Differential squeak
Discussion in '1st Gen Tundras (2000-2006)' started by Swimslikearock, Oct 19, 2019.
  1. Oct 19, 2019 at 5:26 PM
    Swimslikearock
    Swimslikearock [OP] New Member
    Swims
    03 SR5 4x4 TRD
    Pretty stock
    Annoying squeak in the rear end. Not an engine (coasting with engine off) squeak. Related to drive train I put the rear end on jack stands and put it in gear. Related to the revolution of the drive shaft. I have the zero fittings packed with grease. I sprayed WD-40 and penetrating oil all over the area. Stethoscope not real clear but sounds like the front of the rear diff housing. Anyone ever have similar issues?
  2. Oct 19, 2019 at 5:42 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    A squeak in that location can be the first sign of a dying u-joint. Especially if it is a sealed one with no grease fitting.
    revtune likes this.
  3. Oct 19, 2019 at 5:42 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Rubber type squeak? Rear u joint? If it’s in the rear diff I would think it would be more of a metal sound, chatter or clunk. Could also be the pinion seal.
  4. Oct 19, 2019 at 5:44 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    We both posted right at 7:42:D
  5. Oct 19, 2019 at 6:01 PM
    Professional Hand Model
    Hand Protectors
    Mice like to harbor up this time of year. Could be a Fast and Furriest friend?
    bmf4069 likes this.
  6. Oct 19, 2019 at 7:57 PM
    Swimslikearock
    Swims
    03 SR5 4x4 TRD
    Pretty stock
    Pinion deal could be the issue. I can’t eliminate the u joints yet. Thanks for the input. I did check the gear oil and it’s full and never has been changed. I didn’t want to change it until I can eliminate the diff or the pinion seal / bearing.
  7. Oct 19, 2019 at 8:15 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    There’s a dust seal on the outside of the diff just behind the pinion flange. They can get bent and produce a noise like what you’re describing similar to a bent brake backing plate.
  8. Oct 19, 2019 at 8:22 PM
    Swimslikearock
    Swims
    03 SR5 4x4 TRD
    Pretty stock
    Thanks. There is a partially dislodged seal on the front of the pinion. I’ll dig in tomorrow.
  9. Oct 19, 2019 at 8:25 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    They can get dirt and junk wedged in there sometimes. Here’s mine.. barely bent as well.
  10. Oct 20, 2019 at 6:42 AM
    Hand Protectors
    Take some pics and post up the fix!
