation? If you don't know what that is that's okay too.
    kuokoa likes this.
  14. Jul 10, 2021 at 4:13 PM
    #554
    SnrDisregardo
    Wade
    IL
    I don’t and I’m intrigued.
  15. Jul 10, 2021 at 4:24 PM
    #555
    memario1214
    Colton
    Missoula, MT
    Please excuse the quality of this photo as it is a screen grab from a video I was working on so it degrades pretty bad. Either way you should be able to make sense of it. So this is of the driver's side. You have the Phillips screw up the on the left corner. The other side has tabs that slide into "slots" on that side. Feed a zip-tie through both the tab of the Diode Dynamics bracket as well as the slot that is part of the OEM equipment. Then tighten the zip tie down tight effectively locking the two pieces together. You'll hear some folks say just top or bottom, but I did a tie on both and don't regret it. Of course you will need to re-aim your lights if you already have as this will upset wherever they're currently aimed for sure. Hopefully this helps you.
    R65, Barrett50 and (deleted member) like this.
  16. Jul 10, 2021 at 4:52 PM
    #556
    SnrDisregardo
    Wade
    IL
    I’ll give it a shot. This looks like it’ll secure the fog to the bezel more and not the bezel to the truck which is where I’m thinking the shake is. But I’ll give this a try.
  17. Jul 10, 2021 at 4:56 PM
    #557
    memario1214
    Colton
    Missoula, MT
    Ah... Well in that case I don't have any sweet, hot tricks for you unfortunately as I haven't see that issue first hand. If you snap some pics of what you're seeing though I may be able to give an idea or two.
  18. Jul 28, 2021 at 5:19 PM
    #558
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    edit: just received yesterday. I guess someone did hand-carry it from the midwest lol.
    my bad. I haven't checked back in for a couple weeks. I was able to contact DD and after confirming my original DD order number, they sent out a free replacement as well as a prepaid shipping label for the stripped screw light. awesome customer service on their end.
    the only shitty thing is that they sent it at the end of June/beginning of July and I still haven't received it. I think UPS lost it since my package has been "On the Way" since 6/30. maybe someone is hand-carrying it from the midwest to Hawaiʻi? :bananadead:
  19. Aug 9, 2021 at 12:17 PM
    #559
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Going to order a set of the SS3 Pros, anyone running a sale right now, or know of a code that works?
  20. Aug 9, 2021 at 12:40 PM
    #560
    Danman34
    Danman34 [OP] New Member
    Danny
    2018 White Tundra TRD Sport
    No sales. Probably won’t have anything until Black Friday. May have something for Labor Day. But I wouldn’t bank on it.
  21. Aug 9, 2021 at 1:54 PM
    #561
    AlrightAlrightAlright
    AlrightAlrightAlright New Member
    Northwest Arkansas
    2020 SSM DC 4x4 with SR5 Upgrade Package
    RetraxONE MX retractable bed cover TRD Rear sway bar Debadged FabFours Matrix front bumper Smittybilt 9,500# XRC winch Aries 30" light bar (internal bumper mount) Diode Dynamics SS3 3" SAE Fog and Driving lights ConsoleVault RhinoRack crossbars
    Just wanted to add some info in case it helps you, but first and foremost, how incredibly helpful @memario1214 was in getting me to the right place on my build. Ended up getting a pair of Amber SAE Pros for weather and a pair of Amber Maxes with the clear lens swap for deer that switch on with the brights (SwitchPro that I also got from HotShot). I think this is as “illumination bulletproof” as I can get things. Illumination at night is superb, but I can’t use the auto-on/auto-off hi beam feature anymore… too much light for oncoming traffic coming off curves. Highly recommend the SS3 product for deer!
  22. Aug 10, 2021 at 8:09 AM
    #562
    memario1214
    Colton
    Missoula, MT
    No sales or codes running right now (DD is pretty strict about that stuff). I see you shot me a pm though. Even on the worst day I can save a guy sales tax. Depending on where you live that could be pretty big. :cool:
    If I remember right didn't we go with the Amber pros with a clear lens swap to capture the 4000k output color, right? Maybe not, I lose track of individual builds sometimes!
    Either way, I absolutely appreciate the support and the kind words! :cheers:
  23. Aug 10, 2021 at 5:56 PM
    #563
    Northwest Arkansas
    I can’t keep track of it anymore… all I remember is how freaked I was installing them on that geometry nightmare FF Matrix bumper and not screwing it up!
    Gotta find a bumper sticker that says, “Lighting provided by Colton and Ryland Enterprises”. One more “E” and the acronym would spell “CREE”… how awesome would that be? ;)
  24. Aug 11, 2021 at 8:57 AM
    #564
    memario1214
    Colton
    Missoula, MT
  25. Aug 11, 2021 at 11:12 PM
    #565
    OnespeedTRD
    Don
    San Diego
    Just ordered some SS3 Pros in yellow from @memario1214.
    Also really considering some SS3 Max Combo lights to replace my current ditch lights, because they gotta match right?
  26. Aug 12, 2021 at 5:12 PM
    #566
    memario1214
    Colton
    Missoula, MT
    Thank you sir! I will not be able to get them shipped out until Monday as I am outta town. You still have time to get that order in!
  27. Sep 8, 2021 at 12:26 AM
    #567
    20Tundra_sauce21
    20Tundra_sauce21 New Member
    Got my DD SS3 pro amber fogs today!!! UPS lagged it and couldn’t deliver to me on Friday. Anyway big shout out to @memario1214 for hooking me up with the goods!!! Hotshot Off-road has great customer service and better professionals with great advice!!!!
    653EC120-77B7-4A38-BBA6-9CB0E9930FC5.jpg C500B405-9FCA-4706-871E-EDDBB60D9C76.jpg E51F4AFA-B595-4121-ABD3-14DC7E3FAFF1.jpg 66A0EC57-3C1E-4F8D-A2BB-CEE29B7AD7E7.jpg
  28. Sep 8, 2021 at 5:57 AM
    #568
    memario1214
    Colton
    Missoula, MT
    Lookin GOOD!
  29. Sep 12, 2021 at 11:24 AM
    #569
    RogueAngler
    RogueAngler New Member
    @NESURFPRO
    2021 MGM TRD Pro DC
    Tint (3M) to VA limits TRD rear sway bar AJT Design chrome delete; all black TRD shifter Coachbuilder trd pro kit with Bora spacers Toyo OC AT3s CBI overland rock sliders Ordered: UpTop overland Alpha roof rack with Baha lights Considering: RSi SmartCap
    Hey guys. Looking for guidance. I’ve got DD SS3 Pro fogs ready for install. 2021 Tundra TRD Pro. Removing the factory Rigid fogs which have a square casing vs the rounded style of the SS3s.
    My understanding is that for a better (perfect?) fitment, I can trade out the Toyota Fog Light Trim (aka Lamp Bezel) for a round-holed version, Sparks Parts: https://www.sparksparts.com/oem-parts/toyota-fog-light-trim-right-front-521270c070
    Can anyone confirm that for me? Thanks!!!’
  30. Sep 12, 2021 at 12:58 PM
    #570
    memario1214
    Colton
    Missoula, MT
    That is correct. That said, you can probably find what you’re looking for WAY cheaper if you just post up a WTB ad here on the site. Someone who pulled their stock bumper probably has some lying around!
    RogueAngler[QUOTED] likes this.
