Digital Dash Project, What values would you like to see? (Speed, RPM, Mpg, ect.)
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jeff_5_7, Jan 7, 2022.
  1. Jan 24, 2022 at 5:19 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    Got daytime pics? Looks awesome man. You’re doing this and meanwhile I can’t seem to stop the hyper flash from my turn signals regardless of what resistor I use :)
  2. Jan 24, 2022 at 5:38 PM
    Jeff_5_7
    Jeff_5_7 [OP] New Member
    Jeff
    Houston Tx Area
    This is from about a week ago.
    Slowly but surely getting everything finalized and going back and forth on adding new pages with more data. Still trying to crack the TPMS
    biebs96, RegGex, GAknight and 5 others like this.
  3. Jan 24, 2022 at 9:27 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    In addition to Gear shift position, how about which gear the transmission is in when in Drive.
    Nice work!
    Greg
    HulkSmurf14, Jeff_5_7[OP] and Jego like this.
  4. Jan 25, 2022 at 4:03 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    This is probably one of the best projects I have seen.
    I would love to have the knowledge to be able to do this. Computers and I are not friends.
    Shadowfax1 and HulkSmurf14 like this.
  5. Jan 25, 2022 at 5:08 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    Data points I would be willing to pay for:
    Volts
    MPG data (historical & real-time)
    Fuel (remaining amount)
  6. Jan 25, 2022 at 5:11 AM
    Jeff_5_7
    Jeff
    Houston Tx Area
    About 9 months ago when I would read the word CAN bus I just kinda skimmed over it because I didn’t understand it.
    After lots of research and testing I have a much better understanding of how it works. It’s a lot like a conference call with multiple people at work. You talk into the phone and your message is broadcast to everyone else all on the same one phone line. In CAN each message has an address that gives it priority depending on how important it is. All 8-10 ECUs talk on the same line and they all see every message sent out but if it doesn’t apply to that particular ECU it’s just ignores it.
  7. Jan 25, 2022 at 5:18 AM
    Jeff_5_7
    Jeff
    Houston Tx Area
    I go back and forth on the voltage value. The gauge in the cluster is analog. Only way I know how to get the digital value is to ask the ecu for it on the bus. (This is how all of OBD2 works, you ask for the value and it replies with it)
    As of now my entire setup is read only but I could implement code to go ask for a value and read the return.
    Mpg info I have all of. It’s all based on speed, distance, and fuel burned.
    Fuel level remaining I have but it still needs small refinement. The sensor in the tank moves a lot when driving so the data has a lot of noise. I have code that filters it very well but it’s not quite 100% on the money all the time. (Very close)
    Ohannon7[QUOTED] likes this.
  8. Jan 25, 2022 at 5:22 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    For those of us that drive in foreign countries, like Canada, it would be awesome to have the ability to switch over to Kilometers on that digital speedo you created.
    HulkSmurf14 likes this.
  9. Jan 25, 2022 at 5:37 AM
    Jeff_5_7
    Jeff
    Houston Tx Area
    I knew someone would mention this
    The funny thing is since the truck is Japanese all data is sent in metric units. The raw speed signal is in KmH and my code is converting it to Mph.
    Long story short a metric version can be done. Temperature in C ect.
  10. Jan 25, 2022 at 5:47 AM
    Jeff_5_7
    Jeff
    Houston Tx Area
    Short answer is no but shoot me a private message and maybe I can help you.
    HulkSmurf14 and Tundratoofun like this.
  11. Jan 25, 2022 at 10:30 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Are you freaking kidding me? The data already there and being converted but we can’t just click a damned button and switch the digital display to constant KPH. I am so frigidly bitter now…
  12. Feb 3, 2022 at 9:58 AM
    JRS
    JRS New Member
    2012 DCLB
    What's your status with reading TPMS from the LIN? Which transceiver did you go with, or was it an add-on board? As I don't have an oscilloscope (yet) I can't use serial decode to reverse their IDs and messages.
    I'm wrapping up a Raspberry Pi/Open Auto Pro install and wanting to incorporate tire pressures for a separate OLED display.
    Jeff_5_7[OP] likes this.
  13. Feb 6, 2022 at 11:32 AM
    Everything G3 n Yota
    Everything G3 n Yota New Member
    Kevin
    2015 super white tundra ltd double cab
    Firestone air bags. DS grab handle. Toyo 10 ply tires
    This is great! Just joined this group this morning. I have been looking everywhere for ways to get get the 2018 info cluster into my 2015. Put me on the list for purchase once this is ready. .... On another note orange virus tuning Guys are also great at hacking Toyota codes etc. They might be another good source for info. Anything I can do to help ,let me know Jeff !!!
    Jeff_5_7[OP] and HulkSmurf14 like this.
