Differential DROP kit?
Discussion in 'Suspension' started by Jonlee124, Oct 4, 2019.
  1. Oct 4, 2019 at 6:56 AM
    Jonlee124
    Jonlee124 [OP] New Member
    Jonathan
    Houston
    2014 Tundra white 5.7L
    When do you need a differential drop kit?
    I am looking to do Bilstein 6112 or 5100s upfront probably next year on middle setting. I wish to raise up 1.9 inches and get close to a PRO height.
    I have read 3 competing threads basically saying you need to get a diff drop kit if you go over 3 inch lift. The DDkit will apparently prevent premature failure of cv joints. However, some members measured the cv angles and said DDkit does absolutely nothing. Also, the PRO does not run a DDkit.
    I am asking because I want to get a RCI skid. However, I do not know which one to get with or without the differential drop kit?
    I guess I could get the RCI skid without the drop kit and later when I put on the Bilsteins get spacers for it later?
    Just curious. Any help would be great. Keep drivin’ Be safe...
  2. Oct 4, 2019 at 7:15 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I installed dd on my 3.5” lift. I can’t imagine how aggressive the cv angles would be without it. For the $100 it costs I wouldn’t consider not installing it for insurance.
    mountainpete likes this.
  3. Oct 4, 2019 at 7:17 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I would run a DD with any lift over stock to get your CV angles back to factory. Like @2ndgenny said, it's worth it just for the insurance
    Mountun Goat and Jonlee124[OP] like this.
  4. Oct 4, 2019 at 7:19 AM
    Jonlee124
    Jonathan
    Houston
    Yes sir, I see thanks for that input.
    Just looking to raise the front and stuff a bigger tire on. I don’t want to regear but move up from 275 70r18 to a 28570r18 (ridge grappler)or 285 75r18.
    Mountun Goat likes this.
  5. Oct 4, 2019 at 12:18 PM
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    I could by wrong (so please feel free to correct me), but the TRD Pro doesn't have one and it is lifted ~2" on the front.
  6. Oct 4, 2019 at 1:06 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    You totally could be right! I don't know any of the specs for the trd pro, its too far out of my price range lol. I was basically saying that nothing bad will come from installing the DD kit. Or at least I've never heard of anything bad happening because someone installed a DD kit.
  7. Oct 4, 2019 at 1:13 PM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    Cheap insurance easy to install. The closer to neutral you can get the axles the better.
  8. Oct 4, 2019 at 2:00 PM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Not necessary at 1.9”. Pro doesn’t run it, you don’t need to either.
  9. Oct 4, 2019 at 2:11 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I agree with the other statements that it’s not needed with 1.9” of lift. Like the others said, the Pro doesn’t have one even with 2” of lift.
  10. Oct 4, 2019 at 2:27 PM
    15whtrd
    15whtrd Mr. Blonde
    If you do the diff drop, it tilts the differential. Recommend checking the fluid level after the drop, as it will now read low. Top off to the fill threads as you would normally using the correct fluid. This is to insure everything stays lubricated properly.
    eccracer104, 14burrito, equin and 3 others like this.
  11. Oct 5, 2019 at 2:43 AM
    Jonlee124
    Jonathan
    Houston
    Nice, good advice
    15whtrd likes this.
  12. Oct 5, 2019 at 4:27 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Have had 5100s on the middle setting on my '10 since new, just over 10 years old, 60k miles, no diff drop and have not had any issues.
    15whtrd, equin and Jonlee124[OP] like this.
  13. Nov 27, 2019 at 7:05 PM
    Tankdiver
    Tankdiver New Member
    2017 Toyota Tundra SR5 Crewmax
    Eibach 3” front coilovers, Toytec rear leaf shackles 1”
    I just had a shop here in Las Vegas install 3” Eibach coilovers ( only getting 2.25” lift actually with stock tires). I had asked the shop about installing a dd. They strongly recommended against it as it now angles the diff so the pinion bearing does not get lubrication leading to premature failure that will lighten your wallet to the tune of $500-$600. They said they have never had any cv joint issues on any 2-3” lifts and not using a dd. They said even if They did it would be cheaper and easier to deal with cv boots/joints than tearing down a diff for rebuild.
