Differentials and Transfer Case Fluid Change
Discussion in 'General Tundra Discussion' started by parker44, Jul 25, 2018.
  1. Jul 25, 2018 at 10:22 AM
    parker44
    parker44 [OP] New Member
    2008 Tundra - Desert Sand Mica
    My 2008 Tundra is a 4.7L and 4x4. I currently have 135k miles on it and to my knowledge, the fluids have never been changed. The Toyota dealer is the only one that has serviced my truck, and just mentioned that I may want to put those services on my radar of things to look at doing. I'm looking into it and naturally they want me to use the oil from them that is $40 per quart.
    According to my owners manual, it says the transfer case takes about 1 quart of 75W-90, GL-4 or GL-5. The front differential takes about 2.2 quarts and rear is almost 5 quarts, both of 75W-85 GL-5. I tried researching and I feel pretty comfortable doing the rear change, but haven't looked much at the front or the transfer case. My question is, which oil should I use? I have seen Redline and Mobil 1 both come recommended on here.
  2. Jul 25, 2018 at 10:53 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Interested in responses as well.
  3. Jul 25, 2018 at 10:56 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I used the Mobil 1 w the additive for the diffs.
  4. Jul 25, 2018 at 11:00 AM
    Trikerider
    Trikerider New Member
    2015 Limited CM
    I ran Mobil 1 75w90 in both front and rear diffs. doesn't matter if has LS or not as the diffs are both open. The transfer case I ran Ravenol straight 75w I got on Amazon. Nifty bottle made fill up easy and from what I read is the same as the Toyota fluid.
    parker44[OP] and BTBAKER like this.
  5. Jul 26, 2018 at 8:28 AM
    parker44
  6. Jul 26, 2018 at 8:53 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Correct. 75w-85 is not that common. I fair amount of people say they just use 75w-90. I use Redline 75w-85. You can find several sellers online. Not exactly cheap, but it's cheaper that Toyota 75w-85.
    parker44[QUOTED][OP] likes this.
  7. Jul 26, 2018 at 10:23 AM
    parker44
    Yea, Toyota oil was going to be about $250 for just the material, before any labor. I imagine they would probably tell me it's a 4-5 hour job as well.
