Diff service
Discussion in '2.5 Gen Tundras (2014-2021)' started by squid, Jun 16, 2020.
  1. Jun 16, 2020 at 6:49 PM
    squid
    squid [OP] New Member
    Pacific Northwest
    2014 crewmax
    Trd sway bar, trd shit knob, Bakflip MX4
    I have read all the posts on doing the Diff service and it looks pretty straight forward. My question is, is this fairly easy to do? I do my own oil but I’m a bit nervous doing this for some reason. Thanks
  2. Jun 16, 2020 at 7:04 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Don't be nervous, lots of vids on YouTube will guide you right through it if you need help. I think the most important part is using the right gear oil, and making sure you can remove the filler plugs before you attempt to drain the oil. Good luck.
  3. Jun 16, 2020 at 7:05 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Yes, it's as easy as you think it is. I use 85W-140 in the rear because I spend large amounts of time in hot environments. Unless you forget to put oil in it you'll be fine.
    Luckydog likes this.
  4. Jun 16, 2020 at 7:10 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Easy peasy. You'll want the truck level. Make sure you get the fill plug out BEFORE you pull the drain plug. Reusing the crush washers is fine. And get the ole summer pool nose plug---used gear oil is worse than fresh horse shit.
    15whtrd likes this.
  5. Jun 16, 2020 at 7:37 PM
    AZBoatHauler
    So.Arizona
    As stated above, this is way simpler than an oil change. I did change out the crush washers for peace of mind. They are like $1 at the dealer. The front is a little more difficult to access but still super simple. One of the from plugs takes a copper washer if I recal correctly. (Assuming you’re 4WD)
  6. Jun 17, 2020 at 8:20 AM
    squid
    Pacific Northwest
    2014 crewmax
    Thanks for the info, I appreciate it
  7. Jun 17, 2020 at 8:22 AM
    Yes it's super easy. I also replace my crush washers.
  8. Jun 17, 2020 at 8:58 AM
    kevine0001
    kevine0001 New Member
    Kevin
    You can order the crush washers off Amazon, way cheaper. just make sure you have correct part number. it's very easy, just get a decent fluid transfer pump to fill the diffs. and make sure you're using correct oil for the t-case (75w). ravenol (about $20) or OEM (about $80) per bottle. you'll need two for t-case. I think about 5-6 bottles of the diff fluid for both diffs.
    Tundra1078 and Ely010606 like this.
  9. Jun 17, 2020 at 9:47 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    As stated, before you drain, make sure you can remove filler plugs.
    If you can change your oil, you can change diff fluid. It's a cinch.
    To help you out a bit:
    Rear diff drain/fill plug 36 ft. lbs. torque
    Front diff drain/fill plug 29 ft. lbs. torque
    Front differential - 75w-90 - 2.2qt (2.08L)
    Rear differential - 75w-90 - 3.8qt (3.59L)
    I used Ravenol J1C1109 SAE 75W-90 Gear Oil.
    And should you decide to do the transfer case fluid as well (same change interval as diffs & extremely easy, too):
    Transfer case 27 ft. lbs. torque
    75w - 1.6qt (1.51L)
    I used Ravenol J1C1003 SAE 75W Manual Transmission Fluid
    Dorks68, Tundra1078, equin and 6 others like this.
  10. Jun 17, 2020 at 10:01 AM
    TemujinNomad
    TemujinNomad New Member
  11. Jun 18, 2020 at 3:52 AM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    EASY?!
    Like Sunday mornin'....
    (Those of you from the 70's will get that one)
    Seriously, this fluid change is a piece of cake as is the transfer case. I think the diff change is easier than doing the oil actually...
    No skid plate to remove. (Rear)
    Less mess.
    Knock it out, brother!
    equin and Ely010606 like this.
  12. Jun 18, 2020 at 4:49 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Growing and my hair and smoking sh!tty weed then.
    Early Lionel..............
  13. Jun 18, 2020 at 5:43 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Get a Allen wrench with 3/8" or 1/2" socket fitting for the front. Make sure it is fully seated before trying to loosen.
  14. Jun 18, 2020 at 7:26 AM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    FIRST, MAKE SURE that you LOOSEN the FILLER PLUG BEFORE removing the drain plugs.And all of them are crazy tight.Other than that its a fairly easy job.Front is just tight on space especially if your doing it in your driveway on your back. Just did mine last weekend.
  15. Jun 18, 2020 at 7:46 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Tag
    Pinay likes this.
  16. Jun 18, 2020 at 7:48 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Did mine at 30k, washers still looked new so I won’t replace them until next time. Will probably replace my rear diff fill plug next time as well, it got a little bit stripped as it’s quite shallow.
    kevine0001 likes this.
  17. Jun 18, 2020 at 10:19 AM
    kevine0001
    Kevin
    forgot about this....this is really important!
  18. Jun 18, 2020 at 8:04 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Check your vents while servicing them too.
  19. Jun 18, 2020 at 8:17 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I’ll change your diff for you next time if you take that picture down. :rofl:
    Haggis777[QUOTED] likes this.
  20. Jun 23, 2020 at 6:32 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
  21. Jun 23, 2020 at 10:53 AM
    squid
    Pacific Northwest
    2014 crewmax
    Has any one used this? it it any easier to fill?[​IMG]
  22. Jun 23, 2020 at 11:03 AM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Works awesome for the rear diff.....front diff not so much..pain in the ass to get it in the right spot without spilling
    equin likes this.
  23. Jun 23, 2020 at 5:24 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I pump mine in at all three spots.
    chugs likes this.
  24. Jun 23, 2020 at 6:15 PM
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
  25. Jun 23, 2020 at 8:13 PM
    Porkchop Express
    Cody
    2017 Tundra CM
    Same. 75w90 synthetic in both diffs and the transfer case
  26. Jun 23, 2020 at 8:47 PM
    GNTundra
    Gino
    2013 White
    Just serviced mine about two weeks ago. Simple to do. :thumbsup:
  27. Jun 24, 2020 at 3:59 PM
    Rob's Inferno
    Mobil Delvac 1 75w90 front and rear and Toyota 75W in T case.That 75W is like water compared to 75-90.Front was very clean ,rear was dark and t case looked like new.Its done for a long time now.
    AZBoatHauler likes this.
  28. Jun 24, 2020 at 4:28 PM
    AZBoatHauler
    So.Arizona
    How many miles on it when you changed the fluids? I did front and rear diffs at 34k and had the same experience re fluid color. I didn't do the T case because 1) cost and 2)I'm still waiting for someone to say they changed it and it didn't look perfect.
    Doxiedad likes this.
  29. Jun 24, 2020 at 4:30 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    I used these on my truck. I get things at cost if you ever need anything.
    WFD473 likes this.
  30. Jun 24, 2020 at 5:10 PM
    Rob's Inferno
    36000 mi
