differential drop necessary for leveling kit
Discussion in 'General Tundra Discussion' started by big rig, Jul 31, 2015.
  1. Jul 31, 2015 at 2:29 AM
    big rig
    big rig [OP] New Member
    2015 tundra crewmax
    Debating between a 3/2 leveling kit or just a 2" Front lift. The 3/2 kits come with a differential drop piece. While the 2" doesnt. Does anyone know if doing a 2" Front leveling lift needs a differential drop installation. I know these types of lifts affect cv angles on 4x4s but is it necessary being that my rig is 2WD.
  2. Jul 31, 2015 at 6:15 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    If your truck is 2WD, you have no front differential to drop....
  3. Jul 31, 2015 at 6:50 AM
    Wikid
    Wikid New Member
    Don
    Toyota Tundra Crewmax Platinum
    On order
    I simple google search is your friend.
    You can find multiple postings on this topic, by searching "Tundra Differential Drop" Many of them come from right here :) Mdavis is correct. Differential drops are suppose to help relieve the stress, from additional CV angle on the front drive line. You have none.
    Here were was the first page of my search
    Do I need a Diff Drop Kit - Page 2 - TundraTalk.net - Toyota ...
    www.tundratalk.net › ... › Tundra Discussion › Tundra Suspension Talk
    Mar 8, 2012 - 5 posts - ‎2 authors
    Found the thread on TS - here is what I did. The first is the Revtek kit and I just bought parts at my local hardware store. Doesn't seem too hard ...
    Do I really need a Diff Drop on my level kit?
    Sep 24, 2014
    Diff drop needed with bilstein 5100's??
    Feb 11, 2012
    3/1.5 lift, need differential drop?
    Oct 16, 2011
    Diff drop required??
    Oct 19, 2010
    More results from www.tundratalk.net
    More images for differential drop kit tundra
    2007-2014 Toyota Tundra 4WD Differential Drop Kit PRO
    supremesuspensions.com/.../2007-2014-toyota-tundra-4wd-differential-d...
    Rating: 4 - ‎Review by brandon - ‎Mar 15, 2015 - ‎$29.95
    Our Differential Drop Kit is highly recommended for 4WD model trucks with independent front suspension. This kit will lower your front differential and reduce the ...
    www.tundrasolutions.com/forums/tundra/216176-differential-drop-kit/
    Jun 22, 2011 - 10 posts - ‎4 authors
    I recently had a 3/1.5 leveling kit installed in my 2008 5.7 L Double cab ... How many of you guys are running diff drop with you leveling kits? 15 posts
    Feb 16, 2012 15 posts
    Jan 19, 2012 15 posts
    Nov 2, 2009 12 posts
    Jul 8, 2008
    More results from www.tundrasolutions.com
    tacoma differential drop kit, diff drop, tacoma diff drop kit, FJ ...
    https://www.trail-gear.com/.../Diff_Drop_Kit...Tundra/.../_300814-1-KI...
    Tacoma Front Diff Drop Kit, 1995-2004. Lifting a first-generation Tacoma, Tundra, or 4Runner increases the angles on the CV joints and boots, which ...
    2007 2015 Toyota Tundra 4WD Differential Drop Drops Kit Pro
    www.ebay.com › ... › Suspension & Steering › Lift Kits & Parts
    eBay
    $29.95 - ‎In stock
    2007-2015 Toyota Tundra 4WD Differential Drop Drops Kit PRO in eBay Motors, Parts & Accessories, Car & Truck Parts | eBay.
    Zone Offroad Differential Drop Kit T5306
    zoneoffroad.com/zone-offroad...differential-drop-kit...tundra/t5306
    $42.75
    Zone Offroad Products T5306: Differential Drop Kit - 07-12 Toyota Tundra. Kit allows you to drop the front differential mounts 1", reducing the angles on your c.v. ...
    Diff Drop Kits - Yotamasters
    https://www.yotamasters.com/shop/diff-drop-kits/
    Lifting a Tacoma, Tundra, Sequoia, FJ Cruiser, or 4Runner increases the angles on the CV joints and boots, which accelerates wear. These solid aircraft-grade ...
    DIfferential Drop Kit for Toyota '95-04 Tacoma, '96-02 4Runner
    www.lowrangeoffroad.com/differential-drop-kit-for-toyota-95-04-tacom...
    1. $29.00 - ‎In stock
      Low Range Off Road is your source for a DIfferential Drop Kit for Toyota '95-04 Tacoma, '96-02 4Runner, and '99-06 Tundra.
      Searches related to differential drop kit tundra
      front differential drop kit
      differential drop kit sequoia
      toyota tundra diff drop
      toytec tundra lift
      tundra lift kits
      toytec lift kits
      4 lift kit toyota tundra
      sequoia lift kit 2008
      1 2 3 4 5 6 7 8 9 10 Next
    T-Rex266 and Black Wolf like this.
  4. Jul 31, 2015 at 7:06 AM
    I'm thinking about getting the Zone diff drop kit or maybe going to ACE and see what I can dig up. Not much to it. I have the 3" spacer lift and as far as I can see there is no diff drop. (Was already on my truck when I got it) May not be necessary but should do it anyways to restore CV position as close to factory as possible.
  5. Jul 31, 2015 at 7:07 AM
    Thinking the same thing. No need for 2WD. Nothing to drop.
