Differences within 1st gen
Discussion in '1st Gen Tundras (2000-2006)' started by sixteen2nd, Jan 24, 2020.
  1. Jan 25, 2020 at 9:08 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Good catch. I've also noticed the side door trim is different on some years. DC and AC trim not the same. Not sure about 05-06 access cabs though.
  2. Jan 25, 2020 at 9:17 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    A lot of things on the DC trucks are different, trim, body panels, lights, bed, and tailgate.
    There was also the change in the transmission planetary gear set in 03? there were some failures in the older trucks.
  3. Jan 25, 2020 at 9:33 AM
    Sunnier
    Sunny
    San Diego, CA
    “Stepsister” :rofl:
    artsr2002, bmf4069, Darkness and 2 others like this.
  4. Jan 2, 2024 at 3:57 PM
    02TundraCJ
    02TundraCJ New Member
    Cole
    2001 Tundra Access Cab
    Lifted 3.5”. 35” Nitto Mud Grapplers. Aftermarket door speakers and Apple Carplay stereo.
    Are the lower control arms from the 05-06 interchangeable with an 01? As in direct bolt on? I know the lower ball joints have a different bolt pattern and they were built beefier to reduce the failure in them.
  5. Jan 2, 2024 at 5:46 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Not without the spindles as well I believe.
  6. Jan 2, 2024 at 7:03 PM
    GipsyKxng
    GipsyKxng New Member
    2005 AC 2wd limited
    It's ugly as shxt but I I like them
  7. Jan 2, 2024 at 8:58 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    02 SR5 RC Desert Sand- ARB'd 4x4
    BOSS head Unit, Track Rack, Tint. MT Baja Legend EXP 16x9, Pro-Comp 69, Icon Titanium Rebound 17x8. Cant decide on Lift. ARB Rear. Bash Fab Sliders.
    I plan to source one from a pull it yard and do same thing. Variavle geometry intake plenums def work...prob wont see the gains of one paired with vvti but you should see increase in tq and hp from "intake runner lenghth " tuning. Longer runners in theory =more tq, change over to short * should increase ~higher rpm HP. I dont think its ever been dyno proven....but lots of oem added variable geometry intake mani's in the 2000's to squeeze more ponies out of existing engine architecture. And obviously higher end vehicles had them in the 90's. As reference, running length "tuning" is a known functional mod on other platforms. VW/Audi/BMW all did this and most combined with "insert oe name of variable valve timing" to maximize gains. I would think on our motors, the addition of a less prone to heat soak material and intake pulse tuning would net a solid 10WHP....but this is total speculation.
    Example : VW 2.5 CYL non,-turbo motors ( found in newer rabit/jetta models have dyno proven gains of 30whp ( which is huge for a 2.5 -5cyl motor)
    Almost wish my starter would take a crap so I had a real reason to pull the intake mani and upgrade.
  8. Jan 2, 2024 at 9:02 PM
    BluegrapeVr6
    J
    Also I think the later model tundra's have more hardy spider gears. This is off memory. Im sure someone in here can chime in on that. If I could do it over, i would upgrade my 02 to the newer style knuckle/lbj as they did it for a reason and I believe the LBJ has extra bolt compared to 00-02 models. This is off memory from reading Shifty's threads.
  9. Jan 2, 2024 at 9:16 PM
    BluegrapeVr6
    J
    Real helpful info would be to know at what vac the valve switches to short runner lenghth and if this correspondes with vvti tuning. Our engines (00-02l only make what 245hp at 4800? Later make near 300? Since our V8 achitecture likes to rev ( for a truck/not a s2000 lol) im assuming all the later model ganes come from the vario geometry intake and majority vvti. But, id be shocked if adding decreased power. Dirtydeeds seems to think their are some butt dyno gains. If anyone has your motor apart, measure the plenum lenghth for us 1st gen nerds.
  10. Jan 3, 2024 at 2:37 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Hmmm...deja vu
    https://www.tundras.com/threads/variable-runner-intake-for-2000-2002-tundra.119190/#post-3060511
  11. Jan 3, 2024 at 4:11 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I think you mean planetary gear. They put in a stronger one starting in 03.
    BluegrapeVr6[QUOTED] likes this.
  12. Jan 3, 2024 at 5:49 AM
    BluegrapeVr6
    J
    Yes, i lnow Keith has similiar thinking to I. But id dont recall claiming proof of any gains. .....but it was changes....and more power was gained..my guess, if you looked at a dynojet 248 ect plot...you could easily pick out the plenum "flap" , then if you captures logs i bet the vvti advanes more aggressively then early motors. Im no pyscic but lol
  13. Jan 3, 2024 at 5:53 AM
    BluegrapeVr6
    J
    Yes, thanks brother. Bottom line. The older the first gen the more improvements were made. I personally can do without additional emissions devices, but Id love the newer box /planetary gears, bumper-flush mout for trailer light connection ect.
