Diode Dynamics SS3 SAE Pro fog lights installed. Update 4/17/21. Now with SS3 Max.
Discussion in 'Lighting' started by Danman34, Dec 13, 2019.
  1. Mar 1, 2021 at 4:28 PM
    #511
    Silver4x4trd
    Silver4x4trd New Member
    2017 Tundra SR5 & 2012 Sequoia SR5
    Jba long tube headers, dirty deeds TRD exhaust (2x24), 19+ Pro lights and grill painted sky silver, TRD rear sway bar, TRD reusable air filter, PnP sliders, pnp full set skid plates, 275/70/18 ko2’s, bully dog bdx (trail setting), c4 hybrid bumper with DD lights(sae fog and driving)
    Joining the club! Got the pros in amber fog and the whites in combo pattern from @memario1214
    BrandonL812 and memario1214 like this.
  2. Mar 11, 2021 at 10:01 AM
    #512
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I am installing my fogs tomorrow, and I seen people say you can aim them. I am assuming there is some up and down movement? Can they be aimed while installed or does it have to be prior to I installing? And where should I attach the zip ties to lessen the shaking when driving?
  3. Mar 11, 2021 at 10:13 AM
    #513
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I still need to re-aim mine, but they have up/down adjustment by how you aim them when tightening the screws on the side of the bracket. Likely, you have to install, check how they aim, then remove the bracket to loosen and re-tighten the screws. There isn't a lot of room to get your hands in to do it while they are attached to the truck. On mine, I initially installed them about "level" with the bracket, and they are aimed too high on the road. I'd start by aiming them half way between level and all the way "down" and check from there.
    On the zip ties, once you get your bumper apart, it becomes pretty evident where to put them. I had to attach 2 zip ties together to get them to be longer, then tightened them to the black steel bumper brackets.
    farm&forest and Oey12[QUOTED] like this.
  4. Mar 11, 2021 at 10:55 AM
    #514
    Oey12
    Oey12 New Member
    Joey
    New York
    Thanks for all the info!
  5. Apr 17, 2021 at 8:21 AM
    #515
    Danman34
    Danman34 [OP] New Member
    Danny
    2018 White Tundra TRD Sport
    Just upgraded from SS3 Pros to the SS3 Max selective yellow fog lights. I tried to get similar shots to compare the Pro’s to the Max’s. That’s what the first 4 collage pictures are. As you can see the Max’s cutoff is far more defined and there is definitely more light on the ground. I’m debating on selling my Pros at this point. I’m pondering the idea of getting a clear SAE driving lens and fabbing a mount to put them behind the grill.
  6. Apr 17, 2021 at 9:31 AM
    #516
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    How much for the pros?
  7. Apr 21, 2021 at 9:13 AM
    #517
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    Nice update! Do you find that the yellow is a little too much?
  8. Apr 23, 2021 at 8:45 AM
    #518
    Danman34
    Danny
    Not at all. Quite opposite actually, in my case. I have an astigmatism, so the white LEDs put a strain on my eyes with long periods of night driving. The yellow light is actually much more tolerable. And in any case, the output on even the Pros was ridiculously better than factory haha.
  9. Apr 29, 2021 at 7:20 PM
    #519
    bigmout
    bigmout New Member
    17 Inferno SR5 TRD-OffRoad
    Just got done installing ss3 MAX amber fogs purchased from memario1214 at Hotshot Offroad. Excellent buying experience, quick email answer, and fast processing and shipping.
    Large improvement from stock and I don't feel they are too much or too yellow. I aimed them down in the bezel as much as possible before installing and they lined up right up with the line I marked from the old ones. No blue clip.
    I'm happy and very impressed with this upgrade.
  10. May 3, 2021 at 9:04 AM
    #520
    farm&forest
    farm&forest New Member
    2021 Tundra SR5 TRD-Off Road Double Cab
    Dobinsons 2-3" Complete Suspension Kit w/ medium Dobs Leafs, Decked Drawer System, Leitner Forged ACS Rack, Line-Xed bed and Line-Xed Tyger Blade Steps, Wet Okole seat covers, VLED lighting, soon to add Swith Pro and auxillary lights
    I’m submitting a request for an update regarding Pro vs Max...perhaps especially for those who made the switch to Max:
    How comfortable is everyone using the Max (or Pro) for on road driving? Any issues getting flashed regularly? I know to angle them when installing.
    I am planning on SS3 Amber Fog either Pro or Max but a lot of my roads here in NH are dark two direction/ no divide so I want to choose and use responsibly. I like the cutoff of the Max.
  11. May 3, 2021 at 10:17 AM
    #521
    Danman34
    Danny
    Never turned my Pro fogs off. Never flashed once in over a year of having them. No issues with the Max either. They are designed for on road use, hence the DOT and SAE compliance.
  12. May 3, 2021 at 10:19 AM
    #522
    Cfincke
    San Antonio
    I have been running the Pros for 1-1/2 years now and have never been flashed.
