Difference between these cam shaft sensors
Discussion in '1st Gen Tundras (2000-2006)' started by batwrangler, Dec 4, 2015.
  1. Dec 4, 2015 at 2:14 PM
    batwrangler
    batwrangler [OP] New Member
    Bat
    na
    na
    What's the difference between these two cam shaft sensors on 2005 tundra 4.7 old one on left and the one I just bought and can I install the new one just the way it is even with that metal strip on it?
  2. Dec 4, 2015 at 2:37 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I assume that's just a shipping bracket to protect the sensor.
  3. Dec 4, 2015 at 3:41 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah id say take that bracket off.
  4. Dec 4, 2015 at 4:07 PM
    batwrangler
    Bat
    na
    na
    ya but is it for sure ..cause the parts man read to me over the phone something saying not to remove it...so im going their tomorrow and see what he was looking at ..but are you guy sure ..why would they drill two holes and use metal and not plastic a bigger and heavier part?.if it was just to protect it ?
  5. Dec 4, 2015 at 4:40 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Expensive part to protect. I would assume the metal would not let the sensor read right.
  6. Dec 4, 2015 at 6:20 PM
    2995 ? I would assume by then that all bugs would have been fixed by then. :bananadance:
  7. Dec 4, 2015 at 6:50 PM
    batwrangler
    Bat
    na
    na
    just read on a site a tech said its a heat shield and it aluminum.and will read ok....but with all the pos and neg response ill bring both sensors to Toyota and see what they say WOW ill tell you im glad for all this ..it will help me not have a failed engine ..if any more input will help...thanks..ill put up pic soon
  8. Dec 4, 2015 at 6:56 PM
    I would leave it on. It's a heat sink, not a shipping bracket. LOL.
  9. Dec 4, 2015 at 7:28 PM
    batwrangler
    Bat
    na
    na
    I thought so thanks again ..
  10. Dec 4, 2015 at 9:36 PM
    csuviper
    Broomfield, CO
    I do not have experience with the part or actual knowledge of what the added part is. I made a guess or assumption based on observation. One its covering the front of the sensor. Two the screws look to be cheap zinc coated. Three it appears the metal is painted. Four the original doesn't have it. If it's really supposed to be there installed with it I would be surprised.
  11. Dec 4, 2015 at 11:19 PM
    batwrangler
    Bat
    na
    na
    I hear ya guy ..the metal is not painted and is aluminum strapped so I got it from auto zone but im going to match it with Toyota has and we'll see..like I said earlier the parts man read not to remove it ...so ill find out today I hope
  12. Dec 5, 2015 at 4:08 AM
    Virgils12
    My local Toyota dealer will price match so I have been getting all my parts there instead of advanced or auto zone. That way I no I have what I need. Might want to check into that.
  13. Dec 5, 2015 at 7:41 AM
    Typically camshaft sensors biggest cause of failure is excessive heat thus a heat sink is used on this particular sensor for good reason. Most sensors that are exposed to high heat for long periods like oxygen sensors also have higher failure rates. I see the same thing everyday in electronics, especially RF. Heat sinks provide two things : dissipating/deflecting heat and also in this case shielding a critical sensor from excessive heat to prevent premature failure. Heat sinks to not need to be made of titanium and chrome moly screw fasteners . The vast majority of heat sinks are in fact made of aluminum due to it's heat dissipation coefficient and almost always have a heat resistive coating (looks like paint). It's certainly possible it is something else, but many current shunts utilize the same sink strap design that is on this sensor.
  14. Dec 8, 2015 at 7:28 PM
    batwrangler
    Bat
    na
    na
    Yep the strap is ok ..truck has been back together and running great...thanks everybody
    TruckLife900 and Black Wolf like this.
  15. Dec 8, 2015 at 8:28 PM
    csuviper
    Broomfield, CO
    Crazy. Glad you got it figured out. I probably would have mistakenly taken the strap off.