    AggiePhil, pandapro and Flyinryank like this.
  14. Nov 27, 2019 at 7:14 PM
    ajax1
    ajax1 New Member
    2012 black trd limited modded up
    Tires, suspension, bumpers, soft topper
    No need for diff drop didn’t run one on my old tacos and don’t on my tundra, don’t see the point. What will ruin your cvs will be that you put them at to high of angle and the boots rub through shooting grease out, so lift to the point the boot rubs don’t touch or do different boots on the cv
  15. Nov 28, 2019 at 5:14 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    Has anyone here had the pinion failure while running the diff drop?
    Big J likes this.
  16. Nov 28, 2019 at 5:52 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, 3D Spyder all weather mats
  17. Nov 4, 2021 at 8:41 AM
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    I see I'm hitting on an old thread but am curious about this statement. Anybody know if the front differential and cv axles are identical from the pro to other tundras which I suppose would suggest that the pros are running the cv axles at the same angles that other tundras would be with up to a 2" lift in the front?
  18. Nov 4, 2021 at 10:36 AM
    Vang530
    Vang530 New Member
    it's the exact same. no need for a diff drop kit. i have little over 3" lift on fox 2.5's and 37s and don't run one. 20k miles no issues. you loose ground clearance and its less than a degree of difference on the cv boot. all it does is tilt the diff to the rear and doesn't do much to help. it's useless but lots of guys run it just because.
    the pic is distorted due to the lens and makes my tires look weird, but you can see the cv angle where i'm at.
    Mountun Goat, equin and AggiePhil like this.
  19. Nov 4, 2021 at 11:37 AM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Was advised the same when I had Westcott Designs put in my TRD Pro Fox suspension with their collar lift (raising it higher than a stock TRD Pro)…my truck actually had a DD from the prior owner with Bilstein 5100’s on highest setting. They actually recommended and removed the DD as they said it doesn’t do anything for the lift height (~3-3.5”) other than tilt the dif and is far more likely to cause premature wearing/failure of the pinion bearing than any negligible gain to the cv angles. Also said it defeats purpose of the lift just to reduce clearance gains with the DD.
  20. Nov 4, 2021 at 2:20 PM
    Cement4WD
    Cement4WD New Member
    Cement TRD Off Road 4x4
    I have a 3” suspension lift and also researched that diff drop isn’t really a drop, just a tilt. Fluid is also adversely affected in not lubing parts properly. 20000 miles since 3” lift and I’ve had 0 issues or evidence of premature wear. Oh and you also lose clearance with drop.
    1P7R9O4, Vang530 and equin like this.
  21. Nov 4, 2021 at 2:29 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
    There was a thread a few years ago on here where someone installed one and measured the cv angle before and after with an angle finder and it basically was the same
    Vang530, equin, Trust86 and 1 other person like this.
  22. Nov 28, 2021 at 5:16 PM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    Just had 4 wheel parts in reno install a leveling kit, using Bilstein 5100 shocks. They told me the Diff. drop kit is a must if I plan to keep my truck.
    They Lift about 100 trucks a year and been in business for over 20yrs. I would think they know what there are doing. The Diff. drop kit only cost $30.39. Good insurance.
  23. Nov 29, 2021 at 10:08 AM
    SprinterAE86
    Ian
    For the amount of lift that you're getting, may be not necessary. I had it both ways. I installed it my previous Tundra it and opted out of installing it in my current Sequoia do to it being a pain to install. I might install it in spring, since I am wanting to add another inch of lift.
  24. Nov 29, 2021 at 2:43 PM
    Vang530
    Vang530 New Member
    For what it's worth, the stock TRD Pro's are lifted about 2" on the front to level out from the factory and even Toyota doesn't use a diff drop. It's not necessary, but doesn't hurt either way though I guess..
  25. Nov 29, 2021 at 2:52 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    I can't remember if it was total chaos, fox, or accutune, but someone who's name carries weight said not to do it for coilover lifts and I never thought about it again.
    equin and Vang530 like this.
  26. Nov 29, 2021 at 3:24 PM
    I'll look in my garage but I think I still have a brand new diff drop kit sitting in a box if someone needs one. I'll post pics of it if someone is looking for one.
