Differential fluid
Discussion in '2.5 Gen Tundras (2014-2021)' started by bsktball55, Oct 18, 2021.
  1. Oct 18, 2021 at 11:39 AM
    bsktball55
    bsktball55 [OP] New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Do you need to buy the differential fluid that has the limited slip additives in it? Since the Tundra isn't a real LSD, I didn't know if it needed it or not.
  2. Oct 18, 2021 at 11:43 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    No.
    AZBoatHauler and Jaypown like this.
  3. Oct 18, 2021 at 11:46 AM
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    auto LSD isn't the same as a mechanical LSD. auto LSD simulates the the operations of LSD by applying brakes individually to the spinning wheel. with auto LSD system, you do not need LSD friction modifier in your rear differential.
  4. Oct 18, 2021 at 12:07 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Not needed. I’m far from an Amsoil fan but do yourself a favor and get Amsoil 75w90 in the squeeze bags. Unless you’re using an electric pump out of a drum it’s the easiest way to fill a diff. My local Coastal store carries it for $16 a quart, not much more than Mobil1.
    SteyrM40A1 and Oey12 like this.
  5. Oct 18, 2021 at 12:51 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Any 75W90 synthetic diff fluid will be fine. No need for any LSD additives.
  6. Oct 18, 2021 at 1:38 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Stock diff's are open diff. No need for LSD additives. Stick to what Toyota calls out.