    The pros have a little more up lighting than the Max lights, so should be no issue running the Max's. Both are street legal
  13. May 3, 2021 at 10:28 AM
    #523
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Minnesota
    2020 TRD Pro Tundra, 8371 Club
    Coachbuilder Pro Kit, 35x12.5 BFG KM3s, Baja S8 hood mounted, Rago Lo-Pro Brackets sitting empty at the moment, Rago Dash Divot Plate, AJT Stuff, LED Lighting throughout, TRD Intake, Bedliner, Tint, Full front PPF, SPS Graphene Coating, and dropped the B out of JBL ;-)
    Same with the pros...I feel like my aim might be a bit off as I see road signs lit up...in the day time...with yellow light
  14. May 3, 2021 at 2:15 PM
    #524
    farm&forest
    Thanks to guys chiming in- looking at the feedback so far I'm leaning toward the Max for the sharper cutoff.
  15. May 3, 2021 at 2:42 PM
    #525
    Elduder
    Elduder New Member
    Ive had both the Max and Pro, honestly if you have no issue with the extra cash get the Maxs. I cant really tell much of a difference between them though and if my budget were tighter I'd recommend the Pros. The cutoff is sharper but I struggle to tell the difference in fill and coverage.
  16. May 4, 2021 at 1:48 AM
    #526
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    anyone bought the lens replacements for the SS3's? I have the SAE amber fogs on now, but was wondering if the other lenses can be run without issues in the Tundra housing. I'm interested in trying the amber SAE driving or combo ones.
  17. May 4, 2021 at 4:34 AM
    #527
    Danman34
    Danny
    Yes. You can swap the lens. There is no sae yellow driving light. SAE driving lights can only be white. The combo lens is not road legal either. So keep that in mind that neither of those lens would allow to use it for other than auxiliary lighting off road.
  18. May 5, 2021 at 6:43 PM
    #528
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    oh ok, yeah it's not SAE, just "off-road only":
    https://www.diodedynamics.com/yellow-lens-for-ss3-pods-one.html
  19. May 5, 2021 at 6:50 PM
    #529
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    kuokoa[QUOTED] likes this.
  20. May 12, 2021 at 2:14 PM
    #530
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Selling a set of SS3 Pro Amber in Flood pattern. Asking $200.
    TNTundra53 likes this.
  21. Jun 5, 2021 at 6:49 AM
    #531
    Danman34
    Danny
    I finally got around to aiming and getting comparison shots between the DD SS3 Pro and SS3 Max. I tried to make the ambient lighting as similar as possible and pictures taken from the same spot. Please forgive my rudimentary labeling lol. For a quick intensity reference, check out the fence on the left side. Both pictures are fog lights only.
    AT x AT, kuokoa, Silver4x4trd and 3 others like this.
  22. Jun 7, 2021 at 7:21 PM
    #532
    Mr_Kane
    Mr_Kane New Member
    2019 TSS Crewmax
    :Eibach 2.5" Lift :SPC UCA's :34" Toyo AT3's :10" BA Muffler
    Received the Diode Dynamics SS3 Led fog Light Max today
    Shot Out to memario1214 with the Memorial Day Sale:fistbump:
    NewImprovedRon and memario1214 like this.
  23. Jun 7, 2021 at 7:37 PM
    #533
    AT x AT
    Jimmy
    Mods, what mods?
    For clarification, is this aiming higher than stock fog lights?
  24. Jun 8, 2021 at 12:04 AM
    #534
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    anyone have issues with the torx bolts on the back of the lights, specifically the 4 holding the lens in place? bought replacement lenses over the Memorial Day sale and discovered that one of the torx bolts was already rounded off. and I can’t get it off. fml.
    Any ideas?
  25. Jun 8, 2021 at 4:25 AM
    #535
    Danman34
    Danny
    I haven’t had stock fogs in so long it’s hard to say. However, the stock led fogs don’t have a fraction of the output of the DD fogs, so the ability to project light ahead of the vehicle is far less with the stock fogs.
  26. Jun 8, 2021 at 4:35 AM
    #536
    Danman34
    Danny
    I would definitely contact DD on that. You could always try and use a rubber band to try and get some bite with the bit.
  27. Jun 8, 2021 at 7:02 AM
    #537
    memario1214
    Colton
    Missoula, MT
    Like one of the Torx bolts was rounded... Out of the box? Definitely a warranty contact item to go through DD over. I'm not sure if you bought through me during the sale or not, but they will help you out. If not, let me know and I can as well.
  28. Jun 8, 2021 at 8:49 AM
    #538
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    Got my amber SS3 Pros installed this morning. About 15min total. Way quicker popping them out thru the front of the bumper than going thru the wheel liner. Excited to test them out tonight. They are replacing some Morimoto XBs.
    Oey12 and omgboost like this.
  29. Jun 8, 2021 at 4:34 PM
    #539
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    yup, tried this as soon as I saw it rounded, and no luck. a T10 torx bit doesn't even bite enough in the bolt :confused:
    for clarity, I bought these new maybe 6-8 months ago, and they went straight on my truck out of the box. last night was the first time I've removed them, since I bought the replacement (combo) lenses with the Memorial Day sale. not sure if they'll cover it or help me out.
    the T10 torx worked fine all the other 3 bolts, but the 4th one was rounded to the point where the T10 torx barely even bit and was almost able to free-spin in the head :bananadead::bananadead::bananadead:
  30. Jun 8, 2021 at 5:20 PM
    #540
    Djone27
    Djone27 New Member
    Have you tried a screw extrator kit? Something like this:
    https://www.amazon.com/dp/B07HGSPQDV/ref=cm_sw_r_em_apa_glt_fabc_48ZEGPD86PY9HRR4JBQ1?_encoding=UTF8
