Diode Dynamics SS3 Pro RF Interference
Discussion in '2.5 Gen Tundras (2014-2021)' started by edwardlyle, Jan 2, 2022.
  1. Jan 2, 2022 at 5:34 PM
    edwardlyle
    edwardlyle [OP] New Member
    I installed the fogs and they are great!
    Unfortunately, when I turn them on they generate a tone of RF Interference enough to drown out my favorite radio station (factory radio).
    I have tried installing 2 ferrite coils on the power cables on each side and it didn't seem to make a difference.
    I have since ordered a pair of braided grounding cables to try and install, but does anyone have any other suggestions or experience?
  2. Jan 2, 2022 at 6:05 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    My EE knowledge is extremely limited, but I'm assuming you're running their wires through the driver's side which I'm guessing the antenna is run through too? If that's the case, what happens if you completely bypass the driver's side firewall pass through, and hot wire the lights straight to the battery? Does the radio work then? My guess would be the radio and the lights wiring are in close proximity and causing the issue, and you might be fine running the lights wiring down a different path.
    bulldog93 likes this.
  3. Jan 2, 2022 at 6:20 PM
    edwardlyle
    Thanks for the reply.
    I bought the tundra install kit that simply plugs into the factory harness.
    I know other people on here have done that upgrade so I thought I would check.
    I bought the truck used - maybe the previous owner had an aftermarket radio installed and when they put the OEM unit back in they did not ground it out well?
    Anyone else that has done the SS3 fog upgrade have issues with RF?
  4. Jan 2, 2022 at 6:25 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I have SS3 pro fog and no interference with my radio. I only listen to one station, 100.3 and most other times are Bluetooth audio.
  5. Jan 2, 2022 at 6:25 PM
    Ronster
    Ronster New Member
    Ron
    2017 Tundra Crewmax
    I had the same problem when I put a rigid lightbar in but the coils solved my problem. Maybe try moving the coils around on the wiring harness. Unplug them one at a time to try and find out if it’s one or both causing the problem.
    Saltyhero13 likes this.
  6. Jan 3, 2022 at 4:45 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    did u email D.D. an ask them for their input??
  7. Feb 10, 2023 at 8:57 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I'm having RF issues with my SS3 Pro fogs as well - I noticed it in my comms, specifically on MURS frequencies. Seems like it affects parts of the VHF range, but UHF (GMRS) is fine. I got mine through Hotshot Offroad and let @memario1214 know. Sounds like this isn't super common, but has happened from time to time. We'll see if a swap out under warranty cleans it up.
  8. Feb 10, 2023 at 9:29 AM
    Vizsla
    Vizsla 2 = 2.5
    My DD fogs cause radio interference, but I just turn them off. Every light except BD caused interference, Rigid did also. I went nuts and had ferrite suppressors on everything, didn’t help, only thing they worked on is reducing noise from my whips. Concluded the noise comes from the lights, rerouting wiring didn’t help. You have your radio directly to the battery?
    reywcms and TRDFerguson[QUOTED] like this.
  9. Feb 10, 2023 at 9:33 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I've got my Icom on one of my SwitchPro circuits. But it does the same on my Baofeng, so it's not related to the truck wiring. It's weird that none of my other Diode lights do it, including a set of SS3 Sports in the back. Just the Pros up front. And replacing them with some Rough Country cheapies I had sitting around killed the noise. Ferrite chokes didn't do crap on them.
    Vizsla[QUOTED] and reywcms like this.
  10. Feb 10, 2023 at 11:08 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Interesting. I’ve got DD fogs on mine with no interference.
    Vizsla likes this.
  11. Feb 11, 2023 at 5:39 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    New ones are on the way. You didn’t perchance try them independently did you?
    TRDFerguson[QUOTED] likes this.
  12. Feb 11, 2023 at 7:08 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :bananadance:
    I did. Same noise on both, separately powered or together.
  13. Feb 11, 2023 at 7:28 AM
    Sergicalmaneuver
    Sergicalmaneuver New Member
    So Cal
    2019 Platinum Crewmax
    I’ve had the SS3 Pros for about 2 months and no issues