  14. Feb 8, 2022 at 6:54 PM
    Jeff_5_7
    Jeff
    Houston Tx Area
    I am still on the fence about making a 2018+ translator so that cluster could be plug and play in the 2014-2017 trucks. It would spoof all the safety sense stuff so you don’t get any of the digital on screen warnings and it would translate some of the data from the 2014-2017 truck into a format that the 2018 cluster is looking for.
    Not sure how high the demand for something like this would be
    Jesmer83 likes this.
  15. Feb 8, 2022 at 6:56 PM
    Jeff_5_7
    Jeff
    Houston Tx Area
    Still working on TPMS, I have a stand-alone LIN chip but I yet to wire it up to my arduino yet and try to start reading data. I have a good idea what addresses the data is stored on just need to setup the reader
  16. Feb 9, 2022 at 5:45 PM
    Kevin
    Jeff, you are an unbelievable wealth of knowledge. I would never have dreamed that there was that much going on in the cast cluster. The 2018 drop in would be great also. What really spoiled me was : my last company vehicle was a newer ram, and I just loved the " usable" information on the cluster. Great work.
  17. Mar 9, 2022 at 8:58 PM
    Jesmer83
    Jesmer83 New Member
  18. Mar 9, 2022 at 9:00 PM
    Jesmer83
    Jesmer83 New Member
    Great hope you make progress i just bought a 2019 cluster and ony few info shows and a lot of lights on like check engine collision and ect
  19. Mar 13, 2022 at 4:20 PM
    #49
    don1
    don1 New Member
    warranty VOID. LoL NO THANKS.
  20. Mar 14, 2022 at 4:59 PM
    #50
    Jeff_5_7
    Jeff
    Houston Tx Area
    Its been a few weeks so I figured I would give you guys an update. I have spent the last month recoding my Fuel Consumption signal and data coming from it.
    I now have 5 pages of data to scroll through in the display. I think I will add two more pages, one for TPMS of all 4 wheels/tires and one more page for Forward Acceleration, Side Acceleration, Steer Angle, and Yaw Angle.
    All of the photos are filled with dummy values to give you and idea of the look.
    Page 1 Speed
    Page 2 Fuel Instant MPG, Avg MPG, Range, Fuel Remaining in Tank
    Page 3 Fuel Burn Rate GPH, Total Gallons Burned, Trip Distance Driven, Engine Run Time (Secs for now)
    Page 4 Engine RPM, Throttle % (This is % actual Pedal is pressed)
    Page 5 Engine Coolant Temperature, Transmission Temperature
    Still making good progress working all the final bugs and tweaks out of the code. It has been going pretty well so far, I have done several miles of highway testing and hope to be able to post a video soon showing full operation.
    RegGex, alb1k, nhw544 and 4 others like this.
  21. Mar 14, 2022 at 5:17 PM
    #51
    jeller75
    jeller75 New Member
    Joshua
    NC Mountains
    2017 CC Platinum Pro 4wd
    Great work! Love what you're doing. :thumbsup:
  22. Mar 14, 2022 at 5:41 PM
    #52
    Wiesy442
    Wiesy442 New Member
    2016 Tundra SR5 Double Cab Red
    Auto headlight mod, seat covers, drop down rear seats mod, 2018+ LED Headlights, USA flag Tundra tailgate decal (many compliments on red Tundra), Alpine ILX-F509, front Focals, JL 10TW1-4s, Waxoyl undercoat, StartX remote start.
    This some really cool stuff. I'd like to see where you take this ride....
  23. Mar 14, 2022 at 6:25 PM
    #53
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Jeff_5_7, you're a stud and thank you for looking into this amd dialingit in! I'm ready when you are! :spending:
  24. Mar 15, 2022 at 10:18 AM
    #54
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    This is awesome! Thank you for the time and effort you’ve put into this. I’d definitely be interested if this is something you put up for sale.
  25. Mar 15, 2022 at 12:01 PM
    #55
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    This is awesome work… amazing. Sign me up…
  26. Mar 15, 2022 at 12:09 PM
    #56
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Scored a sweet rear skid plate this morning.
  27. Mar 15, 2022 at 1:05 PM
    #57
    alb1k
    Left Coast
    It's good
    Sorry, wrong thread :anonymous:
  28. Mar 15, 2022 at 2:53 PM
    #58
    HulkSmurf14
    2014 Tundra Limited
    Haha you day-drinker you ;)
  29. Mar 17, 2022 at 9:57 PM
    #59
    Shadowfax1
    Shadowfax1 New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    I don’t suppose any of the ECUs broadcasting into the CAN bus provide data on the roll angle and pitch of the truck that you could convert into a visualization - a digital inclinometer?
  30. Mar 17, 2022 at 10:02 PM
    #60
    don1
    don1 New Member
    sure, you can place those sensors at the location on the truck and have them broadcast via CAN bus and display the results on the display.
