Diode dynamics behind the grill lights
Discussion in 'Lighting' started by BlueBottle, Aug 26, 2018.
  1. Nov 19, 2021 at 9:32 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    looks like a decent kit that i probably would have considered. for those with a pro grill, a few 25 cent washers, the lightbar of your choice and about 2 hours time you can have the same effect. hats off to them for giving options for other styles of front end.
  2. Jan 22, 2023 at 4:16 AM
    Kalash1794
    Kalash1794 New Member
    Murrayville
    2016 White OR 1794
    DD ditch lights Tyger blade Borla cat back OEM led headlights Excelon reference
    Was gifted the kit mentioned and I have both the led headlights and pro grill which the specs mention not compatible with. I took the front end of my tundra apart today to see what I could see and it is obvious without some pretty heavy modification to the light brackets the Lightbars will not line up with the grill and I have not yet investigated why it doesn't work with the Trd pro 18 led headlights as indicated but not very fond of sending stuff back that I would use most of anyway so I am here seeing if anyone has just made it work.
    My initial assessment is I can elongate the holes in the bracket moving the mounting of the light bars down to fit the 16 pro grill.
  3. Jan 22, 2023 at 4:27 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I have the kit and have been very pleased with it. The issue with the pro headlights is the use of the harness to integrate it with the high beams. It plugs in-line with the halogen bulbs, and the connectors on the led lights are different. If I remember correctly, the kit also comes with an independent switch, and that absolutely should work.
    Kalash1794 likes this.
  4. Mar 5, 2023 at 7:42 PM
    Wharf-Rat
    Wharf-Rat New Member
    Texas Coast
    2018 Tacoma
    I installed this kit and skipped the included rocker switch wiring into the high beams. Works fine.
